Hi everyone,
I’m trying to enable Secure Boot on my ZSUS X99-W motherboard (with an Intel Xeon E5-2680 v4).
When CSM is enabled and Storage Boot Option Control = Legacy:
-> My SATA SSD is fully visible in the boot menu and works perfectly.
When CSM is disabled (required for Secure Boot) or when in CSM Support → Storage = UEFI:
-> The exact same SSD completely disappears from PCH SATA Configuration (see screenshot). As a result, even though “Windows Boot Manager” may still appear in the boot options, the system cannot actually boot from it and loops back into the BIOS.
Windows is installed in UEFI mode
The drive is formatted as GPT
SATA mode is set to AHCI (not RAID)
This is not a Windows or partition issue the SSD is fully functional and bootable when forced via Legacy. The problem is purely BIOS-side: the UEFI firmware fails to enumerate the SATA drive when CSM is off.
System Details:
Motherboard: ZSUS X99-W
CPU: Intel Xeon E5-2680 v4
SATA Mode: AHCI
SSD: SATA (not NVMe), GPT partitioned
Target: Enable Secure Boot → requires CSM = Disabled
UBU Analysis:
I analyzed my stock BIOS using UEFI BIOS Updater (UBU) and found the following:
Scanning BIOS file bios-x99-w-zsus-original.rom.
Please wait…
Manufacturer - INTEL
Model -X99-W
BIOS release - 5.11 12/04/2024
BIOS version - 00.01
BIOS platform - AMI Aptio 5
[EFI Drivers - Find and Extract]
Intel RST GUID 91B4D9C1-141C-4824-8D02-3C298E36EB3F
AMI NVMe GUID 634E8DB5-C432-43BE-A653-9CA2922CC458
Realtek Undi GUID 32D4B2DD-1DB3-4AF9-91B0-FBAE6E6EA259
[OROM - Find and Extract]
OROM in GUID 365C62BA-05EF-4B2E-A7F7-92C1781AF4F9
OROM in GUID A0327FE0-1FDA-4E5B-905D-B510C45A61D0
Main Menu
[Current version in BIOS file]
1 - Disk Controller
EFI Intel RST RAID Driver - 14.8.0.2377
OROM IMSM RAID for SATA - 8.9.0.1023
OROM Intel RSTe for SATA - 4.5.0.1012
OROM Intel RSTe for sSATA - 4.5.0.1012
EFI NVMe Driver present
2 - Video OnBoard
3 - Network
EFI Realtek UNDI Driver - 2.037
OROM Realtek Boot Agent GE - 2.66
4 - Other SATA Controller
5 - CPU MicroCode
View/Extract/Search/Replace
S - AMI Setup IFR Extractor
O - Option ROM in other GUIDs
0 - Exit
RS - Re-Scanning
A - About
Choice:
Disk Controller
[Current version]
[Available version]
EFI Intel RST RAID Driver - 14.8.2.2397
OROM Intel RST for SATA - 14.8.2.2397
EFI Intel VROC for SATA - 6.1.0.1017
EFI Intel VROC for sSATA - 6.1.0.1017
OROM Intel VROC for SATA - 6.1.0.1017
OROM Intel VROC for sSATA - 6.1.0.1017
1 - Replace
2 - Replace only RST
3 - Replace only RSTe/VROC
X - Extracted
0 - Return to Main Menu
Choice:
Request for Help:
How can I make my SATA SSD properly detected and bootable in UEFI mode with AHCI, without relying on CSM?
Should I replace the EFI Intel RST RAID Driver in my BIOS to get SATA SSDs detected in pure UEFI mode (with CSM disabled)?
If yes, what is the correct replacement driver ?
Thanks in advance!
Edit by Fernando: Thread title shortened and customized
.webp)
