[Discussion] UBU Tool related Questions/Reports/Suggestions
@Michael_Code
It was not easy for me to understand your last 2 posts. You wrote “SoniX dont ask me”, but it seems, that you meant, that SoniX hasn’t answered respectively replied to your PMs for a very long time.
If that should be the case, we have a problem. Without SoniX’s explicit allowance nobody should offer any updated or customized UBU tool for the public.
The only thing you or anyone else can do is to upload and attach a package, which contains all the new BIOS modules, which are missing within the “Files” folder of the UBU tool v1.79.17. Once this has been done, I will edit the start post of >this< thread and add a link to the post, where the new BIOS modules are attached.
This way the interested UBU users themselves will be able to update the UBU tool v1.79.17 by adding the missing BIOS module files to the related UBU “Files” sub-folder.
What do you think about this option?
@plutomaniac
Unfortunately I didn’t read your reply before I published this post.
@Michael_Code
It is up to you whose advice you will follow.
No problem. Since we wouldn’t want to update the OP whenever someone decides to update something, we can mention there that some newer modules are found in the latest replies of this thread, if someone is interested to overwrite/add files of the last official package by SoniX.
@Dieter, you right. Im wrout withot any tranlanators, from Russian to English, My mistake. SoniX dont answered
wroute for our friend DeathBringer
@Diter, I 58 old, you - 78???
These are off-topic. You can send PMs if you like instead.
@plutomaniac
sorry, pluto
I have any updates from ASROCK
IntelGopDriver_efi_Tiger-Alder_17.0.1075-VBT250.zip (79.8 KB)
basically no need any update ?
copy only new plugins" roms / MC" or full package MC extractor “zip if need”
.,…and still works well :smiley: ,. , … one more thanks for this tool and forum :slightly_smiling_face:
Does anybody have a link to a full updatepack with updated files for UBU?
There is none… at the moment.
A lot of standalone updates for manual insertion but you’ll have to look through the posts and specific hw ids threads.
Hello
I try to update the microcode with UBU, I have this
But the microcode is not updated
If someone have idea
Thanks
The update was interrupted due to missing mcode 50654 path, put the new mcodes in the 2066 folder and insert it also in the mcupdate.txt
CPUMicrocodes/Intel at master · platomav/CPUMicrocodes (github.com)
It’s good, thanks so much :wink:
you must download last MC extractor package “source_python app” copy this in UBU ,overwrite files
  • manual find all MC “this files copy in Files\intel\mCode\USR_mCode\HERE”
    and you must use GenUSRmC.bat in mCode folder – this generate your customized update
after this in UBU + last MC extractor >>update from USR mCode
this way you will use and verify the latest MC for your bios :smiley:
edit
USRmC – for sure use all “identical mC” original - source UBU files + new from link above for update
USRmC can also add or delete current mCodes !!! – you must use identical mC tree
There is updated Realtek UEFI UNDI Driver 2.059 on realtek page but UBU shows UNKNOWN version. Is it safe to force update such thing?
Hello, can I actually update EFI LAN BIOS module for Intel I225? I want to update to Intel UEFI x64 PCI-E 2.5 Gigabit driver v0.9.03. How should I name it when putting in Intel/Lan folder? Dunno about OROM actually which should be right.
OROM VBIOS
VER 032.019.000.006.000000 Raphael
VER 032.017.000.055.000000 Rembrant
VER 017.010.000.031.000000 Barcelo
VER 017.010.000.031.000000 Cezanne
VER 017.010.000.031.000000 Lucienne
VBIOS.zip (151.0 KB)
Respected Experts i am very new to this forum & dont know anything about Bios Modding.
i hope experts must help me getting the latest updated roms for the Bios i am looking :
Specs via the Great UBU tool by Sir Sonix as follows
Scanning BIOS file TZ370PG.CAP.
Please wait…
Manufacturer - ASUSTeK COMPUTER INC.
Model - TUF Z370-PLUS GAMING Rev X.0x
BIOS release - 2801 01/13/2021
BIOS platform - AMI Aptio 5
[EFI Drivers - Find and Extract]
Intel RST GUID 91B4D9C1-141C-4824-8D02-3C298E36EB3F
Intel GOP SubGUID 380B6B4F-1454-41F2-A6D3-61D1333E8CB4
AMI NVMe GUID 634E8DB5-C432-43BE-A653-9CA2922CC458
Intel Undi GUID B1DA0ADF-4F77-4070-A88E-BFFE1C60529A
Intel Undi GUID 4953F720-006D-41F5-990D-0AC7742ABB60
Intel GOP VBT GUID 878AC2CC-5343-46F2-B563-51F89DAF56BA
[OROM - Find and Extract]
VBIOS in Padding
VBIOS in GUID A0327FE0-1FDA-4E5B-905D-B510C45A61D0
OROM in GUID A0327FE0-1FDA-4E5B-905D-B510C45A61D0
Press any key to continue . . .
after pressing enter
Main Menu
[Current version in BIOS file]
1 - Disk Controller
EFI Intel RST for SATA - 17.5.0.4136
OROM Intel RST for SATA - 17.5.0.4136
EFI NVMe Driver present
2 - Video OnBoard
EFI GOP Driver SKL-AML - 9.0.1080
RAW GOP VBT SKYLAKE - 212
OROM VBIOS SKL-AML - 1059
3 - Network
EFI Intel Gigabit UNDI - 0.0.13
OROM Intel Boot Agent CL - 0.1.10
4 - Other SATA Controller
5 - CPU MicroCode
View/Extract/Search/Replace
S - AMI Setup IFR Extractor
0 - Exit
RS - Re-Scanning
A - About
Choice:
Thanks a lot in advance :slight_smile:
@Disc2019
Welcome to the Win-RAID Forum!
Your post has been moved by me into this better matching thread.
As first step you should read the UBU Guide, which is within the start post of >this< thread.
After having done that, you can post here the questions, which are not answered within the Guide. Don’t forget to give us the following information:
  1. Which BIOS modules do you want to get updated?
  2. Is the on-board SATA Controller running in AHCI or RAID mode?
  3. Do you use the Wake-on-LAN option?
Enjoy the Forum!
Dieter (alias Fernando)
  1. Sir i want to Update all BIOS modules which are found old via UFU tool as per latest updated repos by there devs.
  2. on board sata controller is in AHCI mode with rst enabled ( ( i will take a snapshot of it & will post here)) : 1st M2 slot direct under cpu : wd 250gb 3d nand blue m2 sata ssd +Second M2 Slot : intel optane 32 gb . i also have samsung 980 pro 1 tb PCIE m2 2280 so that i will swap it with wd ssd when i need.
  3. no sir never used wake on lan.
Edit | Images of sata controller : 1 - Album on Imgur
@Disc2019
Since you neither use the Intel RAID nor the Wake-on-LAN option, an update of the Intel RAID and Network BIOS modules will have no effect on your current system (no benefit at all).
ok sir i will go only with latest Disk Controller ROM .
Pl let me know which rom will best suit this hardware as 17.5.0.4136 i think is old :slight_smile:
