Just for the record;
"Error 26: The host CPU does not have read access to the target flash area. To enable read access for this operation you must modify the descriptor settings to give host access to this region."
Is also a common error for people only trying to dump their BIOS’es. In the case of only dumping BIOS image (not ME or other sections besides that), the most common problem is one that hasn’t been mentioned yet:
SOLUTION
- you forgot the -BIOS argument in the command line
Basically, fptw(64).exe -d bios.bin can produce the error.
But, fptw(64).exe -d bios.bin -bios doesn’t produce the error, and lets you dump the BIOS successfully. At least, that worked in my case of Error 26.
hello
Can you help me whit my hp pro x2 612 G2
My me engine is broken.
it take more than 40 sec before the machine starts
I flasht many files from al forums but non whil solve the problem
I hope you can help me whit this.
In the f10 setup from the bios the me version is 0.0.0.0
regards chris
