Is it possible to āunstitchā that firmware update?
I already know how to use Intel FIT to create a suitable update, but I havenāt seen just the CSE ME binary for 15.0.45.2411 Consumer H yet. In fact, this stitched update from Station Drivers would work for me if it wasnāt for the PHY part, which is different from what my laptop requires (on the other hand, the CSE ME, PMC and PCHC are suitable)ā¦
Afaik the PHY block is just ācopiedā inn, so you might look into the ME partition table and just exchange the area. But Iām still wondering which versions you need?
(You might stitch an older CSME version with the two different PHYs and look if there are differences in the non-PHY areas to be completely sure. And make a backup before updating!)
Iām currently running CSE ME 15.0.42.2384 (Consumer H, TGP/EBG-H B), PMC 150.2.10.1020 (Chipset SKU H), PCHC 15.0.0.1021 and PHY 15.107.135.5018 (SKU N).
The 15.0.45.2411 version which surfaced recently has the updated CSE ME (same variant and SKU), exactly the same PMC and PCHC versions, but a different PHY (12.14.215.2015 for SKU P). Everything (apart from the PHY) is correct for my laptop, only the PHY is not suitable (I need SKU N).
Last time I manually stitched an update for this laptop, I found separate binaries for the CSE ME, PMC, PCHC and PHY from the repositories linked here on Win-Raid, so it was just a matter of stitching them with Intel FIT and then applying the resulting binary with FWUpdLcl64. This time, however, I couldnāt find a separate CSE ME binary for 15.0.45.2411 Consumer H, hence my question if it was possible to isolate only the CSE ME part from the existing update published recently on Station Driversā¦
@Anton35
What you propose did work for the ME 15 discussed, but doesnāt work for this image (ME 14 Corporate H), I get this:
** WARNING **
FW image for FW Update was NOT created!
Reason: CSE FW from a decomposed IFWI image was used.
Action to fix the situation:
To have the FW Update image created, use the original Intel CSE image included in the ME FW Kit as released by Intel.
I have not read all the posts so dont know if this is mentioned or useful to anyone.
If so; plz feel free to delete this post.
Intel ME 11.x Firmware Images Unpacker:
ā⦠The researchers discovered an undocumented field called āreserve-hapā and that HAP could be set to ā1ā for true. Apparently, the NSA wanted to ensure the agency could close off any possible security risk by disabling Intel MEā¦ā
Creating an update file for your machine?
There are no settings transfered in update files so if the details are identical (corp/cons, LP/H, versions of PHY PMC PCHC) an update file should normally work (but ā¦)
Creating a clean ME firmware region for you machine?
You canāt, you need the original configuration of your machine from a firmware dump of your own machine and following the cleaning procedure linked in this subforum or you can extract a stock ME region from a complete stock firmware image (which I doubt Lenovo provides)
The first option. Iāve been updating the ME firmware manually from time to time since HP is a bit slow at updating when it comes to consumer hardware. Plato has been providing us with Extracted firmware images (No 12.0.93.xxx yet) that need stitching through the Flash Image Tool from Intel. Can I directly flash the Lenovo ME firmware on my HP laptop? Many Corporate versions seem to include extra Thunderbolt, camera, and wifi modules that my laptop doesnāt support. Do consumer builds come with those as well?
