Intel (Conv.Sec.) Management Engine: Drivers, Firmware and Tools (2-15)
Intel MEI v11.7.0.1027 for Corporate systems Drivers & Software
Updated first post.
I have a Asus Maximus Z270 Apex board.The last official Bios from Mar/17 had Me 11.6.0.1126 in it.I later did a me flash of me ver 11.6.29.3287 and all went fine.On the Asus Rog forum they released a Beta Bios this past week with a hyper thread fix that has me ver 11.7.0.1229 CON_H_D0 .I used the UBU Tool to check it and mod the new beta bios has me ver 11.7.0.1229 in it.I flashed the new modded beta bios and all went fine.Only thing was the me version in the bios is still on the one I flashed before ver 11.6.0.3287.Anyone have any idea why the me ver from the beta bios did not update.
@ NIK1:
Version Control Number (VCN)
ME Analyzer shows VCN 178…
How I can flash motherboards with socket 2066 and ME version 11.10? Will be FPT for 2066?
I have a Lenovo M800 Desktop PC i5-6400
i need full MEI/AMT software Package.
1. Intel MEI v11.7.0.1028 for Consumer systems Drivers & Software
2. Intel MEI v11.7.0.1027 for Corporate systems Drivers & Software
3. Intel MEI v11.0.6.1194 for Consumer systems Drivers & Software
4. Intel MEI v11.0.6.1194 for Corporate systems Drivers & Software
Which one is the correct one?
THANKS
Just want to inform about new Intel ME 8 1.5MB Firmware v8.1.70.1590 for 7-series:
- everything is fine on MSI Z77A-G43
- update 100% complete without any issues
- memanuf tests all ok
Thanks!
Intel ME 11.0 Consumer PCH-H Firmware v11.0.25.3001 (EXTR → RGN)
Intel ME System Tools v11.6 r15
Hallo,
thx for your thread - it is very interesting for me as beginner.
My Prob is, that my Acer Notebook V5-473g don’t wake up behind sleep under Win10.
After searching the web i came up with deactivate the “Intel management engine interface”. All is fine but this was not the solution i wish. Then I read somewhere (Kaijun/Acer-V5-573G-Hackintosh) that it could be solved with changing the Intel ME firmware.
After reading some text passages in your thread iI have collect some Info’s with recommended tools like:
Intel ME System Tools v9.5 r3
- MEManuf: test passed without errors
- MeInfo
Intel(R) MEInfo Version: 9.5.35.1850
Copyright(C) 2005 - 2014, Intel Corporation. All rights reserved.
GBE Region does not exist.
Intel(R) ME code versions:
BIOS Version: V2.30
MEBx Version: 0.0.0.0000
Gbe Version: Unknown
VendorID: 8086
PCH Version: 4
FW Version: 9.5.3.1520 LP
FW Capabilities: 0x11111A60
Intel(R) Anti-Theft Technology - PRESENT/ENABLED
Intel(R) Capability Licensing Service - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
TLS: Disabled
Last ME reset reason: Power up
Local FWUpdate: Enabled
BIOS Config Lock: Enabled
Host Read Access to ME: Disabled
Host Write Access to ME: Disabled
SPI Flash ID #1: EF4015
SPI Flash ID VSCC #1: 20252025
SPI Flash ID #2: EF4016
SPI Flash ID VSCC #2: 20252025
SPI Flash BIOS VSCC: 20252025
BIOS boot State: Post Boot
OEM Id: 00000000-0000-0000-0000-000000000000
Capability Licensing Service: Enabled
OEM Tag: 0x00000000
Localized Language: Unknown
Independent Firmware Recovery: Disabled
OEM Public Key Hash (FPF):
OEM Public Key Hash (ME):
ACM SVN FPF: 0x0
KM SVN FPF: 0x0
BSMM SVN FPF: 0x0
FPF ME
Force Boot Guard ACM: Disabled
Protect BIOS Environment: Disabled
CPU Debug Disabled: Disabled
BSP Initialization Disabled: Disabled
Measured Boot: Disabled
Verified Boot: Disabled
Key Manifest ID: 0x0
Enforcement Policy: 0x0
ME Analyzer v1.16.3 (FwUpdLcl.efi -save FW_old.bin)
File: FW_old.bin
Family: ME
Version: 9.5.3.1520
Release: Production
Type: Update
SKU: 1.5MB
SVN: 1
VCN: 2
PV: Yes
Date: 2013-05-08
Platform: LPT-LP
Latest: No
I think, that i can flash my “ME” with only:
1
2
3
fw = "9.5.60.1952_1.5MB_PRD_RGN.bin"
FwUpdLcl.efi -f fw
My System:
Notebook: Acer V5-473g
OS: Win10 (v. 1703; Build 15063.483)
Boot HD: Samsung SSD 840 EVO 250 GB mSATA
Data HD: TOSHIBA MQ01ABF050
extra Wlan/BT: Intel Dual Band Wireless-AC 7260
Video Chipset 1: Intel HD Graphics 4400
Video Chipset 2: NVIDIA GeForce GT 750M
Think i correctly, any suggestions or tips?
ReinRalle
I put a new mb in my nephews pc yesterday a MSI Z270 GAMING M3 and tossed the Asus BM250 board .In the bios it shows ME ver 11.6.1.1142…What version should I flash for a update .Also what is the intel software guard extensions SGX platform drivers do.
@ ReinRalle:
Make sure you have the latest v11.0 INF/MEI-Only driver installed from the first post.
Hi plutomaniac,
thank you for your hint.
What I found their is this: “Intel MEI Driver v11.0.6.1194 MEI-Only Installer”, correct?
Correct
plutomaniac: thx for your confirmation. All is running as I expected .
The only thing, that i don’t understand is:
After burn firmware, reboot and installing “Intel MEI Driver v11.0.6.1194 MEI-Only Installer” my “driver manager” under Win10 shows me for the “Intel(R) Management Engine Interface” a version “11.0.5.1189”. Is this a “fall back” and then: why?
ReinRalle
Read the first post carefully
Is this the key sentences: A newer Drivers & Software package has newer Software but the actual MEI driver may still be an older version? I think so…mea culpa…my initial problem seems to be solved .
Many thx und a nice evening from Germany…
ReinRalle
Is there any information about the difference between fw 11.6 and 11.7? Is that even something a user would notice? (like does anyone even know what MEI does on a system with non-corporate chipset with all those remote access stuff and other features?)
Hi,
Was wondering if any of the gurus here know how to transplant the ME Region from an OEM bios ver 3002 lets say onto the same OEM bios ver 902?
For example I used UEFITool to save the "ME Region" using "Extract as is" from my 3002 bios and then used "Replace as is" of the "Me Region" of the 902 bios
transplanting that 3002 ME region. Saved the file with out error.
Will that work??
Furthermore lets say I want to include a newer ME from the ME repository into my modded bios file for sharing how would I do that? Suppose I would have to use the FIT tool?
Thanks.
If they’re both from the same motherboard model, then yes. Make sure the region size is the same, otherwise manually append padding.
[Guide] Clean dumped or extracted Intel Engine region images of Initialization data
Thanks was reading that page this morning and responded to that thread with a few questions if anyone can take a look. Thank you.
