@isaiahbonk I just verified that my D4M4 rev 1.13 with BIOS B2 becomes picky, even when using just a single stick server ECC RAM. It will only boot when it has RAM in what it considers to be the first slot (slot number 0). Which is physically the slot closest to the rear IO.
Were you using Alternative 1 or Alternative 2 when you were making a TBU BIOS?
The major point of the X99 platform since quite some time back, is being cost effective. And right now certainly is not a good time to buy RAM just for testing purposes. But that is of course up to you how you spend your money
If you really need something quick and still being able to use your existing RAM, then just do TBU the traditional way. No shame in that
Hello, I am attempting to enable Above 4G Decoding and Rebar on a Machinist X99 B9. I get a black screen after enabling these options and have to clear cmos. On a reddit post I wrote, I was referred to this forum since I need a modified bios. After reviewing this thread, am I correct that I would need to physically work on removing the bios chip, flash it, then reinstall?
I thought it would work just like a BIOS update but I think I may need to give up. I donāt really want to spend more on a motherboard because I bricked mine.
From what you are writing, then I would guess that the problem might probably be the combination of a Chinese X99 motherboard and Intel Arc GPU. If I were you, I would do the following:
Boot the system normally
Update the vBIOS (on the GPU, not the BIOS on the motherboard) to the latest version. I know how to do this with Nvidia and AMD, but no idea with an Intel Arc GPU. This is your homework
Try again with enabling Above 4G decoding and Rebar, while still on your original motherboard BIOS
One thing that really stands out when looking at the pictures is:
Should you want to flash my modded BIOS, there is absolutely no need to de-solder the flash chip. You can easily do it from Windows, using Intel FPT software. Based on the specs you have listed, then you want to put together a āD1_M2_B1ā BIOS. But once again, start with the GPU vBIOS.
Updating the vBIOS fixed everything. I had forgotten that I reinstalled windows and that nothing was up to date. I got a crash while updating which I think led to me reinstalling windows and not continuing with the update. Thanks for this.
For the motherboard BIOS, this is how it ran stock. I bought it on ebay through this listing so Iām not sure if the seller or supplier had updated it before. The listing doesnāt make any mention of secure boot so maybe it would crash if I tried enabling it.
Ok, glad you got it working! I have some recent first hand experience with newer GPUs on these older platforms. vBIOS update is typically the first thing to start with.
I will send you a PM with some more information and a request.
hello again, friend. I bought the tpm 2.0 and it worked, thank you for explaining the pinout. but now iām wondering if i need to update the bios. Remember, my motherboard is a x99 b9 and iām using the bios jginyue X99-8D4/2.5G Server. I have a 2690 v3 and need turbo boost. I also need to apply strapsrebar patch for my gtx 1660 GitHub - terminatorul/NvStrapsReBar: Resizable BAR for Turring GTX 1600 / RTX 2000 GPUs Ā· GitHub so, what is the best bios for all of this ? thank you in advance.
You are welcome! I think I will start with this question: What type of RAM are you using?
Server/workstation RAM (ECC)
Normal consumer RAM (UDIMM)
I have no experiece with Rebar on Turing. I guess you just disable the Rebar function in the BIOS and add āNvStrapsReBar.ffsā yourself. Based on my own testing with a 3070, there was no gain at all when using Rebar, sometimes even performance regression. I guess the same might be true for your 1660. But that is for you to find out.
Ok, since you are using UDIMM, then I think you can just continue with the BIOS you have. See more info in this post. I am trying some new things to increase RAM compatabilty when using UPT. No idea if I will succeed or not, and personally not so important to me. Before RAMmageddon, ECC RAM was much cheaper than normal RAM. Hence I bought ECC.
With Rebar I basically had the same findings with my 3070, as Hardware Unboxed did when they evaluated on a 3080. In particular, the games I primarily played on that system, had smaller regressions. I would be surprised if your 1660 behaves any differently.
