Intel (Conv.Sec.) Management Engine: Drivers, Firmware and Tools (2-15)
Thanks! I successfully updated my Z170 with this firmware and FWUpd for 11.0.0.1168 as in the OP!
MSI Z170A Gaming m7 ME FW v11.0.0.1171 to v11.0.0.1178 update successfully
Thank you!
Intel(R)_ME10.0_1.5M_10.0.47.1006.zip
Thank you very much Wootever, that’s a great find.
Intel ME 10.0 Consumer 1.5MB Firmware v10.0.47.1006
Intel ME System Tools v10.0 r4:
Flash Image Tool v10.0.46.1002
Added 1.5MB FW Release Notes v10.0.47.1006 (HF)
Added BIOS 2014 CRB BIOS Release Notes v125
Intel ME 11.0 Consumer PCH-H Firmware v11.0.0.1178
worked for me as well, GA-Z170X-Gaming 7
Intel ME System Tools v11.0 r5:
Flash Programming Tool(DOS): 11.0.0.1178
Flash Programming Tool(EFI64): 11.0.0.1178
Flash Programming Tool(Windows): 11.0.0.1178
Flash Programming Tool(Windows64): 11.0.0.1178
Hi, plutomaniac!
My FW Version is 9.0.20.1447 but my platform is HM87+i7-4712 (Dell Precision M3800 Late 2013). Can I use Intel ME 9.5 Consumer 1.5MB Firmware v9.5.45.1922 to update FW from 9.0.x to 9.5.x ?
Thanks for your great post!
Hi plutomaniac, Can you please reupload "Intel ME 6 Firmware Repository Pack r8.rar" because it seems corrupted?
@ syscl:
No, as clearly stated at the first post, you can only update to latter v9.0 releases.
@ kevin:
1) Wrong thread
2) File is not corrupted, read the first post of the Repository thread
I apologise. Thanks it worked :slight_smile:
Thanks for reply!
But now when I type " FWUpdLcl64 -f ME.bin" or "FWUpdLcl64.bin -f ME.bin -allowsv", the program shows "Error 8745: Firmware update cannot be initiated because the OEM ID provided is incorrect", how can I flash the new ME into my computer?
@ syscl:
You have a Dell system so try adding their OEM ID with FWUpdLcl64 -f ME.bin -oemid 68853622-EED3-4E83-8A86-6CDE315F6B78
If that doesn’t work, run MEInfo and check your OEMID. If it’s not the one I mentioned above, please post a picture of MEInfo so that I can see and keep that new Dell OEM ID.
About RAR5 archives, 7-Zip 15.06 or higher can also be used.
Few questions
1. When do we use v9, v10, v11 drivers?
2. Can we use v11 drivers on v9.x/v10.x firmwares? So far it does seem like v11 installs fine on almost any board.
3. There’s 1.5MB and 5MB… what’s the difference? How do I even know which one’s right for me?
4. By applying firmware upgrades (ive never done before), what do I benefit from it?
Can any one say how flash back? to older verion.
F:\DOWN\ME\ME6\WIN>UpdLcl.exe 6.2.40.1045_5MB_MB_PRD_UPD.bin -generic -verbose
Intel (R) Firmware Update Utility Version 6.2.0.1022
Copyright (C) 2007-2011, Intel Corporation. All rights reserved.
Trying to connect to MEI driver.HECI driver version: 6.2.50.1050
***** Flash Info *
Version : 6.2.60.1066
Last Update Staus : 18
EnabledUpdateInterfaces : 1
Image Info ******
Version : 6.2.40.1045
Error 8705: Firmware update not initiated due to version mismatch
Very interesting where is also store info?
In BIOS and where else?
Because Full dumping BIOS from one laptop with Working vPro - and restore on other - vPro absent.
In first boot after Flashing (by programmer) in BIOS all is present AMT Option. After reboot is gray (((
@ biatche:
1-4: Read the first post of the thread. All answers to these questions are there.
@ Minzak:
You cannot downgrade ME6 firmware via FWUpdate. Only via a programmer if the flash descriptor is unlocked and after modifying the required firmware with FITC to adjust it to your system-specific settings.
@ all:
Old drivers moved to legacy section, post #2. Some text changes at drivers & 3 main ME Tools as well. The latter might be removed completely in the future leaving only the System Tools packages.
Intel ME System Tools v11.0 r6:
FWUpdate(Win64): 11.0.0.1173
MEInfo(Windows64): 11.0.0.1173
Has anyone flashed 11.0.0.1178 to their Skylake? Want to check before I do something as stupid as previously and then have to jump chips to be able to flash back to a working version (don’t ever want to do that again!).
You, works fine
Intel Management Engine: Drivers, Firmware & System Tools (112)
