[quote="lfb6, post:397, topic:32169"] ...... make a backup of current bios or bios- region with fpt
Tools: See Section C2 in
Intel (Converged Security) Management Engine: Drivers, Firmware and Tools
Look for ME System Tools v9.1 r7 - (2018-09-01) Should be ME 9.0 or 9.1 if I'm not mistaken.
Use Flash programming tool, fpt(w(64)), naming according to dos/ win/ win64 version.
fpt(w(64)) -d spi.bin would dump the complete chip, unclear if flash descriptor is unlocked already.
If you get an error use
fpt(w(64)) -bios -d biosreg.bin
Post or attach the result
Don't use these tools to write if you don't have 1) a hardware programmer and 2) a valid backup of your complete spi chip!!!!! [/quote] You can continue in collecting "signs" and "symptoms" but that won't help much since you possibly won't find many other people who destroyed their bios the same way as you did......
I recommend strongly to dump your bios now as long as it's possible with software tools. There's a certain danger that you'll end up with a bricked system having lost the machine specific information (mac address, serial, ...), too, if you continue to flash 'something'.
I downloaded that ftpw64 and the first thing it does when launches is trying to update the bios and then it gives this error -CANT UPDATE BIOS. The ROMID is not compatible-
So i used Universal Bios BackupToolKit 2.0 to backup my bios and will link my bios dump since i cant attach it here due to size limit
http://s000.tinyupload.com/?file_id=12080392696141565515
You definitely did not run fptw64. Without switches it gives you a list of options, the command fptw(64 -d spi.bin will dump the complete spi chip, and will not try to write. In addition fptw dosenāt care about āROM IDā. See pictures in spoiler for output (Dump on a H97 system, meks no difference)
2.-d spi,bin
3. -bios -d biosreg.bin
Make screendump of command window such as one can see the written command and the output and post it.
- The command needs to be run at the command prompt directly in the folder where fptw64.exe is located.
- In the folder there are only allowed 4 files when you start: fparts.txt, fptw64.exe, idrvdll32e.DLL, pmxdll32e.DLL
- Command prompt has to be run as administrator
Make screendump of command window such as one can see both the entered command and the output and post / attach it.
Ok i think i donwlolad the right file this time but when i try to put those command it gives me an error
Ok i finally managed to dump that bios using the biosreg stuff
http://s000.tinyupload.com/?file_id=01557249159128853494
The first error you got could have been because you didnāt have admin priviledges or even more likely you have a locked bios?
Think there is a way, although complicated way, to unlock that lock.
Anyhow we really need a full dump. This image is missing the ME region. Like to know what version ME your running.
Maybe you could run MEinfoWin64.exe?? Its in the CSME package. Post the results.
Thanks
Edit: Might want to try to flash the latest 4101 bios release for your board. This may over write the faulty flash data due to being newer data.
Interestingly enough seems like Uefitool NE Alpha has trouble locating the correct location for the FIT data in the official Asus bios release.
Point to the wrong pad file. Anyhow I have noticed Asus bioses always have backup volumes and redundant microcode volumes. When modding
I always make sure each on is identical.
Anyhow still curious what version ME your running.
DONT DO:
If feeling adventurous as this involves risk:
Try this: fptw -rewrite -bios -f bios.bin
You could also try: fptw64 -greset
OK, thanks. The error for the SPI is expected, thereās a read protection for the ME region of the bios.
@loris100 Despite of board specific information and NVRAM your dump is 3801 stock bios. Thatās so far as expected, oem bios update programs donāt update the complete bios region but spare the settings (NVRAM) and the board/ machine specific data. Error might be in NVRAM volumes, these wonāt be completely reset whe loading defaults in bios. Other part of bios that can be corrupt would be ME.
DTS key: Not present
UUID: 8068D43F22C0D3118DD5AC9E17B553A8
MBSN: 141134744700310
There are different things Iād like you to do:
Try to get as much as possible regions from your bios- please run:
fptw64 -DESC -d FDreg.bin
fptw64 -GbE -d GbEreg.bin
fptw64 -ME -d MEreg.bin
Post the result of
fptw64 -i
Now see the picture: You see on the left side your first bios dump (Universal bios backup kit), 16 MB, though missing Descriptor, GbE and ME region, all replaced by FFās in first padding, the first EfiFirmwareFilesystem volume is the start of the bios region. On the right side thereās a ASUS stock 3801 bios, complete structure with Descriptor, GbE, ME (Your own bios does have these too, you just didnƦt have the right to read them/ one of them). Compare the NVRAM volume(s), your bios dump has 2 volumes, the stock bios has an almost empty NVRAM, just the default, the rest is generated dynamically.
Next thing to do would be to try with a stock/ empty NVRAM, possible ways of accomplishing this would be
- prepare a bios region with stock NVRAM and combined with your dump, flash the complete bios region, but that depends on write access to the bios- and even if the bios region is unlocked in the descriptor, there might be protected ranges within the bios region.
- flash just the NVRAM region, since itās constantly rewritten thereās normally not much protection of this area. But that needs to be done precisely, itās dirctly followed by the FIT table
Please run these commands directly after each other. NVRAM gets updated constantly, so one reboot makes the dumps before and after that reboot different.
fptw64 -BIOS -d biosreg2.bin
fptw64.exe -A 0x180000 -L 0x80000 -d nvram.bin
The first command gives complete bios region with current NVRAM, the second command reads the first 512kB of your bios region, corresponding to both NVRAM volumes. I would like to have both the dumps directly read after each other, for comparing if address and length in the command are correct and give right result.
The fpt command @davidm71 mentiones would make fptw64 rewrite the bios region with a file bios.bin This file bios bin has to be a correct working bios region, otherwise itāll brick the board! Iād not update the board to 4101, the static parts of current bios are identlcal to 3801 ASUS stock bios, the NVRAM will not be reset anyway.
Sorry didnāt mean to mislead or risk a brick. Thank you Ifb6 for pointing that out!
Anyhow if he used EZ-Flash on the newer version would that still risk bricking?
Sorry againā¦
@lfb6 @davidm71 thank you for your time guys, im not home but later when i get home i will try those steps, i have the 3801 bios because it doesnt have the Spectre patch in it, the 4101 have the spectre patch, i didnt test much but it seems like there isnt a performance difference between these 2biosāes and this looks strange, this is why i wanted to get rid of these cpu patches in first place, to gain a bit of performance
Assuming its possible to go to 4101, ask Ibf6 first, that could fix whatever ME mismatch nvram issue your having and then would just mod the microcode on 4101 instead. Wouldnt use command line tools. Ask Ibf6. Ignore my previous instructions. Thank you.
@davidm71 No offence meant! But I got very careful about all flashing commands, especially if I know thereās no programmer around, or no complete backup ā¦
Iād probably try this kind of check for write protection in direct combination with a dump, like fptw64 -bios -d biosreg.bin and then directly followed by fptw64 -bios -f biosreg.bin, this way Iād be sure to have identical names and the correct file to flash back.
Use of Asus flash programs is unclear for me, but since static bios parts are identlical to stock this would be mainly interesting if there would be an option to reset the NVRAM. And Iām still not sure how far this reset would go⦠Locked into manual, EZ-Flash doesnāt have any options, Bupdater isnāt even mentioned with this board and I doubt that it would have options to reset the NVRAM.
I did some dumps as you said
biosreg2.bin http://s000.tinyupload.com/?file_id=30093942184861611200
FDreg.bin http://s000.tinyupload.com/?file_id=48474111363706437368
GbEreg.bin http://s000.tinyupload.com/?file_id=00056031369608813590
nvram.bin http://s000.tinyupload.com/?file_id=56325216656804593219
fptw64 -ME -d MEreg.bin gave me an error
and will attach fptw64 -i
@loris100 OK, thank you. Clipping the NVRAM with fptw64 worked fine.
Iād like to check some more things since you donāt have a programmer- but that will take some time, at least until tomorrow!
Next step would then be replacing the NVRAM with an empty stock NVRAM (see attached file). Command would be
fptw64.exe -A 0x180000 -L 0x80000 -f nvram_cl.bin
That should work, but as always thereās a risk for a brick when flashing the bios!
(And thereās no warranty that this will fix this error, but the only other thing in bios would be ME and I doubt that Management engine will be the culprit here.)
As far as I can see your board does have a socketed bios chip? Iād recommend buying a cheap CH341A programmer, makes life a lot easier, especially when you have more modding in mind!
nvram_cl.zip (2 KB)
Hi, i replaced the NVRAM with the one you provided, it flashed successfully but it still shows 3 cores and 6 threads, when hyperthreading is disabled it shows 6 cores and 6 threads as before
@loris100 OK, was actually writing a definitve text since I wanted to try āresettingā NVRAM within Windows myself, did this always with programmer.
If this didnāt work, then itās from bios side only ME thatās not yet checked- and Iām not very optimistic that this is ME related. Possibly @plutomaniac knows if getting wrong number or cores / threads could be ME related?
Do you have the option to use another (clean) OS/ Windows installation, maybe from an USB stick?
Since already uploaded:
Bios region 3801 with board specific data but stock NVRAM
hereās a link to a complete 3801 spi image with your board specific Flash descriptor, GbE, Stock ME region, and bios region with your board specific data, but clean / stock NVRAM
@lfb6 Ok i will try a new windows install, what should i do with your attached files? Do i have to flash them now or try after a new windows install? They are RE and BIN files, i dont even know how to flash them?
Thereās no need for more flashing just now. Cleaning/ re-flashing ME would require unlocking flash descriptor first anyway (or a hardware programmer), but I hope plutomaniac will give a hint here if ME could be the cause.
Please run once MEInfoWin64.exe -fwsts (Intel ME System Tools v9.1 r7\MEInfo\WIN64, admin prompt) and post the result.
Those 2 other files are just āside effectsā, keep them as backup, Iāll delete them afterwards. Theyāre all binary, re meant for region (naming it reg would make it a registry file), spi a complete chip image.
This is what i getā¦
Edit: i clicked on the file the first time, but now i run the command line thereā¦
@lfb6 Installing a new windows fixed it
Thank you so much!!
But im still curious to remove all cpu patches and to see if it performs better this way, older bios like the 3801 doesnt have spectre patch in the microcode vs the 4101 who has that patch but the performance is identical
That was my suggestion as well. Though never thought it would work. Wow!
Well, I had the idea in the start, but ā¦
Emptying the bios for µcodes is quite easy, but I doubt that this will help you, it might even leave the system bricked.
And thereās still Windows µcode update. Iād recommend reading a little about checking the currenctly used µcode in your system (bios/ windows), checking which mitigations are used (and if retpoline is activated), and- last but not least- to buy a CH341- programmer just in caseā¦
Good luck!
https://support.microsoft.com/en-us/topiā¦cc-357f104f5b11
reg query HKLM\HARDWARE\DESCRIPTION\System\CentralProcessor\0 | find āe Rā (normal command prompt)
If bios µcode revision is newer than windows µcode only bios revision is shown
For list of µcodes in mcupdate_genuineintel.dll- drop file on MCE.exe
