[ARCHIVE] Outdated UBU Tool related Questions, Reports and Suggestions
Starting with version UBU 1.12, all new versions of the modules OROM and EFI will be placed in a separate file UBU_Upd *.exe.
File UBU_Upd
*.exe need to put in a folder UBU and run script UBU.bat, all new files are automatically unpacked, or run this file manually with the key "-y".
@ CodeRush
Do not see the point of release 0.30. Make a new UT and maintain old, only the excess waste of time and nerves. :wink:
What means "UT"?
What means "UT"?
UEFITool, the short name - UT. :slight_smile:
0.30 is the new version, so it’s nothing pointless here.
Speaking about AptioV support: what kind of “support” are you waiting for? What 0.20 makes wrong with AptioV?
@SoniX
Hello :slight_smile:
Here is Haswell microcode rev. 1D Date: 2014/12/10
(Sorry if this has been posted Before, i have been very busy lately.)
c326c31d.zip (21.1 KB)
I think there is a file missing.
! UEFIFimd not found !
Press any key to continue . . .
You are right.
Please take the download link to my OneDrive account until SoniX has repaired his package.
Oops! Re-Upload UBU_v114_fix.rar
Sorry!
@Pacman
Hello! :slight_smile:
Where is the the microcode found? :wink:
It is from this BIOS:
http://download.msi.com/bos_exe/nb/E1812IMS.10C.zip
I noticed that all new appear more frequently in MSI. :slight_smile:
Added:
OROM found in GUID’s A0327FE0-1FDA-4E5B-905D-B510C45A61D0 and 365C62BA-05EF-4B2E-A7F7-92C1781AF4F9
The second GUID is not available for MMTool.
It seems that this will be the standard for Aptio 5 BIOS. Is interesting whether the new version MMTool with appropriate support?
will there be version for notebooks ?
Probably not, but some UBU functions do work with BIOSes from mobile systems as well.
The main problem is the risk to brick the mobile system while flashing an uncorrectly modded BIOS.
is there any way of saving the bios file as .rom(cant be flashed through afuwin) after changes ?
After the modification you should rename the BIOS file according the original one.
EDIT: Since you had posted your last 2 questions into the wrong thread, I have moved them to this one, which has been designed for questions regarding the UBU tool.
upgrading the vga did not worked its version is same not 2170.
there can be bug so ım saying.
Intel vBIOS has mobile & desktop firmware, UBU includes desktop only.
Anyone know what issues this microcode updates, resolves, patches, etc?
Updated:
- Intel Haswell CPU Microcode 1D (CPU ID 06C3 Socket LGA 1150)
I don’t know what this Rev. 1D will patch, but i’m testing with the same HW (i7 4790K + ASRock Z97 OC Formula) the two revisions that UBU can handle (1C and 1D) and obviously the native Rev. 19 included by ASRock into the V.1.30 BIOS.
First impressions are not so good because Rev. 1D seems worse than Rev. 19 for OCing as it is needed more VCore to maintain the OC level achieved with Rev. 19, i’ll test all CPU micro-code (19/1C/1D) and i’ll post results.
Cheers,
KK
after opening ubu.bat is ubu uses UBU_Upd_1 to update program ? why its lost i want to understand
also i’ve sent private message to you fernando
