Well make sure the driver is installed and that there us no yellow mark on the device at Device Manager. I guess you could also trying the ME9.0 FWUpdate.
OH, When I close the HWINFO.EXE, it success ā¦
how to give it to you ?
https://onedrive.live.com/redir?resid=62ā¦hint=file%2cbin
I can use only Microsoft Onedrive⦠Other canāt be used in China
@ lly007
Thank you for uploading a ME9.1 UPD image, much appreciated. And yes, running two programs that utilize the MEI driver at the same time will result in problems. Always disable everything in the background before flashing, especially monitoring, overclocking etc programs.
@Scamperor
Did you by any chance manage to create that UPD image from your B150 system using FWUpdLcl64 -save ME.bin command? Also, did that quick/dirty firmware ātransferā work?
The OP states:
Does that mean my P8Z77-V Pro MEI can actually be updated to MEI 9.0 Firmware without problems? I have 8.1 Firmware now.
BTW, you know ASUS provides a special METool for MEI Firmware flashing in their P8Z77-V Pro support section. It easily flashes within Windows. All you have to do is rename your Firmware file to DATA.bin, replace the old DATA.bin firmware file with the new one, and just run METool.exe. BUUUT⦠the tool worked fine for several firmware versions, but now it doesnāt. I get an error log with: "Error 8772: Invalid usage, -allowsv switch required to update the same version firmware" . I tried replacing the included "FWUpdLcl64.exe" and "FWUpdLcl.exe" with the latest versions from the latest Full Package ME System Tools, but that did not help anything. Any ideas on how to fix this?
If I understand, for Z170 the 1194 module is for BIOS replacement and the modded one is for FWUpdate, right?
@ MonarchX:
I donāt understand how you concluded that. It clearly states āIf your firmware is currently v9.0 [ā¦]ā. So no, you have 8.x and not 9.x.
That ASUS tool is useless, it just checks the os architecture and calls the appropriate FWUpdlcl tool. Nothing fancy. Use FWUpdate manually (how often do you actually update the ME?) or create a small batch script that calls it āautomaticallyā.
@ gpvecchi:
Yes, the modded is for FWUpdate whereas the ānormalā is for FIT/FPT use. Tests have shown that even using the modded image with FIT/FPT doesnāt cause problems but I urge you not to use the FWUpdate image for FIT/FPT use just in case.
Intel ME 11.0 Consumer PCH-LP Firmware v11.0.0.1191
Intel ME System Tools v11.0 r9:
FWUpdate(Win): 11.0.0.1191
FWUpdate(Win64): 11.0.0.1191
Hello again,
what ME drivers and firmware would be suitable for my good HP dv5 notebook.
Want to bring to life again with Win10 64Bit
HWInfo says: Intel PM45 (Cantiga-PM) + ICH9M (Base)
(G)MCH Features
Manageability Engine (ME): Supported
iAMT: Supported
ICH9 Features
Intel AMT Support: Not Supported
@ realmax:
Oh, ME4. Interesting. Alright, there were three possible firmware SKUs: AMT, TPM or AMT+TPM. Download the ME4 System Tools, run MEInfo and show us a picture. What DEV_ID does the Intel Management Engine Interface device report at Device Manager?
MEInfo says "unable to connect through HECI driverā¦"
I tried all ME driver major versions to install but none workedā¦
I think it is missing the intel driverā¦
at the moment it should be stock microsoft driverā¦
Also in device manager theres like no entry of ME⦠all devices are
installed correctly, no device which is not recognized so i canāt identify MEā¦!?
I made 2 screens of the systemdevices ⦠maybe you can identify it?
i checked if theres maybe sth disabled in bios, but no options here, if it would be possibleā¦
maybe theres no ME?
I canāt find it, maybe it has some generic name or similar. If Iām not mistaken, the DEV_ID should be one of the following:
VEN_8086&DEV_2A44
VEN_8086&DEV_2A54
VEN_8086&DEV_2A64
VEN_8086&DEV_2A74
Search all those Devices, something should pop up.
Thatās all I got:
PCI\VEN_8086&DEV_293E&SUBSYS_3603103C&REV_03\3&B1BFB68&0&D8
PCI\VEN_8086&DEV_2940&SUBSYS_3603103C&REV_03\3&B1BFB68&0&E0
PCI\VEN_8086&DEV_2942&SUBSYS_3603103C&REV_03\3&B1BFB68&0&E1
PCI\VEN_8086&DEV_2944&SUBSYS_3603103C&REV_03\3&B1BFB68&0&E2
PCI\VEN_8086&DEV_2946&SUBSYS_3603103C&REV_03\3&B1BFB68&0&E3
PCI\VEN_8086&DEV_2948&SUBSYS_3603103C&REV_03\3&B1BFB68&0&E4
PCI\VEN_8086&DEV_294A&SUBSYS_3603103C&REV_03\3&B1BFB68&0&E5
PCI\VEN_8086&DEV_2932&SUBSYS_3603103C&REV_03\3&B1BFB68&0&FE
PCI\VEN_8086&DEV_2919&SUBSYS_3603103C&REV_03\3&B1BFB68&0&F8
PCI\VEN_8086&DEV_2A41&SUBSYS_3603103C&REV_07\3&B1BFB68&0&08
PCI\VEN_8086&DEV_2A40&SUBSYS_3603103C&REV_07\3&B1BFB68&0&00
PCI\VEN_8086&DEV_2448&SUBSYS_3603103C&REV_93\3&B1BFB68&0&F0
PCI\VEN_8086&DEV_2930&SUBSYS_3603103C&REV_03\3&B1BFB68&0&FB
Howās the possibility that thereās no MEI at all in that thing?
Or maybe if you tell me which driver āinstallā I need, it then shows?
It may be that this model has AMT disabled so there is no firmware or operating system driver. What exact dv5 model is that? At Flash Programming Tool, run fptw -i command. What does it show? Are you able to run fptw -d spi.bin command (or fptw -d:spi.bin , not sure what is the correct way for these older tools)?
MEI.rar (924 KB)
Flash Programming Tool. Version 4.2.0.1017
Copyright (c) Intel Corporation. 2007-2009
PMXUtil: Error during PMX Call: sseidrvdll32e.dll!IDRVInstallDriver(): Failed to start loaded service err: 1275
Error 51: Initialization of PMX utilities failed. Unable to continue.
FPT.exe exited with return code: 51
Itās dv5-1142eg (German Model)
Oh, and the driver again refused to install, like my previous attempts,
says something like ārequirements not metā¦ā and aborts right away
Ok, as I suspected. That system doesnāt have AMT or iTPM. So thereās nothing you have to do as far as ME firmware and drivers are concerned.
Those old Windows versions of the tools donāt seem to work on newer operating systems. Personally I tested the DOS versions using DOSBox and these do run but of course I would only use that method for displaying info and not flashing. For flashing, an actual DOS environment is needed. If you want to see the fpt -i output then boot into dos and test it but Iām certain this system doesnāt have AMT support. Personally I wouldnāt mind seeing some pics from the dos MEInfo to be absolutely certain but 99% itās what Iām saying.
I think so too, that this one has been cut off MEIā¦
HP usually gives at least one MEI components download with the notebooks
in their support drivers/software are on their homepage.
But since this model already lacks of that download I would agree with
you that it hasnāt got this functionalityā¦
Iām currently running Win10 64 Bitā¦
Another question since Iām doing research on mod bios for this device.
Is it possible that MEI is kind of locked via BIOS/Software but the hardware
itself is available in the notebook?
So therefore a mod bios maybe could make it visible?
How are the chances for that? possible or not?
No, the chipset may be capable of AMT but the BIOS lacks any support for it including MEBx and other needed BIOS modules. Besides, even if you tried you would only end up bricking the system. Iāll stick to what I said before: nothing related to ME driver or firmware can be performed on that system. If you want at some point to run the tools of the ME4 System Tools package, remember to use them under native DOS and not Windows (at least for flashing). Thatās all really.
OK, so I will accept this one has no MEI and probably regardless to what
action it still wonāt get itā¦
Iām just curious the way they have done it at HP.
Just keep the āMEI hardwareā completely out of the notebook,
or put it in and kind of āsoftware-lockedā itā¦
Since warranty is over and I planned to dissassemble it to do some maintenance
like cleaning the cooling system from dust and new thermal grease I could at least
look for an MEI chip if it is a separate one which can be identified.
Or is it build into the chipset?
Itās built in the chipset, you canāt see it. Different chipsets had different capabilities built-in. Before ME6, it wasnāt obligatory to have the ME engine operational. At PCH and onwards it became part of the platform.
