26.2 has some (cosmetic?) issues. Functionality seems OK. But this hardware test, Hardware Tests>Interrupt Status fails on 26.2. Reverting to 26.1 fixes it. You need PROset installed to see it I believe, not just the driver.
OP Updated!
Complete Pack:
v26.2
"Pure" Drivers Pack:
i225 Adapters -> 1.0.2.8
i210, i211, i350 Adapters -> 12.18.12.1
OP Updated!
i217, i218, i219 Adapters -> 12.19.1.37 (Thanks Station-Drivers)
I am doing a fresh install of Windows 7, and funny enough I cant find any wireless drivers.
I need a driver for:
- Intel(R) Dual Band Wireless-AC 3169
- Intel(R) I211 Gigabit Network Connection
and just incase:
- Intel(R) Ethernet Connection (7) I211-V
P.S: I don’t need Bluetooth drivers, I have them all
edit: wait what why is this here now
Because
a) the Intel(R) I211 Gigabit Network Connection drivers use a wired connection and
b) a complete driverpack for Intel Ethernet Controllers (inclusive the Intel I211 adapter) is offered within the start post of this thread.
If you are searching for a specific Intel Wireless WiFi driver, which supports Win7, you should
1. post your request into >this< Sub-Forum and
2. not forget to mention the HardwareIDs of the related WiFi Controller.
I still need these drivers though:
EDIT: nvm i made a subforum post
hi guys any idea why Intel(R) Ethernet Connection has so many number prefix behind? (1) (4) or (7) etc. are they different revisions or something?
Intel Network Connections Software 26.4
OP Updated!
Complete Pack:
v26.4
i225 Adapters → 1.0.2.13
i217, i218, i219 Adapters → 12.19.1.37 Revision 1.
Hi everyone!
OP Updated!
i217, i218, i219 Adapters → 12.19.1.37 Revision 2.
Release note: Fix LAN slow speed issue Windows 10/11
Thanks for share this useful information. I try this solution it’s helpful for me. because my LAN card automatic connects or disconnects much time during the working on chic ita bag tote shopping.
Intel forgot to change the driver version. Users, who had already installed the Rev.1 driver, may get the message, that "the best driver is already installed", when they try to update it.
Tip: To get the Rev.2 driver installed you may have to force the procedure by using the "Have Disk" button.
Hey everyone!
OP Updated!
What changed:
i225 Adapters → 1.0.2.14
Complete Pack → 26.4 Rev. 2
Just a heads-up that Intel ANS Teams and VLANs will not be supported in Windows 11: https://www.intel.com/content/www/us/en/…t-products.html
Guess no point waiting for Intel to update PROSet for Windows 11 if you want those features.
Hi to everyone!
I was looking for the driver for Intel I-225V. I only found drivers for Windows 7 or 10, but I need it for Windows 8.1.
I tried to remove things from the complete pack 25.0 (the last one working for Windows 7). But it doesn’t seem to be compatible.
I have a ASUS Rog Z490-H
I hope you can help me
Thanks in advance
Best regards
