@lfb6 , @GlitchyHack , Thanks for your help. Yes, I got error 433 when using the CSME file from the first page. I have read the first post regarding updating CSME12. This procedure is too complex for me. When using the CSME file offered from @GlitchyHack the error does not appear and firmware update is OK:
My laptop didnât restart upon wake for a long time as I can recall, since I updated to version 11.8.92.4222, after 4 days, my laptop did restart upon wake up, although it happened just once among hundreds of sleeping and waking up, but that is not a good sign I really hope it is not the new firmware and it will not happen again
Maybe someone can explain to me, why since v12 CSME a CSME update canât be done at the same time than a BIOS update ? My systems will shutdown, instead of restart, and then neither BIOS update nor Intel CSME update was updated? Everytime I have to do first a BIOS update , reboot, Intel CSME update, reboot - or viceversa. Hm
@plutomaniac Attached find the TGP N 11.225 PHY I was missing on the list of the start page. Maybe it will help someone ?
Greetings, I have a Dell Ins 5593 with i7-1065G7 ME Info: Intel(R) ME code versions: BIOS Version 1.19.0 Vendor ID 8086 MEI Driver Version 2131.1.4.0 FW Version 13.0.55.1889 LP Consumer LMS Version 2130.1.16.1 IUPs Information PMC FW Version 130.1.30.1051 OEM FW Version 0.0.0.0000 IOM FW Version 4.12.0.0000 NPHY FW Version 9.0.1.0003 TBT FW Version 13.0.0.7103 PCHC FW Version 13.0.0.1005
When I tried to make an image to update ME (with ME img, PMC and PCHC), FIT give me issues about missing IOM. Can I get it somewhere, or take it from my current machine? Also Can I update NPHY and TBT? It is strange to see TBT on a system without Thunderbolt.
If I use the last tab on the left side âFW Udate Image Buildâ thereâs no complaint at all. If I look into the ME update file of the original Dell update package the only difference is that MEA states âOEM Configuration Yesâ for the Dell upgrade file. This OEM partition is different for every ME included in bios 1.17 to 1.19 and contains a signed manifest (?), so wouldnât make sense to copy it.
I have an BIOS that is locked from Advanced Features which I would like unlocked.
I have installed Intel ME drivers and software, downloaded what I thought was the correct CME for this (CSME v16.0.r7). I have greatly misunderstood all this and donât know enough. I have installed python 3.10.4 and downloaded the MEA.py from the link provided but could not install it as prescribed at the page for MEA.py download.
Installed are the prerequisites as prescribed there with the past command failing with âpysinstaller is not found to be an internal command or could not be found.â < close to this.
I have a few snapshots but it looks like cannot upload here? from HWINFO64 and when I tried to run the command âpyinstaller --noupx --onefilfe MEA.pyâ.
What do I need to do next? Would please help? Thank you kindly stumanchu
Which is this link⌠https://www.station-drivers.com/index.php?option=com_remository&Itemid=352&func=fileinfo&id=3435&lang=en
Doesnât appear functional anymore. Or I canât figure out how to get it to work. Is this just gone? I already tried a Google search and am not sure of a valid replacement. I think there was a Lenovo link I didnât try yet, but⌠A couple others failed similarly (acted like it existed, but trying to download failed).
I know everyone is very busy with the new forum, but maybe someone has an answer to my question posted before ?
Maybe someone can explain to me, why since v12 CSME a CSME update canât be done at the same time than a BIOS update ? My systems will shutdown, instead of restart, and then neither BIOS update nor Intel CSME update was updated? Everytime I have to do first a BIOS update , reboot, Intel CSME update, reboot - or viceversa?
Iâve fixed all the (Intel & SD) broken old driver links at the OP.
@ FM1, MeatWar
The migrated posts are a completely different experience, compared to the ones weâre natively (to this platform) creating now. New posts should work automatically with light/dark theming, but old ones are their own thing. There are various issues: format is ugly/raw html and needs manual conversion to MD or bbcode, colors need to be removed for proper visuals, some html elements are deprecated but were still allowed at the old forum software, so they may break without careful adjustments etc. Basically, all important/complicated old posts need some (probably manual) love by their creators to look good here. That is to be expected when migrating from such an old/deprecated/proprietary forum software. Anyway, still WIP. These will be fixed in time. Focusing on the more important things for now.
@ FM1
How CSME/BIOS updates are handled is vendor-specific for the most part. Some other systems may work exactly as you described, others not.
Here is the corresponding security bulletin from HP:
HPSBHF03793
I can see the CSME firmware is integrated into the .bin files from newer BIOS (e.g. 14.1.65.1969). But I myself can not extract it, but someone can maybe?
The FW versions at the OP are up-to-date based on what has been found so far (including HP). When 14.1 CON H becomes available, it will be posted here.
