Considering there is no going back from that, I rather not risk breaking more shit, the chipsets are different enough not to risk that sort of thing, Im trying to fix something not break more.
@plutomaniac I have HM77 Express Chipset on a DELL Laptop and i managed to update ME firmware to 8.1.65 in order to solve a problem of the yellow mark that appears on Intel Management Engine Interface in Windows 7 Device Manager along with Error Code 10 ( Device has failed to start ). First, i used FWUpdate tool with the latest firmware image but it gave me this error : Error 8193: Intel (R) ME Interface : Cannot locate ME device driver. Then, i used fptw64 with -greset and i shutdown the laptop and powered it back on after 1 hour but nothing has changed and i still have that yellow mark in Device Manager and the same error code 10 because ME firmware is still corrupted. I also tried to use fptw64 to dump the SPI.bin but i got error 26 so i would like to know how i can fix this error and upgrade the firmware to the latest version. The strange thing is, the problem of the yellow mark and error code 10 gets fixed after a restart but the problem occurs again after a cold boot. Whats the reason behind this ? Thanks in advance for the help.
No need to tag me, I monitor this thread regardless. Make sure you have the latest 11.0 driver from the first post and after a restart try updating the firmware again via FWUpdate. Otherwise try updating while in DOS or EFI environment.
Ok, I will install driver and try to update afterwards. BTW, could you tell me how to update while in DOS or EFI ? sorry to ask but iâm familiar only with Windows.
Is the 10.0.55.3000 compatible with consumer non-corporate type laptops? Didnât see it listed on the consumer list on the first page of this threadâŚ
It is fully compatible, the FIT SKU has nothing to do with compatibility. Only the actual firmware SKU has.
Are you sure about this, (dont take it personally I need to be sure beyond any doubt) if that is not right, there is no way back from that(except hw programmers and thats not possible). But if your 100% positive then Ill trust your word for it.
The other question is, flashing a ME FW doesnât seem to reset the recovery state, as last flash did nothing to correct my issue.
Intel ME System Tools v10.0 r2 Intel ME System Tools v9.5 r2
Updated the notice regarding INTEL-SA-00075/CVE-2017-5689 (found 11.6.29.3287 COR LP from Dell & 9.5.61.3012 5MB from HP & 6.2.61.3535 5MB DT from HP):
Updated the notice regarding INTEL-SA-00075/CVE-2017-5689 (found 6.2.61.3535 5MB MB from HP):
@ stefguer:
The "_x" at the end means that these are still in development versions, not yet released. The next versions will be released tomorrow or the day after. Thank you for your interest in MEA.
