I217V in Win Server 2008 R2?
Win7 drivers for win server 2008 R2 are not working.
Any idea?
@Jean78
>Here< I have found something, which may help you to solve your problem.
Good luck!
Sorry for my late reply.
Did you find the i226 driver?
I have I225-V onboard and would like to
Enable RSS and RDMA.
Unfortunately it is not active in the driver.
Found this here:
Can someone help me make a MOD driver to activate this?
Thanks
Best regards
Use the driver I225 1.1.3.28.
The others don’t support rss and also the new driver from realtek also nics don’t support it.
This is something to do with e cores and p-cores incompatibility so they disabled it.
@Fernando Sorry to bother you, men. I have an Killer E2400, but I cant find any drivers for this card, can you help me find it? Also the driver that is auto-detected by Windows Update I doesnt have some settings as the common ones, for example, Interrupt level (low, medium, so on…) Only the On or Off option, and more, thank you in advance, youre such a goat
@angelovski
>Here< is a driver link (hoping, that it will help you).
Thank you! I will download it and compare it with the windows update one
