@ppdemo
Oh, I recommend a system monitoring software aida64 to you. You can download the portable ZIP package version on its website.
https://www.aida64.com/
According to the options in the picture, you can see the ME firmware version you want to know
Intel CSME 14.0 Consumer PCH-LP A Firmware v14.0.31.1120
Intel CSME 14.0 Corporate PCH-LP A Firmware v14.0.31.1120
Intel PMC CMP PCH-LP A Firmware v140.1.01.1008
Intel CSME System Tools v14 r1 - (2020-03-21)
Hi guys,
Got an Asus Z270-WS which I coffeelake modded last year and now trying to reset to stock by upgrading bios to stock newer version firmware and using appropriate cpu for the motherboard. Problem was that after bios flash via bios the ME version was still 11.7. So I used CSME Tools to manually flash to latest ME version available and that worked. MeInfo and HWinfo showing 11.8 ME firmware but according to Meinfo LMS version says 11.7?? Is that an issue? Whats LMS?
Thanks
LMS is the abbreviation for Local Manageability Service and part of the Intel ME Drivers & Software Sets. For details please read >this<.
Here are the properties of the tool LMS.exe as part of the "Intel MEI Drivers & Software Consumer v11.7.0.1069", which is offered within the start post of this thread (Chapter A1):
@plutomaniac
DriverVer = 12/25/2019,1952.14.0.1470
Included in intel_mei_amt_2012.14.0.1517 packageā¦
Note to everyone, the current FWUpdate instructions do not work for CSME 13-14. Will add whatās needed on Monday probably.
Hello.
I found interesting ME firmware in imac 19,1 or imac 2019 model that firmware is around 1MB not 1.5 or 5mb, the board that is using is intel Q370 reported by CPU-z and aida64
I have attacked copy of it extracted, if you wanna look.
https://drive.google.com/open?id=1Q-IlBKā¦ZL2RgkOZDTfV7bI
Me update in FITC need to update ? any useful ?
Why not capable many technologiesā¦
Thank you!
EDIT by Fernando: Inserted picture resized (to save space), can be easily enlarged by clicking onto it
Hi Gents,
I recently ran into the infamous me fw update failed on an Asus Zenbook Pro N501VW.
I read the first post with all the instructions and attempted to check the version of ME used by this laptop based on the chipset. It looks like it is using Version V11.0.0.1169.
However, this information was not obtainable using the tools in this post. I just had to do some digging into the Chipset and Drivers based on Asus.
I assume that ME is completely corrupted. Iāve attempted to re-flash the BIOS but Iāve now come to know that ME updates are a total different beast and are not reversible through BIOS Update/Downgrade.
Additionally -
Because the system cannot recognize the ME Version it will not let me install any accurate version of ME.
What can I do in this situation? Needless to say, this laptop is way out of warranty. But it works fine otherwise.
Thank you!
Added Platform Controller Hub Configuration (PCHC) firmware for CSME 13+
Added CSME v13 - v14 FWUpdate requirements & image build procedure
Note: ME Analyzer v1.110.0 or newer is required for CSME 13-14 firmware
Intel CSME 13.0 Consumer PCH-LP A Firmware v13.0.21.1319
Intel CSME 11.22 Corporate PCH-H B,A Firmware v11.22.77.1664
Intel CSME 11.12 Consumer PCH-H A Firmware v11.12.77.1664
Intel CSME 11.12 Corporate PCH-H A Firmware v11.12.77.1664
Intel CSME 11.8 Consumer PCH-H D,A Firmware v11.8.77.3664
Intel CSME 11.8 Corporate PCH-H D,A Firmware v11.8.77.3664
Intel PMC ICP PCH-LP D Firmware v130.1.30.1048
Intel PMC ICP PCH-N B Firmware v130.3.10.1030
Intel PCHC CMP PCH-H/LP Firmware v14.0.0.7001
Intel PCHC ICP PCH-H/LP/N Firmware v13.0.0.1004
Intel CSME System Tools v11 r30 - (2020-04-01)
Great, this version allows overclocking, unlike the 3660.
Intel CSME System Tools v11 r30 - (2020-04-01) -> FWUpdate (LINUX64): 11.8.77.3665 -> Intel CSME 11.8 Consumer PCH-H D,A Firmware v11.8.77.3664
Is it OK to flash v11.8.77.3664 with FWUpdate 11.8.77.3665?
So far I have flashed in Linux only with identical versions.
I just did on a Z170 board, working fine so far.
thanks ,. v11.8.77.3664 work fine
gt75 7re
I think it would be useful if those doing the upgrade would also specify the version of FWUpdate used (eg the version for Windows, Linux, EFI).
I would like to know if anyone has managed the upgrade in Linux remote via ssh. Under the current conditions SARS-CoV-2 (COVID-19) we can not always get in front of the Linux console!
CSME 11 Tools r30 Linux64 on Ubuntu 19.04 x64 via SSH, no issues.
Copyright(C) 2005 - 2019, Intel Corporation. All rights reserved.
Driverless mode
Intel(R) ME code versions:
BIOS Version
MEBx Version
GbE Version 0.7
Vendor ID 8086
PCH Version 31
FW Version 11.8.77.3664 H
Security Version (SVN) 3
MEI Driver Version Not Available
Wireless Hardware Version Not Available
Wireless Driver Version Not Available
infoā¦
CSME 11 Tools r30 ,win1909 ,.build753 ,uefi
icc now is back ,on older is icc locked "not save any change" ,on msi bios show freq -80mhz last two fw .,now all ok
Thank you gentlemen it is much better so especially for those with critical systems.
Intel CSME 14.0 Consumer PCH-H A Firmware v14.0.32.1123
Intel CSME 12.0 Consumer PCH-H B,A Firmware v12.0.64.1551
hello please
is there any interaction between ME fw and notebook EC? or ME controls power management on 11.8 fw???
I use the latest 11.8.77 fw and everything is different now, I also updated windows ,
but my long term oc doesnāt need offset? c states now are unstable āactive ocā ,.probably not working on old fw
is this all possible? or does it make new windows core drivers ,setup ???
also i had some fw., bug in msi bios show cpu freq -80mhz 45x 4422mhz, now all ok
