Yes, you can put together any combination you want/need that way. But please tell me, what is the last bullet point in that list? Did I say that you should use AMI Flash Utility, or did I say something else?
I didnât check flashing tools . My mistake . Im in a repair shop for reprogram bios. If its possible please help me to do it there . Is that possible for you to check bios that i modified ?
First of all: As you found out, it is normally not a good idea to try flashing a different BIOS without having a programmer in hand.
Just follow what I wrote, and it should work fine. Why am I that confident? Well, since you have the 1.3.x version, then I have not encountered XMC flash chips but normal Winbond. As far as I have seen, XMC started with some of the 1.5.x versions of ZX-99EV3 (A9EV3403 vs B9EV3403)
Youâre absolutely right my friend i brick it very soon . Thanks to you and my friend it goes back . I can see a fib logo on my window . Bios is dated 2023 . I think its ok . May i ask you guid me for overclocking settings over bios and How much it can handle in safe an cool zoon ?
Overclocked stable at 4.2 on bios. Added another fan on top of the case for heatsink . Everything is ok . Thank you very much and sorry about my Englishâ:folded_hands:![]()
. I will share edited file today
Ok, glad you have everything up and running. You are of course free to upload any modded BIOS you like, but I personally see no point if it is just one of the four possible variants (2 different ME regions ; 2 different BIOS regions) from my original upload. I do not I am not sure what your use case is, but I will just leave you some links below
- General setup/tuning
- RAM overclocking
- Live USB system for stability testing (needs Secure Boot off)
Thanks . I donât know this question is related or not . After overclocking ( im on 4ghz 1050 mv) i setup a new window 10 . (Same window same drivers same hardware and same settings in the game ) I have about 10fps lower . Even after disable overclocking . Any idea ?
About this bios 251005_HNZ_BD4_mods that is available, does it enable secure boot on x99-b9?
See the first post in this thread for an overview. As explained in more detail this post, the XMC flash chip is the reason why I have only been able to get a handful of BIOSes running on the X99-B9/X99D4M4. I am working on it, but I have not been able to arrive at a practically useful solution yet. I may or may not succeed.
