That’s exactly my point and my concern (curiosity)…
Thanks for reviewing. Yes I can confirm this was a BIOS file from ASRock support. They kindly sent me this version after I asked if there were any further CPU microcode or Intel ME updates available.
@OctopusNZ
Thank you for your clarifications and shared file/info, all the best.
Thanks for the file, ME FW seems to be running smooth on my spare MSI Gaming plus Z390.
Thanks! When trying to clear the ME region of the BIOS using FIT, I get the following errors: “Error 242: [Ifwi Actions] Failed to validate Key Manifests. The public key in the OEM Key Manifest provided does not match the hash provided in “OEM Public Key Hash”
Error 21: [Csme Binary Gen] Error executing post-build actions.
Error 2: Failed to build.
Failed to build!” May I ask what I’m doing wrong? I think I have to replace the “ME Sub Partition” file in the decomposed files folder with the “ME_15.0_Corp.bin” file in the .zip, changing its name?
Awesome - glad it is working for you. Full credit to ASRock support and BIOS team for being kind and continuing to support my much older board still.
A post was merged into an existing topic: ME Analyzer: Intel Engine Firmware Analysis Tool Discussion
