Intel has no revisions for their CSME System Tools packages. The idea of numbering CSME System Tools with revisions was used by the person who was posting them on this site - Platomav. If he doesn’t post them anymore, then accordingly there are no more new revisions. But the Intel did not stop releasing new ME firmware as well as new versions of System Tools with them. So if you want to find them you should look exactly for System Tools with major.minor.hotfix.build version you want, but not for the mythical revision which doesn’t excist.
Meatwar, I was going to let your last AI screed go, but then I saw this little ditty, so here goes. It’s going to be better to stay away from me. You are by far the most surly person I’ve ever run across on any forum I’ve been on, and I’ve been on a few in my day. For the record, I’ve really put you on “ignore”, because I’ve never seen you give any advice that I’ve found useful. Half the time, you’re telling people to go pound sand anyway.
I don’t care if I annoy you. Then again, who doesn’t annoy you?
That’s exactly what I was doing - giving folks a heads up to be on the lookout for a new new one, with some info to back it up. And you can bet your bottom dollar that I’ve done plenty of digging, and will continue to do so.
I don’t need you to call me out over BS because you can’t control your temper. So from now on, just walk on by.
15.0.50.2633_CON_H_B_PRD_EXTR_859E269A
15.0.50.2633_COR_H_B_PRD_EXTR-Y_F969B3D2
15.0.50.2633_COx_H_B_PRD_EXTR.rar (7.0 MB)
FIT 15.0.35.1951 had a problem when decompressing the source files. Hopefully these files can be used regardless.
thanks a lot for keeping this threat up2date!
small little question, is this fw 15.0.50.3633 also available for COR_LP platforms (lenovo T15 - i7 gen11)?
Thanks again
For at least the consumer extract (15.0.50.2633_CON_H_B) the PCHC component (15.0.0.1021) is still included in the binary. Using FIT 15.035.1951 I’m having difficulty removing the additional partition and am ending up with two Platform Controller Hub Configurations. Is there an easy way to post the MEI extract without the additional PCHC partition? Thanks!
15.0.50.2633_COR_H_B_PRD_EXTR-Y_F969B3D2.rar (5.5 MB)
15.0.50.2633_CON_H_B_PRD_EXTR_859E269A.rar (1.7 MB)
CSE ME 14.1.75.2420 Cons LP.zip (1.8 MB)
CSE ME 15.0.50.2633 ConsLP.zip (1.7 MB)
CSE ME 15.0.50.2633 ConsLP TGLR.zip (1.7 MB)
The second file reads completely identical in MEA but it’s not. Marked TGLR from Dell: :
From Inspiron 14 5410, Version=2.30.0, Model=0B23,0B23,0B24,0B24,0B25,0B26
15.0.50.2633_CON_LP_B_PRD_EXTR.rar (1.7 MB)
@lfb6
Why did you delete them? I guess you would have posted the same ones.
Yep, but when I edited my post and changed it to ‘answering to thread’ instead to a person, it automatically goes from ‘edit’ to ‘reply’. And when editing first post third time it seemed to me it had taken the changes, but didn’t.
Now the reason I posted this again is that Dell had this different(?) TGLR file, 3 different hashes in the CSME when unpacking. But I don’t think the CSME itself is different, the complete update files are stitched differently:
PHY N 16.107.126.3011 vs. 11.225.276.2043
PMC 150.1.20.1041 vs. 150.1.20.1042
15.0.50.2633_COR_H_B_PRD_EXTR-Y_8BB51F54.rar (5.6 MB)
FIT does not like it at all. ![]()
Fit 15 is weird, you have to set it to the right chipset…
But there are different 2 CSMEs here, but I think the difference is just the order of the WCOD partitions.
CSE ME 15.0.50.2633 CorpH TGPEBG-H B_2.bin.zip (6.0 MB)
CSE ME 15.0.50.2633 CorpH TGPEBG-H B_1.bin.zip (6.0 MB)
12.0.96.2562_COR_H_BA_PRD_EXTR-Y_1705B8E2.rar (4.5 MB)
14.1.75.2420_COR_H_A_PRD_EXTR-Y_C317DC35.rar (4.2 MB)
14.5.55.2259_CON_V_A_PRD_EXTR_11A68F52.rar (1.8 MB)
15.0.50.2633_CON_H_B_PRD_EXTR_9C345C79.rar (1.8 MB)
How are you getting these unconfigured prestitched updates? I have to cut out IUPs manually every time. Share the source file please, i’ll decompose it correctly.
If you’re lucky, you might even find one of these. As previously advised, I use FIT. I can’t spoil anything as I just feed it and share.
@westlake If you run those files through MEA again it’ll show you the CSME and the still included/ not removed IUPd. Check for the given length and search in a hex editor for the IUP name, mostly PCHC and PHY.
They should always start at 0x*00. Just delete the given length. MEA should now show just the CSME.
Had this for the first time for CSME 14, too. Maybe the tools are getting too old?
