Intel (Conv.Sec.) Management Engine: Drivers, Firmware and Tools (2-15)
Intel CSME System Tools v11 r36 - (2020-10-31) -> FWUpdate (LINUX64): 11.8.80.3762
Which to choose:
Intel CSME Firmware v11.8.80.3746 (CON H DA) -> 11.8.80.3746_CON_H_DA_PRD_RGN.bin
or
Intel CSME Firmware v11.8.81.3781 (CON H DA) -> 11.8.81.3781_CON_H_DA_PRD_RGN.bin
Can I expect problems if the version of Intel CSME Firmware is smaller than the version for FWUpdate?
Intel CSME 11.8 Corporate PCH-LP C YPDM Firmware v11.8.81.3781
@ ibsajc:
Choose the latest. No problem with FWUpdate.
INTEL-SA-00391 it is also mentioned here -> https://www.station-drivers.com/index.ph…id=4652&lang=en
Now its up! https://www.intel.com/content/www/us/en/…l-sa-00391.html
I wonder how often these updates come up meanwhile. Reading about the new Apple M1 approach makes me also wonder how long someone wants to mess with all these flaws in self built systems.
@ plutomaniac:
ME 14, dump from this thread, machine bricked after just reading? bios chips
After reading BIOS chips, Dell Latitude 3510 won’t start
ME 14.0.37.1165, built with FIT 14.0.11.1205 (updated?)
FIT 14.0.36.1158 can’t read image (used according to recommendation β€œFor Comet Lake H/LP systems which run CSME v14.0.20 or newer”)
FIT 14.0.11.1205 opens the image without complaining
MEA reads β€œunconfigured” and reports an unrecognizable format in MFS partition at 0x10700.
β•‘ ME Analyzer v1.173.0 r216 β•‘
β•‘ Family β”‚ CSE ME β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Version β”‚ 14.0.37.1165 β•‘
β•‘ SKU β”‚ Consumer LP β•‘
β•‘ Chipset Stepping β”‚ B, A β•‘
β•‘ File System State β”‚ Unconfigured β•‘
β•‘ Flash Image Tool β”‚ 14.0.11.1205 β•‘
Error: Skipped MFS partition at 0x107000, unrecognizable format!
β€œUnconfigured”, brick, and errors in FIT when opening dump would fit toghether just fine, but on the other hand this dump opens without any complaint in an older FIT version and does have a configuration.
Is this ME region really unconfigured, and has an MFS partition with an urecongnizable format or is this just a glitch in the Matrix?
Thanks in advance!
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
β•‘ test (1/1) β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Release β”‚ Production β•‘
β•‘ Type β”‚ Extracted β•‘
β•‘ TCB Security Version Number β”‚ 1 β•‘
β•‘ ARB Security Version Number β”‚ 7 β•‘
β•‘ Version Control Number β”‚ 3 β•‘
β•‘ Production Ready β”‚ Yes β•‘
β•‘ OEM Configuration β”‚ Yes β•‘
β•‘ FWUpdate Support β”‚ No β•‘
β•‘ Date β”‚ 2020-05-20 β•‘
β•‘ Size β”‚ 0x335000 β•‘
β•‘ Chipset Support β”‚ CMP-H/LP β•‘
β•‘ Latest β”‚ No β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
β•‘ Power Management Controller β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Family β”‚ PMC β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Version β”‚ 140.1.01.1010 β•‘
β•‘ Type β”‚ Independent β•‘
β•‘ Chipset SKU β”‚ LP β•‘
β•‘ Chipset Stepping β”‚ A β•‘
β•‘ TCB Security Version Number β”‚ 2 β•‘
β•‘ ARB Security Version Number β”‚ 2 β•‘
β•‘ Version Control Number β”‚ 0 β•‘
β•‘ Date β”‚ 2020-03-18 β•‘
β•‘ Size β”‚ 0x14000 β•‘
β•‘ Latest β”‚ Yes β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
β•‘ Platform Controller Hub Configuration β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Family β”‚ PCHC β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Version β”‚ 14.0.0.7001 β•‘
β•‘ Release β”‚ Production, Engineering β•‘
β•‘ TCB Security Version Number β”‚ 0 β•‘
β•‘ ARB Security Version Number β”‚ 0 β•‘
β•‘ Date β”‚ 2019-05-01 β•‘
β•‘ Size β”‚ 0x1000 β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
The CSE File System (MFS) is corrupted. It could explain the brick. MEA detects that and skips it to avoid a crash.
If the image was built with 4.0.11 then it probably needs to be opened with <= 4.0.11. The CSME firmware version is newer due to FWUpdate usage most probably.
Even if FIT does not show an MFS error, it cannot parse that corrupted mess so don’t trust it. If the MFS is corrupted then another healthy dump needs to be found, clean that and move the cleaned/configured ME Region manually using UEFITool or similar.
Thanks a lot!
Wasn’t aware of this logic in MEA, but it’s quote obvious that MEA considers ME β€˜unconfigured’ if it can’t read the configuration correctly. A nice feature would be a different marking in the β€˜File system state’ field like β€˜unclear’. That would describe the current state a little more consistent for the unexperienced.
Rebuild the ME with (probably corrupted…) settings with Fit 14.0.11, opens correctly in both FIT versions now, so this error hadn’t anything to do with FIT versions, but was caused by corrupt MFS partition.
Intel CSME 14.0 Consumer PCH-H A Firmware v14.0.46.1431
Such a thing exists already. When the MFS analysis starts but crashes midway, the File System State shows a red "Error" instead:
But if MEA cannot even detect the MFS as a valid File System, it skips it beforehand and shows that error message. In that case it does seem to show "Unconfigured" instead which is not wrong but I agree that it can cause confusion. I’ll see if I can make it show the red "Error" state as well in that case. Interesting observation/suggestion, thank you lfb6.
In this case, it is not just bad settings. The entire structure of the MFS is filled/mixed with garbage data. Another dump needs to be used for cleaning and then moving back.
Tried to update with this latest firmware, built the image as usual, as described, but when I try to update I get an error.
Error 639: Loader failed to verify manifest signature of PPHY.
Any ideas ?
That doesn’t make sense to me. PPHY is not a CSME 14.0 partition. Are you using the latest FWUpdate we have (14.0.45.1389) with the correct combination of firmware components?
Intel PMC CMP PCH-H A Firmware v140.2.01.1011
Intel PCHC CMP PCH-H/LP Firmware v14.0.0.1002
Yes, using all the latest, but the Intel PCHC CMP PCH-H/LP Firmware v14.0.0.7002 because…1002 gives some other error.
Good. On that same system, had you updated to the previous firmware version 14.0.45.1389 without a problem?
Yes, previously it worked perfectly, but I recall getting the same error when I tried to … overwrite the firmware with the one prebuilt by ASUS, same version, with allowsv argument.
The one the OEMs provide is the pre-stiched CSME+PMC+PCHC. There is no need to re-flash it. Aside from that, I don’t see anything wrong with the firmware or steps used. It could be a FWUpdate <= 14.0.45.1389 (tool) or CSME 14.0.45.1389 (firmware) bug. Run β€œFWUpdLcl64 -save upd.bin”. Also, if you have read access to the CSE region of the SPI/BIOS chip, run β€œfptw64 -me -d cse.bin”. Compress and attach/link to these files.
OK, I think I found the issue, but no idea what went wrong, where or how.
When I ran the "FWUpdLcl64 -save upd.bin" command I got the following errors :
Error 357: Restore Point Image was requested, but it is not allowed because CSE is in Recovery Mode.
Error 329: Restore Point Image Failure. Reboot may be required.
Then run MEInfo -verbose and MEManuf -verbose to check the state of the CSE. You might have a corrupted firmware or similar issue.
Thanks again! I’ve never seen that β€œError” message before- that’s what I meant! But as I wrote: It’d be a β€˜nice to have’, obviously this will not show up so often anyway.
Regarding β€˜cleaning’ with a corrupt MFS partition as base for configuration- I’m aware of that, possibly the whole dump contains errors. It was just curiousity if there was a version incompatibility in addition.
Here we go.
meinfo.txt (8.35 KB)
memanuf.txt (2.05 KB)
Nothing wrong in MEInfo and MEManuf. Either a system-specific issue or something between FWUpdate/CSE and that firmware. I can’t really explain it in any other way. Stay at 4.0.45 for now and try again once we have a newer FWUpdate and/or firmware available.
Even weirder is that I had the same error with the 4.0.45 firmware downloaded from ASUS, using the same FWUpdate version.
Some system specific (ASUS, BIOS) error then. I’m sure others will not be facing such a problem.
