Intel (Conv.Sec.) Management Engine: Drivers, Firmware and Tools (2-15)
Intel CSME 14.5 Consumer PCH-V A Firmware v14.5.12.1111
Intel ME 9.1 1.5MB Firmware v9.1.40.1000
Intel PMC CMP PCH-V A Firmware v140.1.00.1005
Intel PCHC CMP PCH-V Firmware v14.5.0.1001
Intel CSME System Tools v14.5 r1 - (2020-05-03)
Intel CSME System Tools v14.0 r3 - (2020-05-03)
Intel CSME System Tools v12 r23 - (2020-05-03)
Intel CSME System Tools v11 r31 - (2020-05-03)
ME Analyzer v1.123.0 r194
You should update your version of ME Analyzer because an important bug was fixed and many other things are now improved.
Since these issues @gloobox sent me a working bios however my unique values were missing and Intel ME comes up as N/A.
I’m using FF editor to paste my unique values into the ROM that I flash with my programmer.
I also found a tool called MB/TXE injector.
With those two tools combined I am fully backup and running
@ass9411 :
Welcome to the Win-RAID Forum!
You can do what you want, but I always install just the matching "pure" Intel ME driver and never had a problem.
By the way - the Intel ME expert is plutomaniac and not me.
Regards
Dieter (alias Fernando)
@plutomaniac I don’t know if you can shed some light on this?
When I install the latest pure Intel MEI drivers I always get 3 extra software components in device manager (LMS, DAL and ICLS). For some reason the DAL always installs a driver through Windows Update even when I have disabled the auto installation of drivers through win update.
LMS and ICLS don’t do this so they just show as ā€˜Generic software components’ using a Microsoft driver:
Now I could update those with the lastest Intel releases from this package from station drivers for example: https://www.station-drivers.com/index.ph…id=4389&lang=en
But I would rather not have these software components at all, installing the correct Intel drivers will install all kinds of startup services as well which - given the purpose of Intel MEI - I really don’t need or want :slight_smile:
Older versions of Intel MEI didn’t seem to install these extra software components.
For clarification:
DAL = Dynamic Application Loader Host Interface
LMS = Management and Security Application Local Management
ICLS = Capability Licensing Service TCP IP Interface
What is your advise regarding this?
If you don’t want the extra software, check section A2 to install the INF only.
Hello,
I have this old Asus ZenBook UX31E with Intel QS67 chipset and latest BIOS.
It comes with ME v7.1.20.1111 and I’d like to update it to the latest.
If I understand correctly I need to use consumer 1,5 MB firmware to update, right? Which is v7.1.80.1214.
Is it possible to make a backup of my current firmware? Just in case something goes wrong, maybe I could flash it back.
Here is some info:
Intel(R) MEInfo Version: 7.1.50.1166
Copyright(C) 2005 - 2011, Intel Corporation. All rights reserved.
Platform stepping value is 5
FW Status Register1: 0x1E000245
FW Status Register2: 0x60000006
CurrentState: Normal
ManufacturingMode: Disabled
FlashPartition: Valid
OperationalState: M0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
ICC: Valid OEM data, ICC programmed
SMBIOS Table Data
Starting address: EBB60
Table Size in Bytes: 2863 ( 0xB2F )
Number of Table Entries: 79 ( 0x4F )
Virtual mapping of complete Table: 2 4kB Pages
Table Type 0 ( 0x 00 ) found, size of 24 (0x 18 ) bytes
SMBIOS Table Data
Table Type 2 ( 0x 02 ) found, size of 15 (0x 0F ) bytes
Table Type 3 ( 0x 03 ) found, size of 21 (0x 15 ) bytes
Table Type 4 ( 0x 04 ) found, size of 42 (0x 2A ) bytes
Table Type 7 ( 0x 07 ) found, size of 19 (0x 13 ) bytes
Table Type 126 ( 0x 7E ) found, size of 19 (0x 13 ) bytes
Table Type 8 ( 0x 08 ) found, size of 9 (0x 09 ) bytes
Table Type 9 ( 0x 09 ) found, size of 17 (0x 11 ) bytes
Table Type 10 ( 0x 0A ) found, size of 6 (0x 06 ) bytes
Table Type 12 ( 0x 0C ) found, size of 5 (0x 05 ) bytes
Table Type 21 ( 0x 15 ) found, size of 7 (0x 07 ) bytes
Table Type 32 ( 0x 20 ) found, size of 20 (0x 14 ) bytes
Table Type 1 ( 0x 01 ) found, size of 27 (0x 1B ) bytes
Table Type 11 ( 0x 0B ) found, size of 5 (0x 05 ) bytes
Table Type 16 ( 0x 10 ) found, size of 15 (0x 0F ) bytes
Table Type 17 ( 0x 11 ) found, size of 28 (0x 1C ) bytes
Table Type 20 ( 0x 14 ) found, size of 19 (0x 13 ) bytes
Table Type 19 ( 0x 13 ) found, size of 15 (0x 0F ) bytes
Table Type 129 ( 0x 81 ) found, size of 8 (0x 08 ) bytes
Table Type 130 ( 0x 82 ) found, size of 20 (0x 14 ) bytes
Table Type 131 ( 0x 83 ) found, size of 64 (0x 40 ) bytes
MEBx Version found is 1792.0.0.13824
Get ME FWU info command...done
Get ME FWU version command...done
Get ME FWU feature state command...done
Get ME FWU platform type command...done
Get ME FWU feature capability command...done
Get ME FWU OEM Id command...done
FW Capabilities value is 0x1101C60
Feature enablement is 0x1101C60
Platform type is 0x311
GBE Region does not exist.
Intel(R) ME code versions:
BIOS Version: UX31E.214
MEBx Version: 1792.0.0.13824
Gbe Version: Unknown
VendorID: 8086
PCH Version: 5
FW Version: 7.1.20.1111
UNS Version: Not Available
LMS Version: Not Available
MEI Driver Version: 11.0.5.1189
Wireless Hardware Version: Not Available
Wireless Driver Version: Not Available
FW Capabilities: 17833056
Intel(R) Active Management Technology - NOT PRESENT
Intel(R) Standard Manageability - NOT PRESENT
Intel(R) Anti-Theft Technology - PRESENT/ENABLED
Intel(R) Capability Licensing Service - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Get iCLS permit information command...done
Command response status indicates permit not found
Get iCLS CPU allowed feature information command...done
CPU Upgrade State: Upgrade Capable
Cryptography Support: Disabled
Last ME reset reason: Power up
Local FWUpdate: Enabled
Get flash lockdown status...done
BIOS and GbE Config Lock: Unknown
Get flash master region access status...done
Host Read Access to ME: Disabled
Host Write Access to ME: Disabled
SPI Flash ID #1: EF4016
SPI Flash ID VSCC #1: 20052005
SPI Flash BIOS VSCC: 20052005
Protected Range Register Base #0 0x0
Protected Range Register Limit #0 0x0
Protected Range Register Base #1 0x0
Protected Range Register Limit #1 0x0
Protected Range Register Base #2 0x0
Protected Range Register Limit #2 0x0
Protected Range Register Base #3 0x0
Protected Range Register Limit #3 0x0
Protected Range Register Base #4 0x0
Protected Range Register Limit #4 0x0
BIOS boot State: Pre Boot
OEM Id: 00000000-0000-0000-0000-000000000000
Get ME FWU OEM Tag command...done
OEM Tag: 0x00000000
Intel(R) MEManuf Version: 7.1.50.1166
ErrorCode: No Error
Get FWU info command...done
Get FWU version command...done
Get FWU feature state command...done
gFeatureAvailability value is 0x1
System is running on consumer/1.5M image, start Intel(R) ME Runtime Test
OEM ICC data valid and programmed correctly
Request Intel(R) ME test result command...done
vsccommn.bin was created on 04:35:50 08/08/2012 GMT
SPI Flash ID #1 ME VSCC value is 0x2005
SPI Flash ID #1 (ID: 0xEF4016) ME VSCC value checked
SPI Flash ID #1 BIOS VSCC value is 0x2005
SPI Flash ID #1 (ID: 0xEF4016) BIOS VSCC value checked
FPBA value is 0x0
No Intel Wireless device was found
Request Intel(R) ME Runtime BIST test command...done
Get Intel(R) ME test data command...done
Total of 11 Intel(R) ME test result retrieved
Micro Kernel - Blob Manager: Set - Passed
Micro Kernel - Blob Manager: Get - Passed
Micro Kernel - Blob Manager: Remove - Passed
Policy Kernel - SMBus: Read byte - Passed
Policy Kernel - Power Package: Package 1 supported - Passed
Policy Kernel - Power Package: Default package supported - Passed
Policy Kernel - ME Configuration: Wlan Power Well - Passed
Policy Kernel - ME Configuration: CPU Missing Logic - Passed
Policy Kernel - ME Configuration: M3 Power Rails Available - Passed
Policy Kernel - Embedded Controller: Get power source - Passed
Policy Kernel - Power Package: Live Heap Test - Passed
Clear Intel(R) ME test data command...done
MEManuf Test Passed
Yes the latest is ME 7 1.5MB and can be updated via FWUpdate tool. You cannot keep a backup due to the security properties of your system (locked access to ME firmware region) and UPD images generated by "FWUpdate -save" are useless.
Updated and It seems to be working fine. :slight_smile:
Thank you @plutomaniac
FW Status Register2: 0x76000006
ErrorCode: No Error
SMBIOS Table Data
SMBIOS Table Data
VendorID: 8086
PCH Version: 5
FW Version: 7.1.80.1214
BIOS boot State: Post Boot
OEM Tag: 0x00000000
ErrorCode: No Error
FPBA value is 0x0
MEManuf Test Passed
I don’t use the extra software, I always install just the INF files. That’s what I meant with ā€˜pure’ MEI drivers in my previous post.
Regardless the recent MEI INF drivers also install 3 software components and those are the ones I was referring to.
Same, if I install the MEI driver only (inf), I also have these 3 other devices in the device manager but with generic drivers
As much as having the right drivers, since they are available
The MEI INF package is already the bare minimum install. It includes only one actual driver (.sys) which corresponds to MEI. The rest are Control Panel placeholders, similar to Chipset INF.
For what they’re worth, release notes from 11.8.70.3626 to 11.8.77.3664 (https://download.lenovo.com/pccbbs/mobiles/n23rg13w.txt):
-(Fix) Fixed the following security vulnerabilities:
CVE-20200531, CVE-20200532,CVE-20200533,CVE-20200535,CVE-20200536,CVE-20200537,CVE-20200538,CVE-20200539,
CVE-20200540,CVE-20200545,CVE-20200594,CVE-20200595,CVE-20200596 and CVE-20208674.
-(Fix) Fixed an issue BSOD is observed when device guard is enabled.
-(Fix) Fixed an issue BSOD is observed when running WinPVT msc+Restart test.
-(Fix) Fixed an issue the system cannot establish TLS provision via Intel SCS ACU Wizard tool and a yellow bang
is shown on Intel? MEI Driver.
-(Fix) Fixed an issue Failure in tests Intel? MEManufEOL var-f vPro_config.xml and MEDisable_Config.xml.
@snixel @tistou77
Get a full release like: https://www.station-drivers.com/index.ph…id=4334&lang=en
Open with 7zip (or other extractor)
Install:
…\intel_mei_amt_2012.14.0.1517(station-drivers.com).exe\DAL_DCH_REL\DAL.inf
…\intel_mei_amt_2012.14.0.1517(station-drivers.com).exe\ICLS_DCH 64\iclsClient.inf
…\intel_mei_amt_2012.14.0.1517(station-drivers.com).exe\LMS_DCH_REL 64\LMS.inf
and all 3 software components will have a driver. But don’t ask me what they are usable for.
@Morku the last
@Fernando
Hi,
the link for "Intel MEI Drivers & Software Consumer v11.0.6.1194 (ME 7-8)" erroneously point to the download of v1828.12.0.1152.
@ale5000 :
Although I haven’t entered the broken Lenovo link myself, I have fixed the problem.
Good luck with the related Intel MEI driver software!
Thanks :slight_smile:
The installer complete correctly and the driver got installed but the LMS service is missing (I need it for ACUConfig).
The folder "C:\Program Files (x86)\Intel\Intel(R) Management Engine Components" exist but contains only a "Lang" folder, no executable.
I have remove and reinstalled, no changes.
I have also tried the repair option, no changes.
Is it bugged?
Corporate, not Consumer drivers
It is ME 8 Consumer driver.
I have been able to install it with the LMS service using this: dl.dell.com/FOLDER04469185M/5/Intel-Management-Engine-Components-Installer_C3VMM_WIN_11.0.6.1194_A02.EXE
Then I have been able to run this correctly (after installing SCS): ACUConfig.exe DisableClientControlMode
So problem solved, maybe the link can be useful for others.
LMS is part of AMT, thus Corporate drivers, not Consumer. If you had installed "Intel MEI Drivers & Software Corporate v11.0.6.1194 (ME 7-8)", you would have gotten it installed as well.
