Intel (CS) Management Engine: Drivers, Firmware and Tools (2-15)
Intel CSME 12.0 Consumer PCH-H B,A Firmware v12.0.39.1431
Intel CSME 12.0 Corporate PCH-H B,A Firmware v12.0.39.1431
Intel CSME 12.0 Consumer PCH-LP C Firmware v12.0.39.1431
Intel CSME 12.0 Corporate PCH-LP C Firmware v12.0.39.1431
Intel CSME System Tools v12 r16 - (2019-06-13)
@plutomaniac are you aware that β€œIntel CSME System Tools v11 r25” contains in fact β€œIntel CSME System Tools v11 r14” folder and it’s content indeed matches β€œIntel CSME System Tools v11 r14” version? (I checked hashes). The same situation was true for r20. Could you explain this?
I just checked, everything is correct. You must have made some mistake on your end.
Indeed this is very weird issue on my end. Sorry for the noise and thank you for checking this.
Specifically the issue was caused by naming scheme for archives - the archive filename ends with "rXX" (r14, r15 and so on) and my un-archiver treated all subsequent versions as parts of the same archive and showed contents of the lowest version available.
Intel CSME 12.0 Consumer PCH-LP C Firmware v12.0.40.1433
Intel CSME 12.0 Corporate PCH-LP C Firmware v12.0.40.1433
Intel CSME System Tools v12 r17 - (2019-06-18)
Intel MEI Drivers & Software Consumer v1923.12.0.1278
Intel MEI Drivers & Software Consumer DCH v1923.12.0.1278
Intel MEI Installer v1923.12.0.1278
MEInfo.txt (5.74 KB)
Hello, new member here. I am trying to create a binary file merging the latest CSME binary with the latest PMC binary for my system. I verified that I have the correct binaries. When I run FIT the CSME binary gets loaded into FIT. However, when I drop my PMC binary (CNP_300.2.11.1020_H_B_PRD.bin) in the PMC Binary File field I get errors. My CPU is an i9-9900K on a Z390 mobo. FIT displays it as an Intel(R) Cannonlake H Series Chipset - QM370. I tried Z390 but that didn’t work either for the PMC file. Is this an issue? What can the problem be?
Intel (R) Flash Image Tool. Version: 12.0.37.1429
Copyright (c) 2013 - 2019, Intel Corporation. All rights reserved.
6/20/2019 - 8:50:46 pm
Using vsccommn.bin with timestamp 20:53:34 03/26/2019 GMT
Command Line: C:\Users\Gary Shapiro\My Programs\Intel CSME System Tools v12 r17\Flash Image Tool\WIN32\fit.exe
Log file written to fit.log
Loading C:\Users\Gary Shapiro\My Programs\Intel CSME System Tools v12 r17\Flash Image Tool\WIN32\12.0.39.1431_CON_H_BA_PRD_EXTR.bin
Decomposed SKU Value: β€œIntel(R) Cannonlake H Series Chipset - QM370”.
Warning: Invalid value specified for β€œGbE PCIe Port Select”: Port13, reverting to previous/default value: Port 13
Warning: Invalid value specified for β€œeSPI / EC Slave Attached Flash Multiple Outstanding Requests Enable”: Single, reverting to previous/default value: Single Outstanding Request
Warning: Invalid value specified for β€œeSPI / EC Slave Attached Flash Channel OOO Enable”: In Order, reverting to previous/default value: In-Order SAF Requests
Warning: Invalid value specified for β€œUSB2 DbC port enable”: No USB3 Ports, reverting to previous/default value: No USB2 Ports
Warning: Invalid value specified for β€œIntel(R) Precise Touch and Stylus Controller 1 Maximum Frequency”: 30MHz, reverting to previous/default value: 30 MHz
Saving XML …
XML file written to C:\Users\Gary Shapiro\My Programs\Intel CSME System Tools v12 r17\Flash Image Tool\WIN32\Untitled.xml
Loading C:\Users\Gary Shapiro\My Programs\Intel CSME System Tools v12 r17\Flash Image Tool\WIN32\CNP_300.2.11.1020_H_B_PRD.bin
Error 235: Failed to load input file. Invalid input file type.
Error 42: Failed to open with processed commands.
Unable to open file: C:\Users\Gary Shapiro\My Programs\Intel CSME System Tools v12 r17\Flash Image Tool\WIN32\CNP_300.2.11.1020_H_B_PRD.bin. Reverting to default configuration.
Loading defaults.
Attached files show the firmware I am currently on.
MEA.pdf (398 KB)
Is Slim compatible with Consumer? Its something new…
@ streetwolf:
Are you drag & dropping the PMC firmware into FIT? You can’t do that. Load it via the β€œPMC Binary File” field.
@ MonarchX:
It’s not new. Apple systems use Slim.
I was dragging and dropping because I can’t seem to be able to load it as you instructed. Am I supposed to right click on the PMC field and get an option to load the file or is it done another way? I don’t get any menu when I right click.
Also, does it make a difference my CPU is displayed as Cannon Lake instead of Coffee Lake? Should I specify Z390 or does it matter what is specified?
Here are the files I want to merge. Is there anything wrong about them?
WIN32.zip (1.66 MB)
Click on the PMC field as to edit it and a browse button will appear on the right. As per the instructions, only the general H or LP category must be set, not actual PCH/SoC.
Hi,
Where/how to get PMC Binaries? Or those are really needed? Can’t update without it?
I found it xD But it will match with Asus Z390 boards?
I don’t get a browse button when I follow your instructions. I’m using Intel (R) Flash Image Tool. Version: 12.0.37.1429. Can you provide a screenshot of what I should get?
**** UPDATE *****
I had to do some subtle clicking on the field in order to get the browse button.
Everything went smoothly. Thanks for your help.
It simple as that:
It’s still from an Intel bios update package- but the version number is not in the database. Tried to unpack it, but MEA crashed.
β•‘ ME Analyzer v1.86.0 r166 β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
β•‘ Flash Partition Table ROM-Bypass β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Instruction 0 β”‚ N/A β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Instruction 1 β”‚ N/A β•‘
β•‘ Instruction 2 β”‚ N/A β•‘
β•‘ Instruction 3 β”‚ N/A β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•β•
β•‘ Flash Partition Table 2.0 Header β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Tag β”‚ $FPT β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Partition Count β”‚ 14 β•‘
β•‘ Header Version β”‚ 0x20 β•‘
β•‘ Entry Version β”‚ 0x10 β•‘
β•‘ Header Size β”‚ 0x20 β•‘
β•‘ Header Checksum β”‚ 0x7D β•‘
β•‘ Ticks To Add β”‚ 0xFFFF β•‘
β•‘ Tokens To Add β”‚ 0xFFFF β•‘
β•‘ Reserved β”‚ 0x413 β•‘
β•‘ Flash Layout β”‚ 4K β•‘
β•‘ Flash Image Tool β”‚ 4.1.4.251 β•‘
β•šβ•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•β•
Flash Partition Table Checksum is VALID
β•‘ Detected 14 Partition(s) at $FPT [0x2E4000] β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Name β”‚ Start β”‚ End β”‚ ID β”‚ Type β”‚ Valid β”‚ Empty β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ FTPR β”‚ 0x38E000 β”‚ 0x401000 β”‚ 0000 β”‚ Code β”‚ True β”‚ False β•‘
β•‘ FTUP β”‚ 0x401000 β”‚ 0x662000 β”‚ 0000 β”‚ Code β”‚ True β”‚ False β•‘
β•‘ DLMP β”‚ 0x376000 β”‚ 0x38E000 β”‚ 0000 β”‚ Code β”‚ False β”‚ False β•‘
β•‘ PSVN β”‚ 0x2E4000 β”‚ 0x2E4000 β”‚ 0000 β”‚ Code β”‚ False β”‚ True β•‘
β•‘ IVBP β”‚ 0x2E4000 β”‚ 0x2E4000 β”‚ 0000 β”‚ Code β”‚ False β”‚ True β•‘
β•‘ MFS β”‚ 0x306000 β”‚ 0x36A000 β”‚ 0000 β”‚ Data β”‚ True β”‚ False β•‘
β•‘ FPTB β”‚ 0x2E5000 β”‚ 0x2E6000 β”‚ 0000 β”‚ Data β”‚ True β”‚ False β•‘
β•‘ MFSB β”‚ 0x2E6000 β”‚ 0x306000 β”‚ 0000 β”‚ Data β”‚ True β”‚ False β•‘
β•‘ IVB1 β”‚ 0x36A000 β”‚ 0x36E000 β”‚ 0000 β”‚ Data β”‚ True β”‚ True β•‘
β•‘ IVB2 β”‚ 0x36E000 β”‚ 0x372000 β”‚ 0000 β”‚ Data β”‚ True β”‚ False β•‘
β•‘ BIS β”‚ 0x372000 β”‚ 0x373000 β”‚ 0000 β”‚ Data β”‚ True β”‚ True β•‘
β•‘ FLOG β”‚ 0x373000 β”‚ 0x374000 β”‚ 0000 β”‚ Data β”‚ True β”‚ True β•‘
β•‘ UTOK β”‚ 0x374000 β”‚ 0x376000 β”‚ 0000 β”‚ Data β”‚ True β”‚ True β•‘
β•‘ OPR1 β”‚ 0x401000 β”‚ 0x662000 β”‚ 0000 β”‚ Code β”‚ True β”‚ False β•‘
β•šβ•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•§β•β•β•β•β•β•β•β•β•β•
--> Stored Flash Partition Table [0x2E4000 - 0x2E5000]
--> Stored $FPT Code Partition "FTPR 0000" [0x38E000 - 0x401000]
Error: ME Analyzer crashed, please report the following:
Traceback (most recent call last):
File "MEA.py", line 9158, in <module>
File "MEA.py", line 4022, in cse_unpack
File "MEA.py", line 4247, in ext_anl
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xff in position 0: invalid start byte
33.zip (2.45 MB)
It does exist in the DB, as can be seen at MEA.dat file. MEA does not support Intel Engine Capsule images and thus the reported message is not accurate in such case.
I don’t understand the current IME firmware. It seems to be separated into different pieces now that work together? Before it was easy to update just find out if it’s a LP or SH and Corporate or Consumer, now I can’t even determine my version anymore. Here’s what I have
https://www.asus.com/us/Laptops/Q405UA/HelpDesk_Download/
https://www.bestbuy.com/site/asus-2-in-1…p?skuId=6292312
I tried running the MeInfoWin64 but now it doesn’t even work right, it complains
"Error 63: Unknown or unsupported hardware platform. HW: Intel(R) Sunrise Point Chipset. Supported HW: Cannonlake Platform."
What the heck is it talking about? This is an i5-8250U which is current gen, I have no clue what it’s refusing to recognize this for
I can’t do anything now to upgrade this firmware, I can’t identify the version, figure out even what to do next. Any step by step guide is great because this makes no sense to me
You’re using CSME v12 tools on a CSME v11 platform. Nothing has changed for CSME v11 firmware.
Hi!!
i have a GA-X79S-UP5-WIFI BIOS F5f
using UBU tools i can replace some modules:
Intel Legacy RAID for SATA 11.6.0.1702 to 12.9.0.2006
Intel UEFI SataDriver 11.6.0.1702 to 12.9.0.2006
Intel RSTe RAID SataDriver 3.7.0.1049 to 4.2.0.1036
Intel RSTe EFI SataDriver/SCU 3.7.0.1049 to 4.2.0.1036
Marvell 88SE91xx Adapter ROM 1.0.1.1025 to 1.1.0.1020
Intel Boot Agent GE 1.3.95 to 1.5.62
Intel GigabitLanX64 5.1.00 to 6.6.04
Realtek GBE ROM 2.56 to 2.66
Realtek EFI UNDI 2.015 to 2.048
CPU Microcode Pack latest 2019-06
ME firmware 8.1.40.1416
all work fine, ME firmware are replace after with windows tools for 8.1.70.1590(latest) but i dont know for now how to replace in the bios file. Can you share a mini how to please :slight_smile:
Thx
hi, modules asus M4A88TDV_EVOUSB3 agesa FX 6300?
