Intel (Conv.Sec.) Management Engine: Drivers, Firmware and Tools (2-15)
Intel CSME 14.0 Corporate PCH-H A Firmware v14.0.46.1431
Intel CSME 13.0 Slim PCH-N B Firmware v13.0.40.1594
Intel CSME 12.0 Slim PCH-H B,A Firmware v12.0.70.1652
Intel CSME 12.0 Slim PCH-LP C Firmware v12.0.70.1652
Intel CSME 11.22 Slim PCH-H B,A Firmware v11.22.80.1734
Intel CSME 11.12 Slim PCH-H A Firmware v11.12.80.1734
Intel CSME 11.8 Slim PCH-H D,A Firmware v11.8.80.3746
Intel CSME 11.8 Slim PCH-LP C NPDM Firmware v11.8.80.3746
Intel PMC ICP PCH-N B Firmware v130.3.10.1032
I am not sure why this new v2036.100.0.1024 driver have slowed down my system a lot, like a lot, something with memory and I have suffered a lot of it, I rolled back to the older version 2035.15.0.1807, still using latest DAL and iCLS. I donā€™t install the LMS as it caused issues in my system
I have done an update with last firmware csm version, with fit I have load my bios image and load last me version for comet lake h, after mod with uni tool too i have flash the bios and I take a broken machine
Intel CSME Firmware v14.0.46.1431 (CON H A).rar this version give problem for update to my platform
Intel MEI Drivers & Software v2044.15.0.1951 MSI (Windows 7, 8, 10 <= 1703) this version is for win7 and win8 not compatible with windows 10
But they install and work (Windows 10), with this IMEI Driver version: 2040.100.0.1029
Hello!
can anyone help me to downgrade the ME firmware!? motherboard rog maximus xi gen BIOS 1302 I want to downgrade from 12.0.70.1652v3 to version 12.0.49.1534
I cannot do it myself without damaging the motherboard, I will be very grateful for the help
@foetopsy The first post of this thread covers upgrade and downgrade possibilities. Normal downgrade via Intel FWupdate tool dosnā€™t seem to be possible because of different SVN numbers, so you would either have to use a ME region of an earlier bios, or if none of the earlier bioses includes the desired version, youā€™d have to create a ME region in the same manner that you would clean one (see [Guide] Clean Dumped Intel Engine (CS)ME/(CS)TXE Regions with Data Initialization )
Regarding getting the ME region into the SPI/ bios chip: Itā€™s unclear for me 1) if this board does have an Asus flashback option and 2) if Asus flashback does flash the complete bios or just the bios region. If that doesnā€™t work youā€™d have to try the options to open the flash descriptor lock for the ME region or use a CH341 flasher.
In addition thereā€™s mentioned
I donā€™t know if this is the case for the Z390 chipset.
So thereā€™s a chance of things not working out and a good backup and a CH341 programmer at hand could be useful.
What makes you think you have to downgrade?
there is a flashback, it only flashes the BIOS, the performance is not satisfied
with your platform, but not with my platform, there are 2 folders, one folder is for win 7 and other with win 8 driver
I have laptop with a preproduction ME firmware. Just wondering whether there is a way to upgrade it to production. Any help is greatly appreciated!
What laptop are we talking about exactly? Do you have a SPI dump to compress and attach/link to, in order to verify that it is indeed PRE? You cannot change from PRE to PRD and vice versa.
@plutomaniac
Hey, so Iā€™m stumped on somethingā€¦
My System:
CPU - i9900K
Mobo - Asus WS Z390 Pro
I have only 1 remaining yellow Flag in my Device Manager;
-PCI Simple Communications Controller.
From what Iā€™ve read it is the Intel Management Engine Drivers.
I tried installing your Windows 7 IME Installer Driver; I get ā€œPlatform is not supportedā€. The Win 7 folder shows in the subcategory.
I also tried installing your standalone driver, through Device Manager browse, it did not find anything. The .inf and .sys files are in there.
Iā€™m not sure what Iā€™m doing wrong here.
Hardware IDs:
PCI\VEN_8086&DEV_A360&SUBSYS_86941043&REV_10
PCI\VEN_8086&DEV_A360&CC_078000
Intel MEI Drivers & Software v2044.15.0.1951 DCH (Windows 10 >= 1709)
Intel MEI Driver v2040.100.0.1029 (Windows 10 >= 1709)
@ Freeza:
The v15 MSI drivers support (CS)ME 10 & 11 under Windows 7, not 12. CSME 12 is additionally supported under Windows 8 & 10 <= 1709. You should look at older driver branches (v14 maybe) at Station-Drivers or similar which probably still supported CSME 12 under Windows 7.
@plutomaniac
Thank you for responding, but I did not try with those.
I tried installing these, without success:
Intel MEI Driver v2040.100.0.1029 (Windows 7)
This statement confused me a bit; as I am new to this information.
But what I got from that is, v14 or V12 may work for me.
v14 I found these:
https://ftp.station-drivers.com/index.phā€¦&id=624&lang=en
And these:
https://www.driveridentifier.com/scan/inā€¦8086%26DEV_A360
I noticed in the last link it identified v14 and a v12, which is exactly what you stated.
I did a rock, paper, scissors, and installed a random V14 and it corrected the PCI Simple Communications Controller Flag.
But my question is, which one of these should I actually use? or does it not matter?
I know. These were updated that day on the first post. It was a general announcement to everyone, not targeted to you.
You cannot use v15 drivers with that Platform/OS combination. The latest v14 drivers you can find at SD will work just fine. It doesnā€™t matter honestly, as long as you have a driver installed.
Hello
For Windows 10 2009, this MEI version must be used: Windows 10> = 1709 ?
I hadnā€™t paid attention, but with the latest version of the drivers, I had taken for W8 (TeeDriverW8x64.sys file)
Thanks
Yes
OK, thanks
Itā€™s weird, but with the previous version I donā€™t believe I had this TeeDriverW8x64.sys file (while I had always had it)
I will check
It is a Lenovo Thinkpad X1 Carbon Gen 7, but it is engineering model. The normal upgrade from Lenovo does notw work. The MEinfoWin64 shows that it is Pre-Production firmware. I hope there is some trick to bring it production firmware; otherwise, the Intel Audio driver does not work properly.
What CPU is it running? Show us the MEInfo -verbose output.
The CPU is an engineering model "Genuine Intel(R) CPU 0000 @1.6GHZ, 1800 Mhz, 4 Core(s), 8 Logical Processor(s)". It should be either "8th Generation IntelĀ® Coreā„¢ i5-8365U Processor with vProā„¢ (1.60 GHz, up to 4.10 GHz with Turbo Boost, 4 Cores, 8 Threads, 6 MB Cache)" or "10th Generation IntelĀ® Coreā„¢ i5-10210U Processor (1.60 GHz, up to 4.20 GHz with Turbo Boost, 4 Cores, 8 Threads, 6 MB Cache)" based on Lenovo retail version specs.
C:\DRIVERS\WIN\ME\20202211.16032862>MEInfoWin64.exe -verbose
Intel (R) MEInfo Version: 12.0.70.1652
Copyright (C) 2005 - 2020, Intel Corporation. All rights reserved.
Windows OS Version : 10.0
LPC Device Id: 9D84.
Platform: Cannonlake Platform
General FW Information
FW Status Register1: 0x90000255
FW Status Register2: 0x60000506
FW Status Register3: 0x00000030
FW Status Register4: 0x00004004
FW Status Register5: 0x00000000
FW Status Register6: 0x00400000
CurrentState: Normal
ManufacturingMode: Enabled
FlashPartition: Valid
OperationalState: CM0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
SPI Flash Log: Present
Phase: HOSTCOMM Module
PhaseStatus: UNKNOWN
ME File System Corrupted: No
FPF and ME Config Status: Not committed
FW Capabilities value is 0x7DF6D645
Feature enablement is 0x5DF6D645
Platform type is 0x42001441
Found an Intel vPro Wireless device
Platform Type Mobile
FW Type Pre-Production
Last ME Reset Reason Unknown
BIOS boot State Post Boot
Slot 1 Board Manufacturer 0x000017AA
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
Capability Licensing Service Enabled
Local FWUpdate Enabled
OEM ID 4C656E6F-766F-0000-0000-000000000000
Integrated Sensor Hub Initial Power State Enabled
Intel(R) PTT Supported Yes
Intel(R) PTT initial power-up state Disabled
OEM Tag 0x00
TLS Enabled
Intel(R) ME code versions:
BIOS Version N2HET51W (1.34 )
MEBx Version 12.0.0.0010
Vendor ID 8086
FW Version 12.0.20.1307 LP Corporate
LMS Version 2026.14.0.1682
MEI Driver Version 2013.14.0.1529
Wireless Hardware Version 2.1.77
Wireless Driver Version 21.110.1.1
IUPs Information
PMC FW Version 300.1.20.7021
OEM FW Version 1.0.0.0001
ISHC FW Version 5.0.0.3816
LOCL FW Version 12.0.20.1307
WCOD FW Version 12.0.20.1307
PCH Information
PCH Version 32
PCH Device ID 9D84
PCH Step Data D2
PCH SKU Type Pre-Production ES
PCH Replacement State Enabled
PCH Replacement Counter 0
PCH Unlocked State Disabled
Flash Information
SPI Flash ID 1 Not Available
SPI Flash ID 2 Not Available
Host Read Access to ME Not Available
Host Write Access to ME Not Available
Host Read Access to EC Not Available
Host Write Access to EC Not Available
FW Capabilities 0x7DF6D645
Intel(R) Active Management Technology - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Intel(R) Platform Trust Technology - PRESENT/DISABLED
Service Advertisement & Discovery - PRESENT/ENABLED
Persistent RTC and Memory - PRESENT/ENABLED
End Of Manufacturing
Post Manufacturing NVAR Config Enabled Yes
HW Binding Disabled
End of Manufacturing Enable No
Intel(R) AMT State Enabled
MAC Address e8-6a-64-6a-81-5e
IPv4 Address 0.0.0.0
IPv6 Enablement Disabled
Configuration State Not Started
Provisioning Mode PKI
M3 Autotest Disabled
Link Status Link Down
Wireless Micro-code ID in Firmware 0x9DF0
Wireless LAN in Firmware Intel(R) Wireless-AC 9560
Wireless Hardware ID 0x9DF0
Wireless LAN Hardware Intel(R) Wireless-AC 9560
Localized Language English
C-link Status Enabled
System UUID c7737e4c-269d-11b2-a85c-d01f3dfa868b
Wireless MAC Address 34-13-e8-7d-ca-7b
Wireless IPv4 Address 0.0.0.0
Wireless Micro-code Mismatch No
AMT Global State Enabled
Privacy/Security Level Default
Intel(R) Protected Audio Video Path
Keybox Not Provisioned
Attestation KeyBox Not Available
EPID Group ID 0x4DC
Re-key needed False
PAVP Supported Yes
Security Version Numbers
Minimum Allowed Anti Rollback SVN 4
Image Anti Rollback SVN 4
Trusted Computing Base SVN 1
FW Supported FPFs
FPF UEP ME FW
*In Use
ā€” ā€” -----
Enforcement Policy Not set 0x00 0x00
EK Revoke State Not set Not Revoked Not Revoked # Not Revoked=0, Revoked=1
PTT Not set Enabled Enabled # Disabled=0, Enabled=1
OEM ID Not set 0x00 0x00
OEM Key Manifest Present Not set Present Present # Not Present=0, Present=1
OEM Platform ID Not set 0x00 0x00
OEM Secure Boot Policy Not set 0x40 0x40
CPU Debugging Not set Enabled Enabled # Enabled=0, Disabled=1
BSP Initialization Not set Enabled Enabled # Enabled=0, Disabled=1
Protect BIOS Environment Not set Disabled Disabled # Disabled=0, Enabled=1
Measured Boot Not set Disabled Disabled # Disabled=0, Enabled=1
Verified Boot Not set Disabled Disabled # Disabled=0, Enabled=1
Key Manifest ID Not set 0x01 0x01
Persistent PRTC Backup Power Not set Enabled Enabled # Enabled=0, Disabled=1
RPMB Migration Done Not set Disabled Disabled # Disabled=0, Enabled=1
SOC Config Lock Not set Not Done Not Done # Not Done=0, Done=1
SPI Boot Source Not set Enabled Enabled # Enabled=0, Disabled=1
TXT Supported Not set Disabled Disabled # Disabled=0, Enabled=1
ACM SVN FPF Not set
BSMM SVN FPF Not set
KM SVN FPF Not set
OEM Public Key Hash FPF Not set
OEM Public Key Hash UEP 96ADDF2B3EE8AB406E89534931DA41BAEF5C3514F16EDC82C576A144AFF9625A
OEM Public Key Hash ME FW 96ADDF2B3EE8AB406E89534931DA41BAEF5C3514F16EDC82C576A144AFF9625A
PTT Lockout Override Counter FPF Not set
Thanks a lot!
EDIT by Fernando: Put the MEInfo details into a "spoiler" (to save space)
