Intel (Conv.Sec.) Management Engine: Drivers, Firmware and Tools (2-15)
Intel ME System Tools v11.0 r16
Flash Programming Tool(DOS, EFI64, Windows, Windows64): 11.0.0.1205
Hello,
I found this forum by searching for an error I’ve got after updating my BIOS.
The error is:
1
2
Me FW Downgrade - Request Me Spilock Failed Error
Error sending End Of Post message to ME
This error comes on every boot when I completly switch off the PC (no power).
The Intel MEBX-Features are activated.
The PC is a DELL Precision 3620.
The BIOS-Version is 1.32
The Intel ME-Version is 11.00.194
Skylake-H-CPU
Upon searching for a solution I found this forum and updated the Intel ME to the latest version from here (11.0.0.1205), but unfortunately the error doesnt disappear.
Can anyone suggest a solution?
Thanks
@ FormatC:
Can you boot into Windows? Run MEInfo -verbose and MEManuf tools and show me pictures. Before updating the BIOS, had you already updated the ME firmware manually by any chance?
Hi, I got eglobal i3-5005U mini pc (Broadwell WildcatPoint-LP motherboard) with fully unlocked BIOS.
BIOS shows that ME FW info is missing, and MeInfo gives me the following errors
Windows64>MEInfoWin64.exe -verbose
Intel(R) MEInfo Version: 10.0.30.1054
Copyright(C) 2005 - 2014, Intel Corporation. All rights reserved.
FW Status Register1: 0x1E040195
FW Status Register2: 0x16522116
FW Status Register3: 0x00000200
FW Status Register4: 0x00004000
FW Status Register5: 0x00000000
FW Status Register6: 0x00000000
CurrentState: Normal
ManufacturingMode: Enabled
FlashPartition: Valid
OperationalState: Bring Up
InitComplete: Initializing
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Unsecured mode by H/W jumper
Phase: BringUp
ICC: Valid OEM data, ICC programmed
SPI Flash Log: Not Present
ME File System Corrupted: No
PhaseStatus: UNKNOWN
FPF and ME Config Status: Not committed
HECI device is found to be disabled.
Error 9256: Communication error between application and Intel(R) ME module (FW Update client)
Windows OS Version : 6.2.9200 “”
OS BIOS Support : UEFI
Table Type 0 ( 0x 00 ) found, size of 24 (0x 18 ) bytes
Table Type 1 ( 0x 01 ) found, size of 27 (0x 1B ) bytes
Table Type 2 ( 0x 02 ) found, size of 15 (0x 0F ) bytes
Table Type 3 ( 0x 03 ) found, size of 25 (0x 19 ) bytes
Table Type 8 ( 0x 08 ) found, size of 9 (0x 09 ) bytes
Table Type 9 ( 0x 09 ) found, size of 17 (0x 11 ) bytes
Table Type 10 ( 0x 0A ) found, size of 6 (0x 06 ) bytes
Table Type 11 ( 0x 0B ) found, size of 5 (0x 05 ) bytes
Table Type 12 ( 0x 0C ) found, size of 5 (0x 05 ) bytes
Table Type 32 ( 0x 20 ) found, size of 20 (0x 14 ) bytes
Table Type 34 ( 0x 22 ) found, size of 11 (0x 0B ) bytes
Table Type 26 ( 0x 1A ) found, size of 22 (0x 16 ) bytes
Table Type 36 ( 0x 24 ) found, size of 16 (0x 10 ) bytes
Table Type 35 ( 0x 23 ) found, size of 11 (0x 0B ) bytes
Table Type 28 ( 0x 1C ) found, size of 22 (0x 16 ) bytes
Table Type 27 ( 0x 1B ) found, size of 15 (0x 0F ) bytes
Table Type 29 ( 0x 1D ) found, size of 22 (0x 16 ) bytes
Table Type 39 ( 0x 27 ) found, size of 22 (0x 16 ) bytes
Table Type 41 ( 0x 29 ) found, size of 11 (0x 0B ) bytes
Table Type 7 ( 0x 07 ) found, size of 19 (0x 13 ) bytes
Table Type 4 ( 0x 04 ) found, size of 42 (0x 2A ) bytes
Table Type 221 ( 0x DD ) found, size of 12 (0x 0C ) bytes
Table Type 16 ( 0x 10 ) found, size of 23 (0x 17 ) bytes
Table Type 17 ( 0x 11 ) found, size of 34 (0x 22 ) bytes
Table Type 19 ( 0x 13 ) found, size of 31 (0x 1F ) bytes
Table Type 20 ( 0x 14 ) found, size of 35 (0x 23 ) bytes
Table Type 221 ( 0x DD ) found, size of 54 (0x 36 ) bytes
Table Type 221 ( 0x DD ) found, size of 68 (0x 44 ) bytes
Table Type 221 ( 0x DD ) found, size of 26 (0x 1A ) bytes
Table Type 136 ( 0x 88 ) found, size of 6 (0x 06 ) bytes
Table Type 13 ( 0x 0D ) found, size of 22 (0x 16 ) bytes
Table Type 14 ( 0x 0E ) found, size of 17 (0x 11 ) bytes
Table Type 127 ( 0x 7F ) found, size of 4 (0x 04 ) bytes
Error 9459: Internal error (Could not determine FW features information)
MeAnalyzer confirms there is no Intel Engine installed
MEA.exe -info
--------- ME Analyzer v1.4.10 ---------
Error, could not access the Intel Engine driver!
→ Make sure you are running ME Analyzer as Administrator!
→ Make sure you are using an Intel Engine compatible system!
→ Make sure you have an Intel Engine driver installed first!
MeAnalyzer says I got ME region in BIOS update file
File: GBDW1108.bin
Firmware: Intel ME
Version: 10.0.36.1030
Release: Production
Type: Region, Extracted
FD: Unlocked
SKU: 1.5MB
VCN: 2
PV: Yes
Date: 04/02/2015
FITC Ver: 10.0.30.1054
Platform: Mobile
Latest: No
Is it possible to extract and reflash only ME region from the BIOS file?
BIOS file - GBDW1108.bin
@ miasma:
Either at the BIOS or via a hardware jumper, you have disabled ME. If the motherboard has such a jumper, make sure it’s at the default state of ME Enabled. Otherwise, there should be a BIOS option (could be called HMRFPO, ME Disable, Protection Disable or similar) which needs to be set to Enabled again. When the ME is disabled the driver interface (MEI/HECI) doesn’t work. MEInfo reports that as well of you check (ModeOfOperation: Unsecured mode by H/W jumper & Phase: BringUp).
There are no hardware jumpers on this board as I can see.
This is the relevant BIOS section - can you help me to identify the option?
I already tried to enable/disable “Me FW Image Re-Flash” from Firmware Update Configuration option without success.
Thanks.
Yes, the BIOS option is indeed the “Me FW Image Re-Flash” one. That should be Disabled by default so that the ME is enabled without the ability to reflash. The fact that the BIOS does not show the version may actually indicate something being wrong with the firmware. Since you have the “Me FW Image Re-Flash” option you should Enable it in order to reflash the ME firmware. I have attached the extracted ME Region from the SPI image you linked above. Extract the file ME.bin and use Flash Programming Tool with the command fptw -rewrite -me -f ME.bin. After it’s done (successfully), use Flash Programming Tool again with the command fptw -greset which will reset the platform and ME. Once the system boots up, go to BIOS and disable the “Me FW Image Re-Flash” option. Hopefully you will also be able to see the Version from there as well. If yes, when booted into Windows, run MEInfo and MEManuf tools to check that everything is ok as instructed at the first post.
ME_GBDW1108.rar (1020 KB)
It didn’t work, I still can’t see ME enabled when running MEInfo and it shows as N/A in BIOS.
Also tried to flash ME regions from different BIOS versions for this board without success. It
Is it possible to flash Intel Firmware from the B1 section of the first post?
Hello plutomaniac,
thank you for your answer.
Little bit complicated since the tools do not run in 64bit environment so i had to set up a 32bit…
This is a Fujitsu C5731, SKU shows 18492 if TPM is enabled DIP, 18460 without DIP set.
Verbose of original installed ME with TPM DIP activated:
Copyright(C) 2005-08 Intel(R) Corporation. All Rights Reserved.
Intel(R) MEInfo Version: 5.0.0.1167
Trying to initialize heci…
Reading Fw Status Register…
FW Status Register: 0X3004066A
Manageability Mode is 1SKU is 2110Intel(R) Remote PC Assist Technology is disabled
GET Code versions
BIOS Version: 6.00 R1.06.3004.A1
Intel(R) Standard Manageability code versions:
Flash: 5.2.10 Netstack: 5.2.10
Apps: 5.2.10 Intel(R) Standard Manageability: 5.2.10
FW Capabilities: 62
ASF2
Intel(R) AMT
Intel(R) QST
Intel(R) TPM
VendorID: 8086
Build Number: 1023
Manageability Mode: Intel(R) Standard Manageability
UNS Version: Not Available
LMS Version: Not Available
MEI Driver version: 5.2.0.1008
GET Intel(R) AMT STATE
Link status: Link down
Cryptography fuse: Enabled
Flash protection: Enabled
Last ME reset reason: Global system reset
GET PROVISIONING STATE COMMAND FOR THE PARAMETER CONFIGURATION STATE
Configuration state: In process
GET END OF POST STATE
BIOS boot State: Post Boot
GET MAC ADDRESS
MAC Address: 00-19-99-xx-xx-xx
GET FW UPDATE COUNTERS COMMAND FOR THE PARAMETER FWUPDATE COUNTER AND QUALIFIER PARMETERS
FWU Override Counter: Always
FWU Override Qualifier: Always
GET FLASH DESC OVERRIDE COMMAND
GetLanInterfaceSettings COMMAND FOR THE PARAMETER IP ADDRESS
IP Address: 0.0.0.0
MEBx Version: 5.1.0.19
FT Version: 5.2
FT Build Number: 1023
Local FWUpdate: Enabled
Secure FWUpdate: Disabled
GET RCS CAPABILITY
Remote Connectivity Service Capability: False
GET PROVISIONING MODE
Configuration Mode: Enterprise
TPM Vendor ID: INTC
TPM SPEC Version: 1.2.5.2
TPM FW Version: 5.2
TPM Firmware Build Number: 1023
TPM State: Operational
TPM Operational Mode: Enabled Unowned Inactive
iTPM - FIPS 140-2: False
iTPM - Failed Attempts Threshold:61440
iTPM - Initial lockout period: 526
iTPM - Lockout multiplier: 4096
iTPM - Fade-out period: 0
iTPM - Physical presence life time lock flag: False
iTPM - Physical presence command enabled flag: True
iTPM - Physical presence HW enabled flag: True
TPM fuses (MCH/ICH/soft strap MCH/ soft strap ICH): Enabled
FW behavior on Flash Descriptor Override Pin-Strap: Halt
I cannot run fptw because of error 405: There are no supported SPI flash devices installed or …
Even if I disable TPM…
I recognised the problem with the updated ME on the board: first time the system gets the powercord attached the activity LEDs on the LAN stay ON. Shutting down the system per Windows shutdown with the original ME Firmware, they stay on - so I can use WOL. With the 5.2.71 version they go OFF after first shutdown no matter what combination I tried…
Hello, I have problem with my Yoga 3 Pro 1370 after ME upgrade. Could someone help me extract ME region from original bios file ?
Just wanted to warn before upgrading ME 5 to 5.2.71 - I just tested it again, upgrading from 5.2.10 (original) to 5.2.50 was perfect, no WOL affected. Upgrading from 5.2.50 to 5.2.71 kills the WOL on the onboard Intel LAN. I resolved it now by installing a separated PCI LAN Intel card, where WOL works again. Seems like no downgrade of the firmware is possible. Can you confirm that plutomaniac? Thank you
I tried to downgrade to 10.0.45.1024 ( version in bios ) but without success so I can only upload the same with -allowsv. I think I have a problem
Error 8741: FW Update Failed.
Error 8758: The image provided is not supported by the platform.
Can you help me, please ?
@ miasma:
If reflashing the ME region did not solve the issue, it’s simply not there. Maybe the BIOS has been tampered with or needs a clear cmos or similar? Have you tried reflashing the entire 8MB SPI image to the chip for testing purposes? Obviously keep a backup (dump) first. I am not mentioning anything about the Flash Descriptor because if I remember properly that SPI image from the OEM has it unlocked. That can be checked with MEA by dropping the full 8MB SPI image you linked me before.
@ FM:
Unfortunately I cannot confirm anything as this is an old platform which I have no experience with. I never had an AMT compatible system so I guess it’s a general statement. However, it’s the first time someone has reported such an issue. My initial thinking was that some MEBx setting was reset or similar. Have you checked MEBx by any chance to see if something is not right? I don’t think the firmware is “incompatible”, maybe something else is causing this. You said you upgraded as a test from one version to another. Did you do that with older Fujitsu BIOS releases or similar? If yes, can you provide the actual BIOS/SPI image used because the files provided by Fujitsu are compressed in a proprietary way and the one tool from 2006 that extracts these doesn’t work properly from what I can see. Apart from MEBx settings, I am also thinking that maybe you need a newer MEBx. The 5.2.71 firmware was found at a Dell system which mentioned at the changelog that the MEBx was also updated to the latest of 5.1.0.0020. You currently have 5.1.0.0019, maybe it’s not compatible with the latest 5.2.71 firmware? I wouldn’t know as I need the documentation from Intel to determine that for sure. Maybe a GbE firmware update as well is needed. If you can provide a proper SPI image from Fujitsu or at least your system’s dumped SPI image, I can look into the MEBx and GbE newer versions that I have and try to update them. Obviously, this is now becoming more invasive and I cannot guarantee that it will work out. If you are an advanced user then I’ll gladly see what I can do but if this system is critical for work or something and don’t have the tools to recover it in case of a BIOS/ME issue (programmer would be nice to 100% safe) then you shouldn’t proceed.
@ blogger:
My guess is that you are trying to flash the wrong SKU or something. Also, “have a problem” does not really help anyone understand if it’s even remotely related to ME. And there is no reason to send pms for help, I don’t reply to these. Last but not least, I cannot check the ME of your system’s BIOS/SPI image because that Lenovo executable refuses to extract on anything but that system and my other quick manual attempts failed. So you need to extract it manually and attach the BIOS/SPI image here or maybe a dump.
Zitat
I can't make a backup
C:\Intel\Flash Programming Tool\WINDOWS64>fptw64 -d bckup.bin
Intel (R) Flash Programming Tool. Version: 10.0.30.1054
Copyright (c) 2007 - 2014, Intel Corporation. All rights reserved.
Platform: Intel(R) Premium Express Chipset
Reading HSFSTS register... Flash Descriptor: Valid
--- Flash Devices Found ---
W25Q64BV ID:0xEF4017 Size: 8192KB (65536Kb)
Error 26: The host CPU does not have read access to the target flash area. To enable read access for this operation you must modify the descriptor settings to give host access to this region.
If you updated to 10.0.47.1006, that has a VCN of 4 so you cannot downgrade to anything lower with FWUpdate, thus the error. Also the locked flash descriptor (error 26) means that you cannot reflash the entire ME Region as extracted from the Lenovo SPI image. You still haven’t mention what the problem is. It’s probably not ME related, especially if MEInfo and MEManuf do not report any issues. Check the first post on how to run them and verify that.
After upgrade to 10.0.47.1006 LP laptop switch off sometimes without any issue, USB are blocked that’s why I want downgrade. MEManuf passed.
C:\Intel\MEInfo\Windows64>meinfowin64
GBE Region does not exist.
Intel(R) ME code versions:
BIOS Version: A6CN56WW
MEBx Version: 0.0.0.0000
Gbe Version: Unknown
VendorID: 8086
PCH Version: 3
FW Version: 10.0.47.1006 LP
MEI Driver Version: 11.0.0.1181
Wireless Hardware Version: Not Available
Wireless Driver Version: Not Available
FW Capabilities: 0x51101A40
Intel(R) Capability Licensing Service - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
TLS: Disabled
Last ME reset reason: Power up
BIOS Config Lock: Enabled
Host Read Access to ME: Disabled
Host Write Access to ME: Disabled
SPI Flash ID #1: EF4017
SPI Flash ID VSCC #1: 20252025
SPI Flash BIOS VSCC: 20252025
OEM Id: 00000000-0000-0000-0000-000000000000
Capability Licensing Service: Enabled
OEM Tag: 0x00000000
Localized Language: Unknown
Independent Firmware Recovery: Enabled
Keybox: Not Provisioned
OEM Public Key Hash (FPF): 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash (ME):
ACM SVN FPF: 0x0
KM SVN FPF: 0x0
BSMM SVN FPF: 0x0
FPF ME
Force Boot Guard ACM: Disabled
Protect BIOS Environment: Disabled
CPU Debug Disabled: Disabled
BSP Initialization Disabled: Disabled
Measured Boot: Disabled
Verified Boot: Disabled
Key Manifest ID: 0x0
Enforcement Policy: 0x0
Updating the ME firmware via FWUpdate does not change any system settings which could in turn cause instabilities. If MEInfo does not show any red errors, MEInfo -verbose does not show “ME Filesystem: corrupted” and MEManuf reports “Operation Passed” then the problem is usually not ME related. The problems you list could be software, BIOS or hardware related in case for example the system turns off because of overheating or similar. Downgrading the ME firmware now is not possible via FWUpdate due to the increased VCN number and the flash descriptor lock won’t allow full region reflashing. Besides, based on past experience, downgrading it would have probably achieved nothing different as any hypothetical corrupted settings would not be altered by such an action. In your case, downgrading is not possible without external usage of a programmer or the pinmod method. The latter is useful to temporarily circumvent the flash descriptor lock but physical access and sorting of two pins of the sound chip of the machine is required upon bootup for that to activate. This system shut down, does it happen every 30 minutes or randomly? Any pattern? What is a “blocked” usb port?
Although I don’t believe the problem is ME-related, the truth is you cannot downgrade without a programmer or physical access to the sound chip via the pinmod method. I suggest you try the more likely suspects such as BIOS or platform settings. This is what I suggest:
1. Reflash the latest BIOS from Lenovo.
2. At first boot, enter BIOS menu and reset settings to default.
3. Once booted, run Flash Programming Tool with command fptw -greset and let the platform reset.
If indeed the problem is something temporary with the ME, the -greset command should fix it by resetting it.
Thanks for your reply so I will wait for newest ME for my platform and looking for the reason of my problems in other place.
Sorry for beeing late, this is the log for the built-in BIOS-Version (1.32) before I upgraded to the latest ME-Firmware
MEInfo -verbose Log:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
Intel(R) MEInfo Version: 11.0.0.1202
Copyright(C) 2005 - 2015, Intel Corporation. All rights reserved.
FW Status Register1: 0x94000245
FW Status Register2: 0x09F60506`
FW Status Register3: 0x00000300
FW Status Register4: 0x00084000
FW Status Register5: 0x00001F43
FW Status Register6: 0x47C00BC9
ManufacturingMode: Disabled
OperationalState: CM0 with UMA
InitComplete: Complete
ErrorCode: No Error
ModeOfOperation: Normal
Phase: ROM/Preboot
PhaseStatus: AFTER_SRAM_INIT
FPF and ME Config Status: Match
FW Capabilities value is 0x3DFE5947
Feature enablement is 0x1DFE5947
Platform type is 0x42221428
No Intel vPro Wireless device was found
Intel(R) Manageability and Security Application code versions:
Windows OS Version : 6.2.9200 ""
Table Type 218 ( 0x DA ) found, size of 251 (0x FB ) bytes
Table Type 218 ( 0x DA ) found, size of 191 (0x BF ) bytes
Table Type 218 ( 0x DA ) found, size of 65 (0x 41 ) bytes
BIOS Version 1.3.2
Table Type 4 ( 0x 04 ) found, size of 48 (0x 30 ) bytes
Table Type 14 ( 0x 0E ) found, size of 8 (0x 08 ) bytes
Table Type 15 ( 0x 0F ) found, size of 35 (0x 23 ) bytes
Table Type 17 ( 0x 11 ) found, size of 40 (0x 28 ) bytes
Table Type 25 ( 0x 19 ) found, size of 9 (0x 09 ) bytes
Table Type 130 ( 0x 82 ) found, size of 20 (0x 14 ) bytes
Table Type 131 ( 0x 83 ) found, size of 64 (0x 40 ) bytes
MEBx Version found is 11.0.0.0005
MEBx Version 11.0.0.0005
GbE Version 1.5
Vendor ID 8086
PCH Version 31
FW Version 11.0.0.1197 H
LMS Version Not Available
MEI Driver Version 11.0.0.1166
Wireless Hardware Version Not Available
Wireless Driver Version Not Available
FW Capabilities 0x3DFE5947
Intel(R) Active Management Technology - PRESENT/ENABLED
Service Advertisement & Discovery - NOT PRESENT
Intel(R) NFC Capabilities - NOT PRESENT
Intel(R) Platform Trust Technology - PRESENT/DISABLED
Intel(R) AMT State Enabled
TLS Enabled
Last ME reset reason Global system reset
Local FWUpdate Enabled
BIOS Config Lock Enabled
GbE Config Lock Enabled
Get flash master region access status...done
Host Read Access to ME Disabled
Host Write Access to ME Disabled
Get EC region access status...done
Host Read Access to EC Disabled
Host Write Access to EC Disabled
Protected Range Register Base #0 0x0
Protected Range Register Limit #0 0x0
Protected Range Register Base #1 0x0
Protected Range Register Limit #1 0x0
Protected Range Register Base #2 0x0
Protected Range Register Limit #2 0x0
Protected Range Register Base #3 0x0
Protected Range Register Limit #3 0x0
Protected Range Register Base #4 0x0
Protected Range Register Limit #4 0x0
SPI Flash ID 1 C22018
SPI Flash ID 2 Unknown
BIOS boot State Post Boot
OEM ID 68853622-xxxx-xxxx-xxxx-xxxxxxxxxxxx
Link Status Link Down
System UUID 4c4c4544-xxxx-xxxx-xxxx-xxxxxxxxxxxx
MAC Address 64-00-6a-xx-xx-xx
IPv4 Address 0.0.0.0
IPv6 Enablement Disabled
Privacy/Security Level Default
Configuration State Completed
Provisioning Mode PKI
Capability Licensing Service Enabled
OEM Tag 0x00000000
Slot 1 Board Manufacturer 0x00001028
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
M3 Autotest Enabled
C-link Status Disabled
Wireless Micro-code Mismatch No
Wireless Micro-code ID in Firmware 0x24F3
Wireless LAN in Firmware Intel(R) Dual Band Wireless-AC 8260
Wireless Hardware ID No Intel WLAN card installed
Wireless LAN Hardware No Intel WLAN card installed
Localized Language English
Independent Firmware Recovery Disabled
EPID Group ID 0xF8D
OEM Public Key Hash FPF A53EF0C1xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Retrieving Variable "OEM Public Key Hash"
OEM Public Key Hash ME A53EF0C1xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ACM SVN FPF 0x2
KM SVN FPF 0x0
BSMM SVN FPF 0x0
GuC Encryption Key FPF 0000000000000000000000000000000000000000000000000000000000000000
Retrieving Variable "GuC Encryption Key"
GuC Encryption Key ME 0000000000000000000000000000000000000000000000000000000000000000
FPF ME
Force Boot Guard ACM Enabled
Retrieving Variable "Force Boot Guard ACM Enabled"
Enabled
Protect BIOS Environment Enabled
Retrieving Variable "Protect BIOS Environment Enabled"
Enabled
CPU Debugging Enabled
Retrieving Variable "CPU Debugging"
Enabled
BSP Initialization Enabled
Retrieving Variable "BSP Initialization"
Enabled
Measured Boot Enabled
Retrieving Variable "Measured Boot Enabled"
Enabled
Verified Boot Enabled
Retrieving Variable "Verified Boot Enabled"
Enabled
Key Manifest ID 0xF
Retrieving Variable "Key Manifest ID"
0xF
Enforcement Policy 0x3
Retrieving Variable "Error Enforcement Policy"
0x3
PTT Enabled
Retrieving Variable "Intel(R) PTT Supported"
Enabled
PTT Lockout Override Counter 0x0
EK Revoke State Not Revoked
PTT RTC Clear Detection FPF 0x0
MEManuf -verbose Log:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
Intel(R) MEManuf Version: 11.0.0.1194
FW Status Register2: 0x090B0506
ErrorCode: No Error
Phase: ROM/Preboot
PhaseStatus: CALL_NEXT_MODULE
ME initialization state valid
ME operation mode valid
Current operation state valid
ME error state valid
OEM ICC data valid and programmed correctly
MFS is not corrupted
PCH SKU Emulation is correct
FPF and ME Config values matched
Request Intel(R) ME BIST status command... done
Get Intel(R) ME test data command... done
Total of 26 Intel(R) ME test result retrieved
Policy Kernel - Power Package : Live Heap Test - Passed
Common Services - LAN : Connectivity to NIC in M3 - Passed
Policy Kernel - Boot Guard : Self Test - Passed
Policy Kernel - Embedded Controller : Power source type - Passed
MCA - MCA Tests : Blob - Passed
MCA - MCA Tests : MCA Manuf - Passed
SMBus - SMBus : Read byte - Passed
MCTP - General : Connectivity to EC using SMT3 - Passed
VDM - General : VDM engine - Passed
GFX - General : Sampling engine - Passed
USBr - General : Storage - Passed
USBr - General : KVM - Passed
Common Services - LAN : Connectivity to NIC in M0 - Passed
AMT - KVM : Compression engine - Passed
AMT - KVM : Compare engine - Passed
Policy Kernel - ME Password : Validate MEBx password - Passed
Policy Kernel - ME Configuration : M3 Power Rails Available - Passed
Policy Kernel - ME Configuration : PROC_MISSING - Passed
Common Services - EHBC State : EHBC and Privacy Level states compatibility - Passed
Common Services - EHBC State : Valid Embedded Host Based Configuration (EHBC) state - Passed
Common Services - Privacy Level : Valid Privacy Level settings - Passed
AMT - Power : M3 power rail supported - Passed
AMT - Power : Valid LAN power well - Passed
Clear Intel(R) ME test data command... done
MEManuf Operation Passed
And this is the log generated after I flash the ME-Firmware to the latest version from Page1:
MEInfo
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
ErrorCode: No Error
Phase: ROM/Preboot
BIOS Version 1.3.2
GbE Version 1.5
Vendor ID 8086
PCH Version 31
LMS Version 11.0.0.1177
MEI Driver Version 11.0.0.1176
TLS Enabled
MAC Address 64-00-6a-8e-56-d9
OEM Tag 0x00000000
M3 Autotest Enabled
Localized Language German
EPID Group ID 0xF8D
ACM SVN FPF 0x2
KM SVN FPF 0x0
BSMM SVN FPF 0x0
FPF ME
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Key Manifest ID 0xF
0xF
0x3
PTT Enabled
Enabled
MEManuf
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
ErrorCode: No Error
Phase: ROM/Preboot
With both ME-Firmware-versions I have the described error.
Unfortunately I cannot downgrade the BIOS to 1.24. The Dell-BIOS-Flash-Tool wont let me do that.
I will report back if I have a PC running with the old (functioning) BIOS/ME-Firmware-Version and will post the logs here if necessary.
Just a thought...could I flash the ME-Firmware from the 1.24-BIOS to the 1.32-BIOS?
Intel Management Engine (ME) Firmware Version 11.0.1.1001 (S&H)(1.5Mo)
http://www.station-drivers.com/index.php…id=2064&lang=fr
Intel Management Engine (ME) Firmware Version 11.0.1.1001 (S&H)(5Mo)
http://www.station-drivers.com/index.php…id=2089&lang=fr
