[Guide] Add TPM module on Chinese X99 and X79
Sorry to hear that. I had a quick look and both the 2022 version and the 2024 version of QD4 have Secure Boot. However, there is no TPM support. My questions:
  • Do you have a complete 16M copy of the original BIOS still? If yes, can you upload it to somewhere I can download from without requiring registration?
  • Do you have a picture showing the entire motherboard, not just the Debug port area?
  • How long ago did you buy this board?
I checked further with FITC, and it also shows me that the ME region (9.1.30) is configured for a B85 chipset. Which is good news on the whole, it is just “Example 4” when putting together a BIOS.
Edit: ME region was configured exactly the same between the 2022 and the 2024 version. Which is expected.
so the trusted computing option there is for secure boot ?
the bios file is either hz-x99-8m-f.tp.rom OR hz-x99-8m-f.tp.tu.rom
i think they are the same
but now i dont know if the one i used was any of these ones ! lol
i have to access my main pc which is not possible right now
B1 BIOS
9.1.30 ME from my bios
changed IIO to auto like the original bios
it was bought in december 11 2024
Ok, then things are getting clearer
Proposed way forward for BIOS
  • Take the 9.1.30 ME region from the G629A, and then follow “Example 4”
  • The G629A BIOS has IIO 0 configured as x4x4 ; x16 ; x16
  • I have not seen a confirmation that TPM actually works with the 8M-F BIOS. It is from 2020, when this feature was generally not required/requested
i shouldnt have set these options to auto on the B1 bios then ?
B1 BIOS
9.1.30 ME from the z99-8m-f bios
instead of x4x4 ; auto ; auto use x4x4 ; x16 ; x16
is this right ?
Basically just follow the original G629A BIOS (not 8M-F), including ME and IIO 0 configuration. In my own experience with 8 types of motherboards, that works without any problem.
Also make sure that you have a new enough GPU that supports UEFI booting. This is a common requirement on any BIOS on any platform, the moment you enable Secure Boot.
Hi all,
I have a Machinist X99 PR9-H (black PCB) and I’m trying to get TPM 2.0 + Secure Boot working, because Valorant (Vanguard) requires both on Windows 11.
My board:
  • Board: MACHINIST X99 PR9-H (black PCB)
  • BIOS: AMI 5.11, dated 02/22/2024
  • Super I/O: Nuvoton NCT6779D (per HWiNFO)
  • CPU: Xeon E5-2650 v4, GPU: GTX 1660
  • Windows 11 24H2, UEFI boot already working (GPT)
  • Flash chip: [marking on the 8-pin chip]
  • TPM header: [JLPC1 / DEBUG, pins soldered or not]
Problems:
  • The BIOS has no Secure Boot option.
  • Setting CSM to Disabled freezes the BIOS.
  • No TPM module installed yet.
I found the modded BIOS “X99 PR9 v1.4 (by FIB)” from tiburcillo’s post, but its internal ID says “MACHINIST X99 PR9”, not PR9-H, and I’m worried about hardware differences (chipset, flash chip, Super I/O).
Questions:
  1. Has anyone tested this BIOS (or any other mod) on a PR9-H or PR9-H 2.0?
  2. Is there a PR9-H specific BIOS with Secure Boot?
  3. I read that the official PR9-H BIOS already supports TPM. Can anyone confirm?
  4. How can I tell which chipset (H81/Q85/Q87) my PR9-H has?
I have a CH341A programmer and will make two dumps of my current BIOS before flashing anything. Thanks!
Hello and welcome!
Can you start by uploading a complete 16M copy of your original BIOS to somewhere I can download from without requiring registration?
From what I can remember the PR9-H board is HM55 based, which means I personally have no way of helping you here. No experience. If you have problems, I would simply try looking through the Angxun BIOS page.
Huananzhi X99-F8 / G335J Ver.2.0
NCT5532D
Xeon E5-2678 v3
4×16 GB DDR4-2400 REG ECC
BIOS 2.18.1263
Hello there, good afternoon. I appreciate in advance your contribution regarding the X79 and X99 platforms and the lack of TPM 2.0 support. You see, I have a Machinist B9 X99 motherboard; it has a section at the bottom labeled “DEBUG,” and I assume that is where the connection pins for an external TPM 2.0 module should go. I would like to know where to start and what tools or materials I need to add TPM 2.0. Thank you for what you do; also, if it’s not too much to ask, could you please keep the explanation simple? I tend to get a bit lost in this conversation thread.
ch341a-✓
Check the #2 post, it’s exactly the same for your board (X99 B9 is just a rebrand of X99 D3M4)
Yes, I’ve read that section thoroughly; I just have a few questions. Which exact TPM 2.0 model should I use? How should I solder the wires? And what is the diagram’s orientation? I assume it’s based on the board’s natural position
Earlier I gave up completely on the older Huananzhi motherboards. I made some test BIOSes, but I did not receive any usable feedback. Anyhow:
  • For 5532 based boards like in your case, then the BIOS in this post seems to work well. See confirmation from the user brichanfiana in the post below that one
  • For 5567 based boards, then the latest official v6 BIOS seems to work just fine
TPM pinout looks correct, based on the information from this page.
My recommendations having done this twice on a X99D3M4 and X99D4M4
  • Buy a TPM module that has 2.54mm pitch width. That is typically sold as a 20-pin generic TPM module on Taobao/Aliexpress/Ebay etc
  • Do not solder any wires on the motherboard. Instead solder on pins on the unpopulated header. In particular, I bought several 5*1 rows of 2.54mm pins. Then installation is exactly the same as any other board. You can also use the header with a debug card, as I show in the second post in this thread
  • The diagram is oriented “as you see it”. If unsure what that means, there are multiple ground points (GND) on the TPM module. You can put the multi-meter in continuity/beep mode to clarify things
я дам обратную связь после прошивки. спасибо
I’ll provide feedback after the firmware update. Thanks.
Back when I first installed the TPM, it was a 2mm-pitch model, so I had to make an adapter cable, but nowadays you can get TPMs that plug in directly from sites like AliExpress. It’s still working on Windows Server Insider Canary, including Secure Boot. I’ll post the old screenshot again here. (The driver for the ASR-81605ZQ I’m using isn’t up to scratch, so if I run programmes like HWInfo, the RAID stops working, which means I can’t take screenshots straight away.)
ошибка b7 на материской плате.
This is an English speaking forum, so please use English. On a personal level I do not speak Russian or Portuguese, but I use translation tools to get information.
In my experience, B7 typically means that the BIOS flash chip is not supported. So what flash chip are you using? In particular, what is the SPI ID when you detect it with for instance NeoProgrammer?
Winbond 25Q12BJV… — I am using W25Q128JV in NeoProgrammer.
Ok, then I think this really drives home the point about my lack of understanding the difficulties with the F8/T8/TF BIOS compatibility. Proposed way forward:
