[Guide] CoffeeLake CPUs on Skylake/KabyLake MBs
@dsanke Just flashed and it works! Thank you!
Hi Guys, I have a QQLS Mutant and had that thing running in an Asrock Z170 ITX Board with no problems. I now switched to an ATX Board (MSI Z170A Krait Gaming), modded the bios with coffeetime 0.99 (same settings as Asrock Bios before). CPU posts and boots, but Performance is a lot lower. CPU only boosts to 3,3ghz all core and Intel XTU says I am restriced by Current/EDC even without loads. I played carefully with voltages but that almost insantly causes reboots of the system. Do you have any idea what could be wrong here?
Hi Guys,
I got another Board, an ASRock Z270 Extreme 4 and my QQLS refuses to post/boot.
This is my Bios:
Anything wrong here? ME? Thanks in advance!
@chrisk2305
Could be a problem with the BGA-to-LGA interposer. Did it come with the ASRock board? It may not work with other boards.
@chinobino : Thanks, but that CPU was working fine in another ASRock Z170 and also a MSI Z170 Board. PC turns on for a brief second and then turns off. Maybe something wrong with ME?
@chrisk2305 I will tag @dsanke to ask for help with getting the BGA 1440 QQLS to work on a ASRock Z270 Extreme 4 if/when they have time (thanks in advance dsanke).
Much appreciated!
Got to work thanks to @msm8960
Mar '20
Thank, it’s work with Asrock Z270 Extreme 4. (Need E6 method of plutomaniac’s [Guide] Unlock Intel Flash Descriptor Read/Write Access Permissions for SPI Servicing before Flash bios)
ā€œsetup_var 0x68F 0x01ā€ for who don’t have time.
@chrisk2305 Thanks for reporting back. So it seems your flash descriptor was locked and you couldn’t downgrade ME FW.
exactly
Hey All,
I followed this thread to use the latest 2019.1229 version ALLINONE Tool to modify the BIOS file for the H110M-STX found in my ASRock Deskmini 110. Unfortunately, inspection of the resulting output BIOS file showed that no CPU microcode was written at all!
I know of at least one person that had success with the same mobo using a previous version of the ALLINONE Tool. Does anyone have access or a link to the 2019.618 and/or 2019.311 versions of the tool? I’d like to give one of those a try.
Thanks in advance!
-James
give it a shot with coffetime tool from here.
Thank you! Great information. I missed it completely since it was part of the original post. I downloaded and played around with coffeetime extensively and was left with a few unknowns:
  • I want to keep the Intel ME FW enabled so that I can use the Intel PTT (software TPM 2.0) on my system. It’s not clear to me if my existing 11.8.50.3425 FW can be left in place and enabled and still be compatible with Kaby Lake AND Coffee Lake CPUs.
  • Using Intel FPT, my BIOS appears to be locked for reading and writing in the important regions, making it hard to back up the BIOS region personal data and also to write out any updated BIOS.
    — Flash Devices Found —
    MX25L6473E ID:0xC22017 Size: 8192KB (65536Kb)
      --- Flash Image Information --
      Signature: VALID
      Number of Flash Components: 1
              Component 1 - 8192KB (65536Kb)
      Regions:
              DESC     - Base: 0x00000000, Limit: 0x00000FFF
              BIOS     - Base: 0x00200000, Limit: 0x007FFFFF
              CSME     - Base: 0x00003000, Limit: 0x001FFFFF
              GbE      - Base: 0x00001000, Limit: 0x00002FFF
              PDR      - Not present
              EC       - Not present
      Master Region Access:
              CPU/BIOS - ID: 0x00, Read: 0x00B, Write: 0x00A
              ME       - ID: 0x00, Read: 0x00D, Write: 0x00C
              GbE      - ID: 0x00, Read: 0xFFF, Write: 0x008
              EC       - ID: 0x00, Read: 0xFFF, Write: 0xFFF
Total Accessible SPI Memory: 8192KB, Total Installed SPI Memory: 8192KB
I don’t really want to have to jumper pins on hardware to remove the write protections. Am I cooked at this point?
@utwb3893 Hi, you must downgrade ME firmware to 11.7.1xxx for a Coffee Lake CPU to boot in the H110.
Use the Consumer version supplied with Coffee Time and leave it enabled so that TPM will also work.
If you can’t use FPT to flash a modified BIOS due to locked Flash Descriptor you will need to use a hardware programmer to bypass this.
Make sure you make a complete backup before you attempt to flash anything.
That means CoffeeTime can’t apply the patch, maybe this mobo don’t need it, I don’t know, you have to try.
Hello,
Considering i hit (ctrl+f) and only saw 1 entry for Dell, shall i assume this hack is still ONLY for Asrock boards?
I have a Dell Optiplex 7450 AIO id VERY much be interested in doing this with… But yet, its 4 cores max still… Correct?
Hello,
I created a bios mod file according to the instructions for the motherboard B365M
Phantom Gaming 4 but after flashing, I turned on the computer for about 5 seconds and then turned off. The DDram led lights up in the check led strip and stops there, after about 2 seconds the computer turns off. Before that, I created a bios mod file for the motherboard B250m gaming 3 and flashed it with CH341 successfully, used it for 2 years without any problems. My CPU is shared with the 2 motherboards above, QNCT 6C12T MIDIFIED LAPTOP.
Please help me create another bios mod file. Because I don’t know what I did wrong, after trying to create many different bios mod files but the result is still the same. Thanks you.
@JUMP Some ASRock boards have BIOS protection (Flash Descriptor writing being blocked). You should make sure that the ME firmware on the motherboard was actually downgraded.
Do you you have a Skylake or Kaby Lake CPU you can test the modified BIOS with to check the ME firmware version currently on the board?
You may need to use the CH341A to get past the BIOS locks.
I have i3-9100f cpu to test. After I flashed my B365M
Phantom Gaming 4 motherboard using CH341 with NeoProgrammer 2.1.0.19 software. I went into bios and saw ME firmware is 0.0.0.0 as shown in the picture.
I am pretty sure I overwrote bios mod bypassing BIOS protection.
@JUMP There are many changes that need to be made to the BIOS to get Coffee Lake CPU’s to work on a B365 chipset, what software are you using to modify the BIOS?
Can you link to the original BIOS and also upload your modified BIOS here so that it can be examined?
To get the BGA1440 CPU to work with that motherboard you may want to contact the person that sold you the CPU and ask if they can send you a working BIOS.
