Intel (CS) Management Engine: Drivers, Firmware and Tools (2-15)
Intel CSME 11.8 Corporate PCH-LP C Firmware v11.8.79.3722 (NPDM + YPDM)
I suppose there is no matter how the modified BIOS is flashed. BG prevents the system from starting when a modified BIOS is detected.
Oh well, BG is very annoying
Intel CSME 14.0 Consumer PCH-LP B,A Firmware v14.0.39.1367
Intel CSME 14.0 Corporate PCH-LP B,A Firmware v14.0.39.1367
Intel CSME 13.0 Consumer PCH-LP D Firmware v13.0.37.1556
Intel MEI Drivers & Software v2015.13.30.9106 DCH (Windows 10 >= 1709)
Intel MEI Driver v2013.13.30.9100 (Windows 10 >= 1709)
Intel CSME 13.30 Lite PCH-LP B Firmware v13.30.1.1075
Intel PMC LKF PCH-LP B Firmware v133.0.10.1046
Intel PCHC LKF PCH-LP Firmware v13.30.0.1005
Intel PHY LKF S Firmware v10.227.203.1144
Note: ME Analyzer v1.148.0 or newer is required from now on.
Intel CSME 13.30 Lite PCH-LP B SPI Firmware v13.30.10.1147
Folks, i have recently updated the BIOS on the MSI Z370-A PRO motherboard to the latest. Ever since then the ME version shows up as 0.0.0.0. The computer still boots but takes longer and shows the following error message:
"The ME FW of system was found abnormal"
"it is recommended to re-flash system BIOS by M-Flash to ensure normal system operation"
So far it seems that the following operations are no longer properly working:
- computer does not wake up from sleep
- computer does not restart when requested needing a hard power down
- slow boot and error message at the beginning of the boot sequence
I tried flashing the same BIOS again, but the situation did not get any better.
Is there any advice someone can offer in regards to how to go about recovering from this issue?
Thanks.
@apara Seems your ME filesystem got corrupted. Offer the complete results of meinfo* -fwsts (and possibly a complete bios dump). Tools (and description for creating a clean ME region) are pinned and can be easily found within the Intel Management Engine subforum.
Intel CSME 14.5 Consumer PCH-V A Firmware v14.5.25.1163
Note: ME Analyzer v1.148.4 or newer is required for better CSME 14.5 support.
Intel CSME System Tools v14.5 r3 - (2020-08-29)
Intel CSME System Tools v14.0.20+ r6 - (2020-08-29)
Intel CSME System Tools v13.0 r3 - (2020-08-29)
Intel CSME System Tools v12 r25 - (2020-08-29)
Intel CSME System Tools v11 r33 - (2020-08-29)
Intel CSME 14.0 Consumer PCH-H A Firmware v14.0.39.1367
Intel CSME 14.0 Corporate PCH-H A Firmware v14.0.39.1367
Intel CSME System Tools v14.0.20+ r7 - (2020-09-01)
Intel CSME System Tools v12 r26 - (2020-09-01)
Intel CSME System Tools v11 r34 - (2020-09-01)
I have tried updating to this new 14.0.39.1367 firmware but I get the message "Error 619: Update of partition between engineering build vs regular build is not allowed."
I’m currently on 14.0.39.1339
Post a MEInfo -verbose report and what firmware components/versions you picked for the update.
MEInfo -verbose in the spoiler
Intel (R) MEInfo Version: 14.0.39.1367
Copyright (C) 2005 - 2020, Intel Corporation. All rights reserved.
Windows OS Version : 10.0
LPC Device Id: 685.
Platform: Cometlake Platform
General FW Information
FW Status Register1: 0x90000245
FW Status Register2: 0x66000506
FW Status Register3: 0x00000020
FW Status Register4: 0x00004800
FW Status Register5: 0x00000000
FW Status Register6: 0x40000000
CurrentState: Normal
ManufacturingMode: Disabled
FlashPartition: Valid
OperationalState: CM0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
SPI Flash Log: Not Present
Phase: HOSTCOMM Module
PhaseStatus: UNKNOWN
ME File System Corrupted: No
FPF and ME Config Status: Committed
RPMC status: OK
FW Capabilities value is 0x31119140
Feature enablement is 0x11119140
Platform type is 0x72000392
Platform Type Desktop
FW Type Production
Last ME Reset Reason Other
BIOS boot State Post Boot
Boot critical code redundancy Disabled
Current Boot Partition 1
CSME Measured Boot to TPM Disabled
Capability Licensing Service State Enabled
Crypto HW Support Enabled
FWUpdLcl Enabled
Firmware Update OEM ID 00000000-0000-0000-0000-000000000000
Integrated Sensor Hub Initial Power State Disabled
Intel(R) PTT State Disabled
Intel(R) PTT initial power-up state Disabled
OEM Tag 0x00
TLS State Disabled
Intel(R) ME code versions:
BIOS Version 0707
GbE Version 0.4
Vendor ID 8086
FW Version 14.0.39.1339 H Consumer
LMS Version 2026.14.0.1682
MEI Driver Version 2021.14.0.1615
IUPs Information
PMC FW Version 140.2.1.1011
PCHC FW Version 14.0.0.7002
SAMF FW Version 0.0.0.0000
PPHY FW Version 0.0.0.0000
PCH Information
PCH Version 0
PCH Device ID 685
PCH Step Data A0
PCH SKU Type Production PRQ Revenue
PCH Replacement State Disabled
PCH Replacement Counter 0
PCH Unlocked State Disabled
Flash Information
Storage Device Type SPI
SPI Flash ID 1 EF4019
SPI Flash ID 2 Not Available
RPMC Replay Protection Unsupported
RPMC Replay Protection Bind Counter 0
RPMC Replay Protection Bind Status Pre-bind
RPMC Replay Protection Rebind Unsupported
RPMC Replay Protection Max Rebind 1
Host Read Access to ME Enabled
Host Write Access to ME Disabled
Host Read Access to EC Disabled
Host Write Access to EC Disabled
FW Capabilities 0x31119140
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Intel(R) Platform Trust Technology - PRESENT/DISABLED
Service Advertisement & Discovery - NOT PRESENT
Persistent RTC and Memory - PRESENT/ENABLED
End Of Manufacturing
Post Manufacturing NVAR Config Yes
HW Binding Enabled
End of Manufacturing Enable Yes
Intel(R) Protected Audio Video Path
Keybox Not Provisioned
EPID Group ID 0x355F
Re-key needed False
PAVP State Yes
Security Version Numbers
Trusted Computing Base SVN 1
Minimum Allowed Anti Rollback SVN 1
Image Anti Rollback SVN 7
FW Supported FPFs
FPF UEP ME FW
*In Use
ACM SVN 0x00 0x00 0x00
BSMM SVN 0x00 0x00 0x00
EK Revoke State Not Revoked Not Revoked Not Revoked # Not Revoked=0, Revoked=1
Error Enforcement Policy 0 Disabled Disabled Disabled # Disabled=0, Enabled=1
Error Enforcement Policy 1 Disabled Disabled Disabled # Disabled=0, Enabled=1
Intel(R) PTT Enabled Enabled Enabled # Disabled=0, Enabled=1
KM SVN 0x00 0x00 0x00
OEM ID 0x00 0x00 0x00
OEM KM Present Disabled Disabled Disabled # Disabled=0, Enabled=1
OEM Platform ID 0x00 0x00 0x00
OEM Secure Boot Policy 0x400 0x400 0x400
CPU Debugging Enabled Enabled Enabled # Enabled=0, Disabled=1
BSP Initialization Enabled Enabled Enabled # Enabled=0, Disabled=1
Protect BIOS Environment Disabled Disabled Disabled # Disabled=0, Enabled=1
Measured Boot Disabled Disabled Disabled # Disabled=0, Enabled=1
Verified Boot Disabled Disabled Disabled # Disabled=0, Enabled=1
Key Manifest ID 0x00 0x00 0x00
Force Boot Guard ACM Disabled Disabled Disabled # Disabled=0, Enabled=1
PTT Lockout Override Counter 0x00 0x00 0x00
Persistent PRTC Backup Power Enabled Enabled Enabled # Enabled=0, Disabled=1
RPMC Rebinding Disabled Disabled Disabled # Disabled=0, Enabled=1
RPMC Support Disabled Disabled Disabled # Disabled=0, Enabled=1
SOC Config Lock State Enabled Disabled Enabled # Disabled=0, Enabled=1
SPI Boot Source Enabled Enabled Enabled # Enabled=0, Disabled=1
Txt Supported Disabled Disabled Disabled # Disabled=0, Enabled=1
OEM Public Key Hash FPF 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash UEP 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash ME FW 0000000000000000000000000000000000000000000000000000000000000000
I made a FWupdate using:
Intel PMC CMP PCH-H A Firmware v140.2.01.1011
Intel PCHC CMP PCH-H/LP Firmware v14.0.0.1002
Asus ROG Maximus XII Hero (WI-FI)
Ok, this is due to Intel stupidity. PCHC 14.0.0.1002 and 14.0.0.7002 are identical. The difference is that Builds 7xxx are Engineering ones. For PCHC CMP, Intel released 7001 instead of 1001 so all systems that have shipped so far use the Engineering build version which starts with 7xxx instead of 1xxx. FWUpdate tool has a check for that so that’s why it fails when trying to upgrade/downgrade to 1xxx versions, even if they are newer. Thus, I need to include both 7xxx and 1xxx Builds and the user will have to choose the proper one based on their current PCHC build, as detected by MEInfo. Re-download the PCHC archive and read the instructions inside to properly update your CSME 14.0 firmware.
Update was successful, thank you!
Hello guys i have a dell inspiron 5567 and i dont know which version i am suppose to choose from intel me firmware to update my system. I have attached my system info:
[[File:2020-09-05 13_02_34-Forum - Intel Management Engine_ Drivers, Firmware & System Tools.png|none|auto]]
Intel CSME 11.8 Consumer PCH-LP C NPDM
@plutomaniac . Thanks for the immediate answer! The update was successful .
Intel CSME System Tools v14.0.20+ r8 - (2020-09-12)
Intel Management Engine Driver 2033.15.0.1783
Support: ME10-ME15
