with alot of trial and error and reading this HMRFPO_ENABLE mesage is what i need to enable service mode i tested it on my pc (posting old config) service mode jumper on me disable and full read write permissions one issues im getting is error 7 hardware missmatch but i can flash same image back and all regions i think one of my other setting may be incompatable.
1205.rar (3.7 MB)
at the moment i flashed the original dell a34 bios back and im going to get a full spi dump from the pi and keep on usb incase!
hi after a bit of help so im goin throw my UEFI and came across this
PchBiosWriteProtect_PchBiosWriteProtect
Section_PE32_image_PchBiosWriteProtect_PchBiosWriteProtect.rar (1.5 KB)
i cant seam to extract it anyone give me a hand thanks
I should be able to see it in the ifr extracted platform but all i get is Intel Ref.code setup hide
edit
this is for the AMI AptioV UEFI EDITOR i get my bios lock sorted but trying to see if it possible to remove the FPRR from my bios
i have 5 7810 all with dual xeons and 2 5810. 3 of them i salved from going to a skip and the others i have aquired when my client upgrade there workstations
@Windius
Please stop starting several threads about the same topic. This is absolutely confusing for the Forum Staff and the Forum members, who are trying to help.
Today I have tried to find and merge all threads you had started since October 2022 regarding your Dell 7810 BIOS and Management Engine problems. If I missed any thread, please let me know it.
Thanks I will keep all my questions and post related to dell 7810 in this thread sorry for extra work
So what I did and have tried
I updated bios to one with the correct version I have installed latest dell A34 that didn’t clear the ME FW version error either
In windows fptw all regions unlocked so did full spi backup followed the clean me guide.
Flashed from pi did full erase all passed
Pc turns on error is gone but windows won’t load it crashes on dell logo but I can get into safe mode windows but crashes trying to load normal windows or dell automatic recovery
So getting backup redoing me and going to try flash again
I was hoping that getting in safe mode I could see what’s wrong but that didn’t happen
Any other suggestions or tips to try
Thanks
Edit:
So the worst think happened halfway through flashing and my upstairs neighbour drops something and I here the clip ping off at 38% fudge
Now as it flew off it bent the plastic that holds it on so it won’t stay connected
Went to the local electronics shop they have no more soic clips till after the new year but he gave me these to try tiny little clips that’s all he had till new year.
Got a Paloma clip on order with Amazon but not here for another week
Edit:
Somehow those clips worked and it managed to get the computer to boot got dell flash update and went to stock bios for now
so in windows on stock dell bios i checked fptw -i all regions were unlocked so did full Spi backup
A34spi.rar (7.0 MB)
i think its good but im scared to restart haha
H thanks for looking you were right i had ran that through ubu.
so to start from fresh i installed T7810A34 dell official update loaded up windows and all regions are unlocked just not able to flash back.
i looked in HWINFO and found im in manufacturing mode and
Host ME Region Flash Protection Override (HMRFPO) Status: Disabled
im gonna wait till my soic clip turns up before i try a flash again or if i figure out the spi pin header
this is just bios dump untouched from stock A34
jan02bios.rar (3.7 MB)
For anyone with x99 chipset after a lot of trial and error I have done it
Now for the fun part
I did get the multiplier to x35 on the locked Xeon
Picked up an arc she looks good
So got the arc working with rebar above 4g and csm disabled in bios
Added the rebar dxe into bios and bingo
She is a bit slow to boot
So oc locked 2x Xeon 2630 v3 x35 multiplier and core full turbo more powers setting a to play with yet
Rebar and v3x4 dxe inserted into bios
Now I think I need the 1350 psu and some water coolers
But shout out to the greenpcgamers who together we opened the back doors of the dell and slid in.
frankr2994
Thanks all
Would you mind share the steps? I recently acquired a 7810, too. Searched for guides to unlock Xeon v3 on 7810 and just found this thread. It would be nice to get some help from a person who did this before.
From my understanding, it takes removing microcode from BIOS then adding the UEFI plugin. However, you said that only unlocked one socket. How did you eventually unlocked both? Which tool made the final working image?
Then you seemed to be tinkering a lot with ME and had difficulties flashing the modded BIOS. Was ME a required step of the unlock mod?
Yes a lot of trail error but got it sorted in both cpu I’m more active on
There is a few of us working on the dells can help you get it unlocked on there bud
Thanks, will join.
- Did you solder that jumper to the motherboard? I’m too lazy to removed the motherboard from the chassis.
- Do you know how to add Intel RC Setup to Dell’s bios ? (looks like nothing works there but still)
- Do you know how to change RAM speed to 2400 (I have v4 CPUs) and adjust timings?
hey mate not on this much we have a discord server where we can help
