I dont have Vcore option in the bios.
And via XTU ?
Via XTU I did try changing the vcore offset from 130 (what it defaulted to) to 160. It was around 1.38v - 1.39v.
Hi everyone! Got an old Acer SFF PC with Pentium G4600 CPU, dumped its BIOS with FPT with no problems, but there it goesā¦CoffeeTime 0.99 can apply some patches, and change ME, but canāt replace microcodes and change VBIOS + GOP. Iāve used MMTool to replace microcodes, but iāve stuck on VBIOS and ACPI tables.
UBU v1.80 canāt modify them either. Can anyone help me with solution? BIOS dump here
Thank you in advance!
P.S. BIOS version is R02-B0
i keep seeing ācopper tapeā mentioned here, i assume this has to be conductive on both sides? because most of the ācopper tapeā that i find isnāt conductive on both sides. one side has to have adhesive which wonāt conduct electricity, at least not reliably.
can anyone confirm if itās enough to short the socket pins or is it necessary that the short also goes through the cpu pads?
because in that case, i can stick something to the two pads on the cpu that need āshortingā with something that unites the two socket pins (i.e. just buy any ācopper tapeā). the pencil trick doesnāt seem durable and i assume these pads wonāt accept solder sticking since nobody ever mentions it.
