Intel (CS) Management Engine: Drivers, Firmware and Tools (2-15)
Give more information like MEA output of bios firmware you want to upgrade, all firmware files you used, machine/board you’re working on, link to a firmware, post your own ME region, pull an update file of your existing ME region with fwupdlcl -save and post it/attach it, whatever.
You should present your problem in a proper way with all the details available to make people answer…
And as written: With the information you posted it’s impossible to give you a proper answer…
okay, lets to try…
attached all files in the archive win32.
ME report too. please ask me if other info you required…
WIN32.rar (1.79 MB)
@Kolich If I follow Intel (Converged Security) Management Engine: Drivers, Firmware and Tools => How to use FWUpdate Tool at CSME v13+: precisely word for word I don’t get any error messages when creating an update image.
I assume your error lies in choosing the correct chipset platform here or you make an error when loading the CSME firmware?
║ ME Analyzer v1.253.0 r262 ║
║ FWUpdate_2.bin (1/1) ║
║ Family │ CSE ME ║
║ Version │ 15.0.30.1902 ║
║ Release │ Production ║
║ Type │ Extracted ║
║ SKU │ Consumer H ║
║ Chipset │ TGP/EBG-H A ║
║ TCB Security Version Number │ 1 ║
║ ARB Security Version Number │ 3 ║
║ Version Control Number │ 11 ║
║ Production Ready │ Yes ║
║ OEM Configuration │ No ║
║ FWUpdate Support │ Yes ║
║ Date │ 2021-07-08 ║
║ File System State │ Unconfigured ║
║ Size │ 0x32C000 ║
║ Flash Image Tool │ 15.0.35.1932 ║
║ Latest │ No ║
║ Power Management Controller ║
║ Family │ PMC ║
║ Version │ 150.2.10.1019 ║
║ Type │ Independent ║
║ Chipset SKU │ H ║
║ Chipset Stepping │ B ║
║ TCB Security Version Number │ 0 ║
║ ARB Security Version Number │ 0 ║
║ Version Control Number │ 0 ║
║ Date │ 2021-05-20 ║
║ Size │ 0x26000 ║
║ Manifest Extension Utility │ 15.0.10.1302 ║
║ Chipset Support │ TGP ║
║ Latest │ Yes ║
║ Platform Controller Hub Configuration ║
║ Family │ PCHC ║
║ Version │ 15.0.0.1021 ║
║ Date │ 2021-04-28 ║
║ Size │ 0x1000 ║
║ Manifest Extension Utility │ 15.0.30.1716 ║
║ Latest │ Yes ║
║ USB Type C Physical ║
║ Family │ PHY ║
║ Version │ 12.14.214.2014 ║
║ SKU │ P ║
║ Date │ 2021-04-01 ║
║ Size │ 0x6000 ║
║ Manifest Extension Utility │ 15.0.0.7069 ║
║ Latest │ Yes ║
║ Family │ CSE ME ║
║ Size │ 0x32C000 ║
║ Latest │ No ║
║ Family │ PMC ║
║ Chipset SKU │ H ║
║ Size │ 0x26000 ║
║ Latest │ Yes ║
║ Family │ PCHC ║
║ Size │ 0x1000 ║
║ Latest │ Yes ║
║ Family │ PHY ║
║ SKU │ P ║
║ Size │ 0x6000 ║
║ Latest │ Yes ║
i have this problem when i building image for FWupdate.
can you provide to me this image for flashing my notebook? :)
may be problem in win11 which i use ;)
I don’t think that’s the reason. And if you do really think the ME tools work differently on Win11 you shouldn’t use FWUpdLcL either until it’s confirmed working properly on Win11
And I’m sorry, that was just proof of concept that things do indeed work as expected- I deleted the files already again.
can you rebuild for me this file again?
FWupdate working correctly, i already flashed previously firmwares. Can you help me?
FWUpdLcL working correct, because already used many times before. it so hard for you rebuild this file for me?
i think i found problem, you used another samples, i attached screenshot, in the manual said i need just use Tiger H chipset without others…
║ Family │ CSE ME ║
║ Size │ 0x32C000 ║
║ Latest │ No ║
║ Family │ PMC ║
║ Chipset SKU │ H ║
║ Size │ 0x26000 ║
║ Latest │ Yes ║
║ Family │ PCHC ║
║ Size │ 0x1000 ║
║ Latest │ Yes ║
║ Family │ PHY ║
║ SKU │ P ║
║ Size │ 0x6000 ║
║ Latest │ Yes ║
done! i setup same like you in up on the screen :) and bin file compilied successfully.
Good to hear that you managed it! (Actually the manual doesn’t say anything specific about TigerLake, but you’re right, there are 2 choices for "H", difference is Mobile or Desktop chipsets.)
yeaaa, you right… are you have changelog for this version? and what another controllers which i can will flash? :slight_smile:
Hello everyone ,
I own a Z490E from Asus and I’ve installed 14.1.60.1790 on a fresh windows install , since then system doesn’t feel responsive like it used to , my previous me firmware was 14.0.45.1389 .
It’s the first time I encounter this problem and I don’t want to broke my motherboard , I’ve already reed the thread explaining the procedure but it’s seem complicated , could someone guide me here or pm me please ?
Latest ME Fw on Asus website is Version 14.1.53.1649V1.1. What did you exactly do? How did you update, which files and tools did you use?
I used a most recent one on the asus forum (can’t post link here) and updated with FWUpdLcl64
Was this update firmware made specifically for your board? Did you check the components of the update firmware with MEA?
║ ME.bin (1/1) ║
║ Family │ CSE ME ║
║ Version │ 14.1.53.1649 ║
║ Chipset │ CNP/CMP-H A ║
║ ARB Security Version Number │ 9 ║
║ Date │ 2021-03-04 ║
║ File System State │ Configured ║
║ Size │ 0x2DD000 ║
║ Flash Image Tool │ 14.0.53.1649 ║
║ Latest │ No ║
║ Family │ PMC ║
║ Version │ 140.2.01.1018 ║
║ Chipset SKU │ H ║
║ Chipset Stepping │ A ║
║ TCB Security Version Number │ 3 ║
║ Date │ 2021-02-22 ║
║ Size │ 0xE000 ║
║ Chipset Support │ CMP ║
║ Latest │ Yes ║
║ Family │ PCHC ║
║ Version │ 14.0.0.7002 ║
║ Release │ Production, Engineering ║
║ Date │ 2020-06-12 ║
║ Size │ 0x1000 ║
║ Latest │ Yes ║
║ Family │ PHY ║
║ SKU │ P ║
║ Size │ 0x6000 ║
║ Latest │ Yes ║
║ 14.1.60.1790.bin (1/1) ║
║ Family │ CSE ME ║
║ Version │ 14.1.60.1790 ║
║ ARB Security Version Number │ 10 ║
║ Version Control Number │ 26 ║
║ Date │ 2021-08-18 ║
║ Size │ 0x2DD000 ║
║ Flash Image Tool │ 14.0.60.1790 ║
║ Latest │ Yes ║
║ Family │ PMC ║
║ Chipset SKU │ H ║
║ Size │ 0xE000 ║
║ Latest │ Yes ║
║ Family │ PCHC ║
║ Size │ 0x1000 ║
║ Latest │ Yes ║
║ Family │ PHY ║
║ SKU │ P ║
║ Size │ 0x6000 ║
║ Latest │ Yes ║
I’ve the iCLS 1.63.1155.0
where can I found the latest intel iCLS v1.63.1155.1?
Google it & only found this link
https://github.com/intel/INTEL-SA-00086-Linux-Recovery-Tools
[email protected]
[email protected]
Already got that from MEI v2141.16.0.2514 package.
Still, thank you.
Don’t think anything with ME would make a difference to that.
