Intel MEI Drivers & Software Consumer v1923.12.0.1278
In get this error on latest 1433:
Error 433: PMC partition is not in the Update Image.
Have a Gigabyte z390 Board.
Intel CSME 11.8 Consumer PCH-H D,A Firmware v11.8.65.3606
@ Scoty:
Read the first post on how to use CSME 12 FWUpdate tool.
I use now the v12.0.40.1433 on my z390.
Is there a ROM for the Intel ME FITC as shown in the snippet from HWInfo64 I attached?
I donât understand that question, it makes no sense. Read the first post if you donât understand what Flash Image Tool (FIT) is.
I am familiar with the FIT. In fact I just used it to update my firmware with your binaries. You can see this by the version number of the first two entries in my attachment. I am supposing that these entries are the versions that are now flashed into my BIOS. But what about the third entry? What is it? It must be some binary that is flashed into the BIOS like the other two entries. It isnât the same thing as the software FIT. My motherboard as a built in Flasher called Q-Flash. Could the third entry be referencing this?
FITC = FIT. Your OEM used FIT v12.0.22.1310 to build their SPI image which is now flashed on your system. The use of FWUpdate tool to update the actual firmware on top, does not change that.
Sorry for all the questions but as they say there are no stupid questions (debatable IMO). Anyways, I see references online to a utility called FITC.EXE. Is this the same as FIT.EXE? Also I am not clear if the FITC shown in my screenshot is the BIOS based Q-Flash as it is known in Gigabyte boardsâŚ
At my post above I said that FITC or âFlash Image Tool Configurator (?)â = FIT or âFlash Image Toolâ. Itâs a different name for the exact same tool. QFlash has nothing to do with FIT.
Type: Region, Extracted
File System State: Unconfigured
can be used with FWUpdate tool to upgrade the version of Intel ME without configuration with Intel Flash Image Tool (FIT)?
Yes
Hi, i have asrock z87 extreme4 bios version 3.50, win10 x64, what version of MEI driver without software should i install? thank you.
Hello!
Please share intel flash image tool 12.0.0.1069.
Thank You!
I donât do that on demand. You can use the latest FIT from the CSME System Tools v12 of the first post.
I cant open dump with regular v12 CSME sys tools. Me analayzer says it was built with 12.0.0.1069 so i think it will open it. Same as was with ES sample dump that only 1020 could open it. All other whre "reverting to defaults"
Intel MEI Driver v1919.14.0.1269 (Windows 8 & Windows 10)
2
3
4
5
6
7
Â
DriverVer = 05/07/2019,1919.14.0.1269
PCI\VEN_8086&DEV_3DE0; ME13.0 - ICL-H
PCI\VEN_8086&DEV_34E0; ME13.0 - ICL-LP
PCI\VEN_8086&DEV_38E0; ME13.0 - ICL-LP
PCI\VEN_8086&DEV_18D3; ME13.0 - CDF
PCI\VEN_8086&DEV_02E0; ME14.0 - CML
PCI\VEN_8086&DEV_06E0; ME14.0 - CML
Â
Yes I am aware. There are CSME 13 drivers for ICL and CSME 14 for CML. CSME 14 covers CSME 13 drivers so I donât understand why two branches exist. Anyway, these platforms are not released yet so people should use CSME 12 drivers until we know more.
HI!
Could you help me which is the correct CSM system tool version and firmware? I know the install steps, but have to many difference.
I think so the Intel firmware is not enough.
Thank your time and thank you the amazing works!
Respects!
Motherboard: ASUS PRIME Z270-A
MEinfo :
Intel(R) ME code versions:
BIOS Version 1302
MEBx Version 0.0.0.0000
GbE Version 0.2
Vendor ID 8086
PCH Version 0
FW Version 11.8.65.3590 H
Security Version (SVN) 3
LMS Version 1915.12.0.1257
MEI Driver Version 1914.12.0.1256
Wireless Hardware Version Not Available
Wireless Driver Version Not Available
FW Capabilities 0x31111540
Intel(R) Capability Licensing Service - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Intel(R) Platform Trust Technology - PRESENT/DISABLED
Re-key needed False
Platform is re-key capable True
TLS Disabled
Last ME reset reason Firmware reset
Local FWUpdate Enabled
BIOS Config Lock Enabled
GbE Config Lock Enabled
Host Read Access to ME Enabled
Host Write Access to ME Disabled
Host Read Access to EC Disabled
Host Write Access to EC Disabled
SPI Flash ID 1 EF4018
SPI Flash ID 2 Unknown
BIOS boot State Post Boot
OEM ID 00000000-0000-0000-0000-000000000000
Capability Licensing Service Enabled
OEM Tag 0x00000000
Slot 1 Board Manufacturer 0x00000000
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
M3 Autotest Disabled
C-link Status Disabled
Independent Firmware Recovery Disabled
EPID Group ID 0x2009
LSPCON Ports None
5K Ports None
OEM Public Key Hash FPF 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash ME 0000000000000000000000000000000000000000000000000000000000000000
ACM SVN FPF 0x0
KM SVN FPF 0x0
BSMM SVN FPF 0x0
GuC Encryption Key FPF 0000000000000000000000000000000000000000000000000000000000000000
GuC Encryption Key ME 0000000000000000000000000000000000000000000000000000000000000000
FPF ME
â â
Force Boot Guard ACM Disabled Disabled
Protect BIOS Environment Disabled Disabled
CPU Debugging Enabled Enabled
BSP Initialization Enabled Enabled
Measured Boot Disabled Disabled
Verified Boot Disabled Disabled
Key Manifest ID 0x0 0x0
Enforcement Policy 0x0 0x0
PTT Enabled Enabled
PTT Lockout Override Counter 0x6
EK Revoke State Revoked
PTT RTC Clear Detection FPF 0x0
I donât understand what youâre asking. I assume you mean CSE and not CSM. You have a 200-series system with CSME 11.8 firmware so the equivalent tools must be used from the first post.
