Intel (Conv.Sec.) Management Engine: Drivers, Firmware and Tools (2-15)
It is under beta.
http://www.asrock.com/mb/Intel/Z87%20OC%20Formula/?cat=Beta
Ohh,yes thanks.
GB B85 series is also updated with ME firmware 9.1.0.1035…
ftp://download.gigabyte.ru/bios/mb_bios_ga-b85tn_f4.zip
New Asrock beta bios L2.72 for Z87 Extreme 4 released - that fixed the PCIe clock / BCLK / FSB problem - with 9.1 ME firmwares.
http://66.226.78.22/downloadsite/bios/11…4(L2.72)ROM.zip
New Asrock beta bios L2.73 for Z87 Extreme 4 released - more fixes for ME firmware 9.1.x
http://66.226.78.22/downloadsite/bios/11…4(L2.73)ROM.zip
Hi
I guess I learnt something “again” and Fernando is one of the good guys on the net, you know one when you search for something always pops up and when he does always has the highest of standards info. Thank you
I did not realize that their is firmware in my firmware
Intel(R) MEInfo Version: 9.0.21.1452
Copyright(C) 2005 - 2013, Intel Corporation. All rights reserved.
Intel(R) ME code versions:
BIOS Version: 1402
MEBx Version: 0.0.0.0000
Gbe Version: 1.3
VendorID: 8086
PCH Version: 4
FW Version: 9.0.2.1345 H
LMS Version: 10.0.0.1180
MEI Driver Version: 10.0.0.1204
Wireless Hardware Version: Not Available
Wireless Driver Version: Not Available
FW Capabilities: 0x01101940
Intel(R) Capability Licensing Service - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
TLS: Disabled
Last ME reset reason: Power up
Local FWUpdate: Enabled
BIOS Config Lock: Enabled
GbE Config Lock: Enabled
Host Read Access to ME: Disabled
Host Write Access to ME: Disabled
SPI Flash ID #1: EF4017
SPI Flash ID VSCC #1: 20252025
SPI Flash BIOS VSCC: 20252025
BIOS boot State: Post Boot
OEM Id: 00000000-0000-0000-0000-000000000000
Capability Licensing Service: Enabled
OEM Tag: 0x00000000
Localized Language: Unknown
Independent Firmware Recovery: Disabled
Should I have any problems going from my OLD firmware to Intel ME9 1.5MB FWUpdate v9.0.31.1487.
Should I down clock first? Asus Maximus Hero VI @4.7 stable for 1 year +. (reset to defaults?)
Sorry for not reading a messily 26 pages, summer and outside a lot. I will catch up.
Regards
@ Shayne:
Welcome at Win-RAID Forum!
No, this should be safe (unless the power will be switched off while flashing).
If I were you, I would do it and redo the OC settings once having successfully rebooted.
Good luck!
Fernando
Thank you sir your quick reply it is much appreciated.
BIOS Version: 1402
Gbe Version: 1.3
VendorID: 8086
PCH Version: 4
FW Version: 9.0.31.1487 H
TLS: Disabled
OEM Tag: 0x00000000
Best Regards
Hi, I am new to this forum
MY system :
R4BE 4930K, Bios 701
Before update the ME firmware, Meinfowin64 shows:
Host Read Access to ME : Enabled
Host Write Access to ME : Enabled
After updated ME firmware to 8.1.52.1496 with FWUpdLcl64, Meinfowin64 shows:
Host Read Access to ME : Disabled
Host Write Access to ME : Disabled
How to change back to enable?
@ felix2014:
Since I don’t know the answer myself, I hope, that you will get an instruction from anyone else, who is more familiar with the Intel ME settings.
Regards
Fernando
It’s interesting to see that ordinary ME update changed descriptor lock settings for ME region, but this new setup is actually better. No need to change anything.
The answer for original question: you need to disable Intel descriptor lock either by using external SPI flasher or by performing a HDA chip pinmod during boot. Both methods are dangerous and needed only if ME region is corrupted and needs a complete reflash.
Does this affect future ME firmware update or bios update?
No, if this updates will be done by normal vendor’s tools.
Thanks
Caught up, a few questions to the ones that are in the know.
There appears to be not much on what versions are better as Rst(e) or many other driver/firmwares. We must assume latest is better for all?
The reason I even stubble on the firmware in bios was that 1505 bios from asus recommend an update to run the new 4th and it was windows based. I read this was 9.0.30.1482 ime firmware . I installed your package 9.0.31.1487. Would 30 be better, worse, same for my hero vi board? Change logs would be gr8 on OP. But I also have google just appears to have limited hits, still need to read CodeRush’s hard forum.
A brief idea of the exact differences in 9.0, 9.1, 9.5 would be helpful. I understand that some 87 boards are running 9.1 but have a hard time downgrading, What about 9.5?
Are 87 board 9.0 that’s it?
I feel the placebo that my baby is smoother and more in tune, feeling better inside now .
Thankz again
Regards
P.S. Is there a search button in threads?
No!
1. General pre-condition: The latest driver/firmware/OROM etc. has been designed for your specific system.
2. Even the latest suitable driver/firmware, OROM etc. is not always the best.
Generally it seems so, but some mainboard manufacturers obviously have opened the door to the Intel ME firmware v9.1 for some Z87 chipset boards.
No, the search field is valid for the complete Forum (which is good, because not all posts are within the best suitable thread or sub-Forum).
so asus releases 9.0.30.1482 for my board, would this be preferred to 9.0.31.1487. I will call it quits at 9.0 and buy a new board for future.
You cannot bubble through threads and point directly to post you are looking for, this is a bit of a handicap that must lead to addition posts/questions, no?
Regards
This is due to the Forum software, which has not been made by me. My administration console doesn’t allow any change regarding the search function.
Absolutely no problems, was just trying to understand GBE 1.3 and 1.5 and search was not that gr8, answered on the first page which was helpful not to have to read all again.
What would be really appreciated is your thoughts on
so asus releases 9.0.30.1482 for my board, would this be preferred to 9.0.31.1487?
Regards
No, because v9.0.31.1487 is newer and compatible with your mainboard.
ASUS does not always offer the newest stuff for their mainboards.
