If it comes from Dell, it could be customized for Dell and not other brands.
Hi. Iām trying to clear ME in lenovo yoga 9i and its firmware version is 14.1.70.2228_CON_H but I cannot find exact repository. The closest one I found is 14.1.70.2228_CON_LP and 14.1.75.2420_CON_H. Please help!
Thereās no rule about which version old or newer you have to use, except for CSME 15 itās kinda tricky with FITc.
14.1.77.2497_Both_Lenovo.rar (5.8 MB)
Unfortunately none of the public FIT 14s āeatā it.
Need to cut top and end blocks but less work by using the content of original Lenovo files
L13 Laptops (ThinkPad)
https://download.lenovo.com/pccbbs/mobiles/r15rg11w.exe
Does that mean I can use any repository from those two I have mentioned, or those MeatWar Moderator and westlake mentioned?
Same two, but the ones I linked have āredundantā data. The package linked by MeatWar contains files that are already handled by FIT. The files below are (easier) to work with.
Hello, do you have any reservations about the Intel CSME System Tools v11 r36 toolkit? If possible, please send me a copy. Thank you very much!
What reservations⦠read the guide and youāll find the correct links in section:
C2. (CS)ME System Tools
If it works with r36 it also works with r46ā¦
Hello,
I“m looking for a CSME 12.0.96.2562 (Corp-H) update for a Gigabyte C246-WU4 which only has vendor update for 12.0.95.2489. Supermicro X11SCA have 12.0.96.2562 (Corp-H) update. Is it possible to generate a update file (CSME only) or BIOS that is compatible with C246-WU4 ?
Thanks.
From the guideā¦
" Engine Firmware Regions (RGN/EXTR):
The Type of each Engine/(CS)ME firmware Region can be either Stock (RGN) or Extracted (EXTR) . Stock are clean/stock/unconfigured images provided by Intel to OEMs. Extracted are dirty/extracted/configured images from various SPI/BIOS. The Engine firmware at the systemās SPI/BIOS chip is always EXTR , generated by the OEM after configuring the equivalent RGN with the appropriate system settings."
Not advisable but you can try it and re-initialize the engine with your OEM settings, ensure that you know how to recover the system by any unexpected results.
Stillā¦the repository has the pretended FWā¦
In the collection since 4/13/2025. Why donāt you use it if someone is already bothering to bother with it?
FWUpdLcl64 11.8.97.4720 (2024.06.27)
FWUpdLcl64.rar (507.7 KB)
Hello everyone.
Please help with me region 14.1.74.2355 consumer LP CNP/CMP-LP B,A
Edit by Fernando: Thread moved into the āIntel Management Engineā Forum Category and thread title customized
āHELPā on what⦠no wizards here sir.
sorry if i asked the question incorrectly, i need me region 14.1.74.2355 consumer LP CNP/CMP-LP B,A share if possible
@Danya
Some where in this thread or @SD Intel Management Engine (ME) Firmware Version 14.1.74.2355 (LP)
