Intel (CS) Management Engine: Drivers, Firmware and Tools (2-15)
@Ataemonus Submit it as a false positive:
https://www.microsoft.com/en-us/wdsi/filesubmission
They happen, in each antivirus I have used, even in Kaspersky which is my all time favorite. Heuristics are not perfect.
Also you have exclusions in Defender until you receive the updated signatures.
Intel CSME 11.8 Corporate PCH-H D,A Firmware v11.8.80.3746
MEI driver only version 2035.15.0.1807 for Windows 10:
https://www.station-drivers.com/index.ph…ileinfo&id=4637
Successfully merged CSME + PMS with FIT and flashed with FWUpdate on an HP Pavilion 13 AN0007NU from CSME 12.0.45.1509 to 12.0.68.1606.
drive google com/drive/folders/1DIwK11JDrL2p1Ef9trYltGrRbhW9C42P?usp=sharing
Intel CSME 15.0 Consumer PCH-LP B Firmware v15.0.2.1377
Intel CSME 12.0 Corporate PCH-H B,A Firmware v12.0.70.1652
ME Dynamic Application Loader driver only version 1.38.2020.805 for Windows 10:
https://ufile.io/12nneh93
Sadly, after the update, Windows won’t utilize the TPM of my machine, saying, “Can’t get TPM information” even after a few TPM resets.
Intel CSME 13.0 Consumer PCH-LP D Firmware v13.0.40.1594
Intel PMC ICP PCH-LP D Firmware v130.1.30.1051
@ eray:
What TPM were you using? The one CSME provides or a third party chip embedded in the board? From the CSME side, run MEInfo -verbose and MEManuf -verbose to check for any irregularities/errors. Also, try a Flash Programming Tool “fptw64 -greset” to see if it helps. It could also be a BIOS issue. Make sure it’s up to date and restore defaults once before re-adjusting whatever you want there.
@plutomaniac
ME Analyzer 1.160.0 r212 reports ME firmware 12.0.70 Corporate not in database, and that I should report it.
Doing that as I am told
@plutomaniac
Hello!
I am certain that my computer uses the TPM feature provided by CSME and Intel, as from my research about INTC TPM.
I tried the command above, TPM resets in the UEFI, multiple reflashes with PTT enabled in FIT, re-installing the latest BIOS, and even re-keying meant for ME firmware 11, but to no avail. One thing left to do is re-installing Windows because I am on the Insider Dev channel. I feel confident that HP is going to release a newer revision with updated CSME firmware.
Sadly, the current CSME firmware version cannot be downgraded.
CSME logs.txt (9.69 KB)
I don’t know. The firmware is just fine according to MEInfo and MEManuf. It could be Windows, try a stable version. Otherwise, some BIOS issue I assume ("incompatibility", weird HP stuff?).
Intel CSME 15.0 Corporate PCH-LP B Firmware v15.0.10.1405
Intel CSME 14.0 Consumer PCH-LP B,A Firmware v14.0.46.1431
Intel CSME 14.0 Corporate PCH-LP B,A Firmware v14.0.46.1431
I guess it was a coincidental issue with Windows. Updating to the newest 20241 build fixed it.
Intel CSME 11.8 Consumer PCH-LP C NPDM Firmware v11.8.80.3746
Intel CSME 11.8 Corporate PCH-LP C NPDM Firmware v11.8.80.3746
Hi friends. which version is good for ASUS Z170-A ?
thanks.
@ErfanDL :
Which version of what (driver/Firmware/System Tools) do you mean?
Intel CSME 12.0 Consumer PCH-LP C Firmware v12.0.70.1652
@plutomaniac isn’t 2035.15.0.1807 the latest MEI driver instead of v2031.15.0.1743 posted at the start post?
@snixel Well, yeah it is. I was reluctant to link these drivers because I was seeing some strange changes to the INF file and thought maybe they were a test/beta version. But I guess it is some new method by Intel because I’ve seen it at two newer MEI drivers now. I’ve added them to the OP now, thanks to SD of course (Pacman, Fdrsoft) for keeping an eye out for these.
Intel MEI Drivers & Software v2037.15.0.1840 DCH (Windows 10 >= 1709)
Intel MEI Driver v2035.15.0.1807 (Windows 10 >= 1709)
