Intel (CS) Management Engine: Drivers, Firmware and Tools (2-15)
@plutomaniac
Thanks for reply
Just tried fptw64 -greset unknown value is still there. Here’s meinfo:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
D:\Intel CSME System Tools v12 r12\MEInfo>MEInfoWin64
Intel (R) MEInfoWin64.exe Version: 12.0.20.1301
Copyright (C) 2005 - 2018, Intel Corporation. All rights reserved.
Intel(R) ME code versions:
BIOS Version GL703GS.306
MEBx Version 0.0.0.0000
GbE Version Unknown
Descriptor Version 1.0
Vendor ID 8086
FW Version 12.0.20.1307 H Consumer
LMS Version Not Available
MEI Driver Version 1828.12.0.1152
Wireless Hardware Version 2.1.77
Wireless Driver Version 20.100.0.4
PMC FW Version 300.2.11.1018
PCH Information
PCH Version 10
PCH Device ID A30D
PCH Step Data B1
PCH SKU Type Production Pre-QS Revenue
PCH Replacement Counter 0
PCH Replacement State Disabled
PCH Unlocked State Disabled
FW Capabilities 0x31119140
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Intel(R) Platform Trust Technology - PRESENT/ENABLED
Persistent RTC and Memory - PRESENT/ENABLED
Capability Licensing Service Enabled
End of Manufacturing Enable Yes
Local FWUpdate Enabled
OEM ID 00000000-0000-0000-0000-000000000000
Integrated Sensor Hub Initial Power State Disabled
Intel(R) PTT Supported Yes
Intel(R) PTT initial power-up state Enabled
OEM Tag 0x1043
PAVP Supported Yes
Post Manufacturing NVAR Config Enabled Yes
TLS Disabled
FW Type Production
Last ME reset reason Global system reset
BIOS Config Lock Enabled
GbE Config Lock Enabled
Host Read Access to ME Enabled
Host Write Access to ME Disabled
Host Read Access to EC Disabled
Host Write Access to EC Disabled
SPI Flash ID 1 C22018
SPI Flash ID 2 Not Available
BIOS boot State Post Boot
Slot 1 Board Manufacturer 0x00001043
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
M3 Autotest Disabled
Minimum Allowed Anti Rollback SVN 1
Image Anti Rollback SVN 4
Trusted Computing Base SVN 1
HW Binding Enabled
FPF UEP ME FW
Enforcement Policy 0x00 0x00 0x00
EK Revoke State Not Revoke Not Revoke Not Revoke
PTT Enabled Enabled Enabled
OEM ID 0x00 0x00 0x00
OEM Key Manifest Present Not Present Not Present Not Present
OEM Platform ID 0x00 0x00 0x00
OEM Secure Boot Policy 0x00 0x00 0x00
CPU Debugging Enabled Enabled Enabled
BSP Initialization Enabled Enabled Enabled
Protect BIOS Environment Disabled Disabled Disabled
Measured Boot Disabled Disabled Disabled
Verified Boot Disabled Disabled Disabled
Key Manifest ID 0x00 0x00 0x00
Persistent PRTC Backup Power Enabled Enabled Enabled
RPMB Migration Done Disabled Disabled Disabled
SOC Config Lock Done Not Done Done
SPI Boot Source Enabled Enabled Enabled
TXT Supported Disabled Disabled Disabled
ACM SVN FPF 0x00
BSMM SVN FPF 0x00
KM SVN FPF 0x00
OEM Public Key Hash FPF 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash UEP 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash ME FW 0000000000000000000000000000000000000000000000000000000000000000
PTT Lockout Override Counter FPF 0x00
Do not pay attention, I have two boards on z390. the same situation was on the BIOS from the factory.
Generally regardless of the BIOS version or separately updated firmware ME FW, I get the same PhaseStatus = UNKNOWN. the firmware through the BIOS programmer will not solve the issue either. it is not treated…
It does not affect the work and all right.
@magikkk I am in the same boat. After updating the Intel ME firmware for Consumer PCH-H B to its latest version, the Phase Status now shows UNKNOWN value as well; it wasn’t like that in the version dated two updates back. Nonetheless, like @jjxaker said, I wouldn’t pay too much attention to that.
I have a feeling the firmwares of v20 hotfix (and up, in future) are optimized towards Intel 9th Generation which are Coffee Lake “Refresh”, and that means they might be planning to rename/drop/revamp that particular item anyway, but their tools still show it in its original form. We already know that Intel ME Tools might have bugs, like it was determined a few posts above by @plutomaniac so this might be such a case too. Plus v12.0.20.1307 is a “hotfix” version and it might not be a full “final” one, thus this error.
Yes I agree. This is most likely MEInfo being outdated/bugged and not being able to recognize some Status value, thus returning Unknown. You can ignore it completely as it’s purely a visual thing at MEInfo. The platform works as expected. Intel has already jumped to 12.0.30 (12.0.20 started in September) but we’ve yet to find any such firmware.
I see, thank you people for all the info.
Was FWUpdate tool’s error.txt with verification percentages a bug too?
Because firmware update was successful with green light and all. It’s weird to generate error.txt saying that ‘everything’s ok’
It’s likely. Version 12.0.20.1301 is 3 months old at this point. No matter what, both MEInfo and MEManuf outputs are proper so you have nothing to worry about.
@magikkk I believe the answer is very simple: it was created not because bugs happened during the update but despite of their existence/lack of it. The brainiacs at Intel made it obligatory to create such a log and named it this way, but it’s still just a confirmation file for future reference.
@Fernando There is a newer version (1846.12.0.1177) of MEI Drivers & Software at Station-Drivers for Consumer systems here than the one in the first post.
@Wickez :
The thread opener and author of the start post is plutomaniac and not me. If there are newer/better Intel MEI drivers available, he will update the start post as soon as possible.
I consider this very disrespectful after 4 years of maintaining this sub-forum . The link has been updated.
Sorry, my homie. I messed up with another tab of this forum with Intel RST topic where Fernando was the boss. I will make it up to you by sending handcrafted Intel ME badge. You only need to give me your address.
And a changelog between this and 11.8.55.3510:
<11.8.60.3561> (N23RG10W)
-(Fix) Fixed the following security vulnerabilities:
CVE-2018-12188, CVE-2018-12189, CVE-2018-12190, CVE-2018-12191, CVE-2018-12192,
CVE-2018-12199, CVE-2018-12187, CVE-2018-12196 and CVE-2018-12185.
-(Fix) Fixed an issue where Intel(R) ME does not work properly after performing FW Update.
-(Fix) Fixed an issue where firmware reset occurs when loading web storage when using MeshCommander.
-(Fix) Fixed an issue where wrong Intel(R) LMS version is displayed when executing MeInfoWin64.
-(Fix) Fixed an issue when starting user consent flow, MEBX Consent is not displayed.
-(Fix) Fixed an issue when the platform is on S3 resume flow, the HECI SW fails to communicate
with HECI FW.
https://support.lenovo.com/ca/en/downloads/ds502325
ASRock provided new bios for my H370 mobo 3.20 with updated ME Firmware
Here is a MEInfo:
PS D:\Drv\Intel CSME System Tools v12 r12\MEInfo\WIN64> .\MEInfoWin64.exe -verbose
LPC Device Id: A304.
Platform: Cannonlake Platform
Windows OS Version : 10.0
FW Status Register1: 0x90000245
FW Status Register2: 0x06F10506
FW Status Register3: 0x00000020
FW Status Register4: 0x00004000
FW Status Register5: 0x00000000
FW Status Register6: 0x40000000
CurrentState: Normal
ManufacturingMode: Disabled
FlashPartition: Valid
OperationalState: CM0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
SPI Flash Log: Not Present
Phase: ROM/Preboot
ME File System Corrupted: No
PhaseStatus: UNKNOWN
FPF and ME Config Status: Committed
RPMC status: OK
FW Capabilities value is 0x31109140
Feature enablement is 0x31109140
Platform type is 0x72000392
Table Type 255 ( 0x FF ) found, size of 0 (0x 00 ) bytes
BIOS Version P3.20
Table Type 0 ( 0x 00 ) found, size of 69 (0x 45 ) bytes
Table Type 1 ( 0x 01 ) found, size of 166 (0x A6 ) bytes
Table Type 2 ( 0x 02 ) found, size of 125 (0x 7D ) bytes
Table Type 3 ( 0x 03 ) found, size of 138 (0x 8A ) bytes
Table Type 9 ( 0x 09 ) found, size of 23 (0x 17 ) bytes
Table Type 11 ( 0x 0B ) found, size of 29 (0x 1D ) bytes
Table Type 32 ( 0x 20 ) found, size of 22 (0x 16 ) bytes
Table Type 40 ( 0x 28 ) found, size of 22 (0x 16 ) bytes
Table Type 16 ( 0x 10 ) found, size of 25 (0x 19 ) bytes
Table Type 17 ( 0x 11 ) found, size of 74 (0x 4A ) bytes
Table Type 19 ( 0x 13 ) found, size of 33 (0x 21 ) bytes
Table Type 221 ( 0x DD ) found, size of 93 (0x 5D ) bytes
Table Type 221 ( 0x DD ) found, size of 388 (0x 184 ) bytes
Table Type 221 ( 0x DD ) found, size of 208 (0x D0 ) bytes
Table Type 221 ( 0x DD ) found, size of 32 (0x 20 ) bytes
Table Type 7 ( 0x 07 ) found, size of 29 (0x 1D ) bytes
Table Type 4 ( 0x 04 ) found, size of 189 (0x BD ) bytes
Table Type 20 ( 0x 14 ) found, size of 37 (0x 25 ) bytes
Table Type 130 ( 0x 82 ) found, size of 22 (0x 16 ) bytes
MEBx Version 12.0.0.0010
GbE Version 0.5
Vendor ID 8086
FW Version 12.0.6.1120 H Consumer
LMS Version 1846.12.0.1173
Wireless Hardware Version Not Available
Wireless Driver Version Not Available
PMC FW Version 300.2.11.1015
PCH Information
PCH Version 10
PCH Device ID A304
PCH Step Data B1
FW Capabilities 0x31109140
Service Advertisement & Discovery - NOT PRESENT
OEM Tag 0x00
PAVP Supported Yes
TLS Disabled
FW Type Production
Last ME reset reason Unknown
Host Read Access to EC Enabled
Host Write Access to EC Enabled
Protected Range Register Base #0 0x0
Protected Range Register Limit #0 0x0
Protected Range Register Base #1 0x0
Protected Range Register Limit #1 0x0
Protected Range Register Base #2 0x0
Protected Range Register Limit #2 0x0
Protected Range Register Base #3 0x0
Protected Range Register Limit #3 0x0
Protected Range Register Base #4 0x0
Protected Range Register Limit #4 0x0
SPI Flash ID 1 EF4018
Slot 1 Board Manufacturer 0x00000000
Trusted Computing Base SVN 0
HW Binding Enabled
FPF UEP ME FW
EK Revoke State Not Revoke Not Revoke Not Revoke # Not Revoke=0, Revoke=1
PTT Enabled Enabled Enabled # Disabled=0, Enabled=1
OEM Key Manifest Present Not Present Not Present Not Present # Not Present=0, Present=1
CPU Debugging Enabled Enabled Enabled # Enabled=0, Disabled=1
BSP Initialization Enabled Enabled Enabled # Enabled=0, Disabled=1
Protect BIOS Environment Disabled Disabled Disabled # Disabled=0, Enabled=1
Measured Boot Disabled Disabled Disabled # Disabled=0, Enabled=1
Verified Boot Disabled Disabled Disabled # Disabled=0, Enabled=1
Persistent PRTC Backup Power Enabled Enabled Enabled # Enabled=0, Disabled=1
RPMB Migration Done Disabled Disabled Disabled # Disabled=0, Enabled=1
SOC Config Lock Done Not Done Done # Not Done=0, Done=1
SPI Boot Source Enabled Enabled Enabled # Enabled=0, Disabled=1
TXT Supported Disabled Disabled Disabled # Disabled=0, Enabled=1
ACM SVN FPF 0x00
BSMM SVN FPF 0x00
KM SVN FPF 0x00
PTT Lockout Override Counter FPF 0x01
On the 12.0*** firmware I’m trying to load the PMC file in the Fit tool and I’m stuck. I don’t know how to actually select and input the file, I highlight the PMC Binary File option but no option to input the file. :frowning:
Never mind, figured it out. :slight_smile:
@plutomaniac ,
Was wondering if you could tell me if my MEinfo verbose detail look ok?
Thanks
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
LPC Device Id: A305.
FW Status Register1: 0x90000255
FW Status Register4: 0x00004004
FW Status Register6: 0x00400000
ManufacturingMode: Enabled
ErrorCode: No Error
SPI Flash Log: Present
Phase: ROM/Preboot
FPF and ME Config Status: Not committed
RPMC status: OK
Feature enablement is 0x11109140
BIOS Version F7
Table Type 0 ( 0x 00 ) found, size of 66 (0x 42 ) bytes
Table Type 1 ( 0x 01 ) found, size of 136 (0x 88 ) bytes
Table Type 2 ( 0x 02 ) found, size of 116 (0x 74 ) bytes
Table Type 3 ( 0x 03 ) found, size of 98 (0x 62 ) bytes
Table Type 8 ( 0x 08 ) found, size of 25 (0x 19 ) bytes
Table Type 10 ( 0x 0A ) found, size of 33 (0x 21 ) bytes
Table Type 11 ( 0x 0B ) found, size of 21 (0x 15 ) bytes
Table Type 12 ( 0x 0C ) found, size of 21 (0x 15 ) bytes
Table Type 34 ( 0x 22 ) found, size of 19 (0x 13 ) bytes
Table Type 26 ( 0x 1A ) found, size of 29 (0x 1D ) bytes
Table Type 36 ( 0x 24 ) found, size of 18 (0x 12 ) bytes
Table Type 35 ( 0x 23 ) found, size of 27 (0x 1B ) bytes
Table Type 28 ( 0x 1C ) found, size of 29 (0x 1D ) bytes
Table Type 27 ( 0x 1B ) found, size of 30 (0x 1E ) bytes
Table Type 27 ( 0x 1B ) found, size of 17 (0x 11 ) bytes
Table Type 29 ( 0x 1D ) found, size of 27 (0x 1B ) bytes
Table Type 39 ( 0x 27 ) found, size of 184 (0x B8 ) bytes
Table Type 17 ( 0x 11 ) found, size of 109 (0x 6D ) bytes
Table Type 4 ( 0x 04 ) found, size of 185 (0x B9 ) bytes
GbE Version 0.5
Vendor ID 8086
LMS Version 1828.12.0.1150
MEI Driver Version 1815.12.0.2021
Wireless Driver Version 20.70.0.5
OEM FW Version 0.0.0.0000
PCH Information
PCH Version 10
PCH Device ID A305
PCH Step Data B1
Intel(R) Platform Trust Technology - PRESENT/DISABLED
End of Manufacturing Enable No
Intel(R) PTT initial power-up state Disabled
OEM Tag 0x00
PAVP Supported Yes
TLS Disabled
FW Type Production
Host Write Access to ME Enabled
HW Binding Enabled
FPF UEP ME FW
Enforcement Policy Not set 0x00 0x00
EK Revoke State Not set Not Revoke Not Revoke # Not Revoke=0, Revoke=1
PTT Not set Enabled Enabled # Disabled=0, Enabled=1
OEM ID Not set 0x00 0x00
OEM Key Manifest Present Not set Present Present # Not Present=0, Present=1
OEM Platform ID Not set 0x00 0x00
OEM Secure Boot Policy Not set 0x40 0x40
CPU Debugging Not set Enabled Enabled # Enabled=0, Disabled=1
BSP Initialization Not set Enabled Enabled # Enabled=0, Disabled=1
Protect BIOS Environment Not set Disabled Disabled # Disabled=0, Enabled=1
Measured Boot Not set Disabled Disabled # Disabled=0, Enabled=1
Verified Boot Not set Disabled Disabled # Disabled=0, Enabled=1
Key Manifest ID Not set 0x01 0x01
Persistent PRTC Backup Power Not set Enabled Enabled # Enabled=0, Disabled=1
RPMB Migration Done Not set Disabled Disabled # Disabled=0, Enabled=1
SOC Config Lock Not set Not Done Not Done # Not Done=0, Done=1
SPI Boot Source Not set Enabled Enabled # Enabled=0, Disabled=1
TXT Supported Not set Disabled Disabled # Disabled=0, Enabled=1
ACM SVN FPF Not set
BSMM SVN FPF Not set
KM SVN FPF Not set
OEM Public Key Hash FPF Not set
OEM Public Key Hash UEP E02EFA655BEBB704883EEE4476ADC62C6FEBC80756158CB684A71D35B169C5D1
OEM Public Key Hash ME FW E02EFA655BEBB704883EEE4476ADC62C6FEBC80756158CB684A71D35B169C5D1
PTT Lockout Override Counter FPF Not set
I mentioned to David not to flash the EXTR firmware without ‘cleaning’ it first from here.
[Guide] Clean Dumped Intel Engine (CS)ME/(CS)TXE Regions with Data Initialization
If you don’t or can’t do that, use the 1301 RGN firmware.
Your absolutely right. It completely skipped my mind. Thank you for pointing that out. Fortunately I was able to boot up with out issue that I can tell. The problem is now how do I go back to a cleanly configured state. I tried your ME file but because it was older I could not go backwards. I have a backup of the ME before I tried flashing to a newer version as I did a dump prior flashing. I suppose when the next version is released I can use FIT to transfer my original settings onto it? Or is there a better way?
Thanks
KedarWolf,
Your ME file according to ME Analyzer is also Region Extracted just like my ME File such that it must be mislabeled and incorrectly named. I ran another ME Region ver 11.11.55.1509 through ME Analyzer and that said ‘Region Stock’ as opposed to ‘Region Extracted’. So I wonder where you got your file from? Did they run it through FIT tool to transfer the settings needed prior?
Thanks
I ran ME Analyzer on the firmware from the Firmware Repository .zip and it said it was Region. :slight_smile:
Kedar,
Can you do me a favor and do a MEinfo -verbose listing for me?
Thanks
Edit: I get the same ‘Region-Stock’ from the repository as well. Just not from the ones you posted on Overclock.
As requested, my MEInfo -verbose.
D:\Intel CSME System Tools v12 r12\Intel CSME System Tools v12 r12\MEInfo\WIN64>MEInfoWin64.exe -verbose
ErrorCode: No Error
Phase: ROM/Preboot
RPMC status: OK
BIOS Version F5b
Table Type 0 ( 0x 00 ) found, size of 67 (0x 43 ) bytes
Table Type 2 ( 0x 02 ) found, size of 127 (0x 7F ) bytes
GbE Version 0.5
Vendor ID 8086
FW Version 12.0.20.1301 H Consumer
PCH Information
PCH Version 10
PCH Device ID A305
PCH Step Data B1
OEM Tag 0x00
PAVP Supported Yes
TLS Disabled
FW Type Production
HW Binding Enabled
FPF UEP ME FW
ACM SVN FPF Not set
KM SVN FPF Not set
