Okay, I understand now. My file contains all of them, because I added them after posting them here. Just as anyone else can do it, just as you could have done it. So they are indeed not included in the factory r376, but that doesn’t change the essence: all 15 versions you posted are unnecessary, because I already did it before. You could have taken the trouble to check back.
I will help you avoid unnecessary posting in the future: MEA.rar (158.1 KB)
I couldn’t add them because the collection we have access to only includes the latest versions. Also for every file I posted I searched the entire forum and didn’t find them. I was always checking before posting.
That being said Thank you for the updated database. I’ll work with it to spot the versions that are already available. That will save me a lot of time
Hey @westlake . When I run your 15.0.55.2751_CON_LP_B_PRD_EXTR_D726C130 through MEA, it gives me the structure that you would expect: a single main section, a single Power Management Controller section, a single Platform Controller Hub Configuration section, and a single USB Type C Physical section. The size is 3,887 KB.
In most cases, whenever I extract the same version 15 Consumer LP ME firmware from a Dell BIOS update and run it through MEA, I get 2 identical Power Management Controller sections, 2 identical Platform Controller Hub Configuration sections, and 2 identical USB Type C Physical sections. The size is always larger, which makes sense.
Do you know why there’s a double-up in these Dell ME firmware sections?
I would like to use the Dell ME firmwares to update another Dell that is no longer receiving bios updates, that doesn’t produce the MEA double sections result, but that would seem to be a questionable move.
I’m attaching the MEA for a Latitude 3420 as an example. Thanks.
Thank you both. I figured it was a mistake by Dell, but it’s interesting that the same mistake applies to more than 1 extracted Dell ME 15 Consumer LP firmware update. I’ll have to play with FIT 15 (to maintain OEM Configuration - Yes, assuming it matters).
When I ran it through the latest posted FIT 15, it did knock out duplicates of everything, except Platform Controller Hub Configuration. Maybe it doesn’t matter, and maybe Dell has the same type of FIT 15 hiccups that others have noted in this thread. FIT 12 just always seems to be more stable/reliable than 15.
You made a bad BIOS backup that was the reason. I faced the same issue recently, fixed his, and fixed yours too if you want to try it and see if it works.
Hello. I’m an electronics hobbyist and I’m trying to repair the BIOS on my Dell Latitude 5520 laptop. I’ve been trying to clean up the ME region, but I can’t find a compatible version of Flash Image Tool for this version. I’ve tried versions 15.0 and 15.4, but it still doesn’t work. What am I doing wrong, or where can I find the correct version? I get the following error on every version I’ve tried:
Error 179: [Fit Actions] Failed to parse CSE region.
Error 10: [Ifwi Actions] Failed to decompose Region. Failed to decompose CSE data.
Error 18: [Ifwi Actions] Failed to generate decomposed files. CSE Region
Whoever is maintaining the Mega folder, maybe put back the 12.0.97.3000 version, since folks like me will need it for getting up to date the first time
