ME Analyzer v1.6.5 & DB r66
Performance:
0.73 sec
0.15 sec
Improvement: 80%
2.05 sec
1.46 sec
Improvement: 30%
2.05 sec
0.15 sec
Improvement: 1350%
Note 1: UEFIFind is not included with MEA anymore by default. If you want to use Engine GUID detection (-enuf) then make sure to include it alongside MEAâs executable.
Note 2: Most people use default settings with no parameters so they should see the 1350% improvement at MEA v1.6.5. People who had UEFIFind disabled (UBU and UEFIStrip) will see an 80% or so improvement . Even with UEFIFind Engine GUID detection enabled, you should expect at least 30% improvement.
@SoniX @lordkag
Remove the old â-disufâ from UBU and UEFIStrip as UEFIFind Engine GUID Detection is disabled by default now. If you want it enabled somewhere, use â-enufâ instead. MEA will ignore any â-disufâ parameter/filename input until your tools are adjusted accordingly.
ME Analyzer v1.6.6 Dev 1
Fixed issue that caused temporary files to not be deleted
Note: You should clean your %temp% folder and update MEA
Note: Affected versions are v1.6.3 - v1.6.5
@SoniX
Please update UBU with this Dev version
Can I use MEA to update the MEI fw in a BIOS file?
ME Analyzer v1.7.0 Dev 35 RC & DB r75 Dev 3
The next version of MEA is almost ready with big changes all around. So please test and let me know of any issues.
ME Analyzer v1.8.0 & DB r75
v1.8.0
Added Engine firmware size validation and display
Added ME 11.x FIT SKU detection (11.0 - 11.6)
Added $FPT header checksum validation check
Added $FPT Entry Counter validation check
Added Manifest detection from $FPT directly
Added parameter to display $FPT header details
Added early support for TXE 3.x APL firmware
Added ME 11.x Flash Descriptor EC lock detection
Added info to fix FWUpdate-buggy ME 11.x images
Added SPS 3.x $FPT checksum validation check
Added support for ME2-ME6 SPI Flash Descriptor
Added support for ME 6.x ROM-Bypass firmware
Improved detection & analysis of $FPT header
Improved VCN detection of post-SKL ME,TXE firmware
Improved Engine Release detection (PRD/PRE/BYP)
Fixed wrong Engine $FPT selection when multiple exist
Fixed wrong error messages at special TXE 1.x images
Fixed various code issues and errors under rare cases
Removed irrelevant info shown at Partial Update images
Removed option to extract Dell HDR RBU ImagME Regions
Removed option to print whole DB without SHA1 hashes
Removed option to encode all textual output to Unicode
MEA now pauses automatically at unexpected exceptions
Various code optimizations and performance improvements
Updated Engine Firmware Repository Database to r75
r75
Latest ME 11.6 CON LP SKU to 11.6.10.1196
Latest TXE 2.1 1.375MB SKU to 2.1.5.3105
Added ME 11.6.10.1196_CON_H_D0_NOPDM_PRD_RGN
Removed ME 11.6.10.1196_CON_H_D0_NOPDM_PRD_EXTR
Added ME 11.6.10.1196_CON_LP_C0_UKPDM_PRD_EXTR
Added ME 11.6.1.1142_CON_H_D0_UKPDM_PRD_RGN
Removed ME 11.6.1.1142_CON_H_D0_UKPDM_PRD_EXTR
Added ME 11.6.1.1142_CON_LP_C0_PDM_PRD_RGN
Added ME 11.6.0.1121_CON_H_D0_NOPDM_PRD_RGN
Added ME 11.6.0.1121_CON_LP_C0_NOPDM_PRD_RGN
Removed ME 11.6.0.1121_CON_LP_C0_UKPDM_PRD_RGN
Added ME 11.6.0.1121_CON_H_D0_NOPDM_PRE_RGN
Added ME 11.6.0.1121_CON_LP_C0_NOPDM_PRE_RGN
Renamed ME 11.0.18.1002_CON_H_D0_NOPDM_PRD_RGN
Added TXE 2.1.5.3105_1.375MB_PRD_EXTR
Added SPS 04.00.03.137_PRD_REC
Added SPS 04.00.03.137_PRD_OPR
Hi, it seems that ME Analyzer v1.8.0 & DB r75 wrongly detects size of ME FW blob in my case.
File: P67DS_F5.BIN
Family: ME
Version: 7.1.20.1119
Release: Production
Type: Region, Extracted
FD: Unlocked
SKU: 1.5MB
Date: 08/08/2011
Platform: CPT
Latest: No
But FIT 7.1.60.1191 unpacked ME Region.bin file only 839680B and when I checked with hexaeditor I can see only FFh blank behind 839680+4k descriptor offset. FIT doesnât show ME size anywhere. Iâm not sure if itâs right as other 7.x ME FW blob, e.g. 7.1.80.1214 has 1335296B. Maybe GB used some stripped version? You can check yourself, BIOS image is
here
I havenât tested the file but I know MEA is correct. If you load the FITC âME Region.binâ at MEA youâll see a Warning about possible data loss. FITC v2 to v10 used to cut all the padding from extracted ME images even if that violated region boundaries. Before reinserting the file back to the BIOS/SPI image, FITC would just readd the padding. Stupid but thatâs how it worked. MEA detects the size intelligently from what the actual firmware reports. At bare Engine regions it can check for extra (useless) padding, less (possible data loss) padding and at full SPI images it can check if there are extra/unknown data after the ME firmware size but before the ME region actually ends as described at the Flash Descriptor.
Is the total ME size stored inside the blob or you have to calculate it according parsig the ME partition table or so? Yeah, interesting that FIT is cutting the paddings. I see more ME FW blobs that differ slightly in size, seems thereâs no standard. But it it seems to be safe to cut off unnecessary padding as when inserted to flashROM empty pages are blanked and no used anyway⌠Thanks for explanation.
Thank you for your interest in ME Analyzer and for using it.
It has to be calculated manually and after taking in mind all the differences, weirdness, uncharted sections etc which have appeared in all the firmware that MEA supports (10 ME, 3 TXE and 4 SPS major generations). MEA is open source so if you are interested, the full code on how it calculates the sizes can be found at its github page.
The size of the ME region does not matter as long as data are not lost. MEA checks that but also reports extra padding to lower the required filesize. For example, you can find a 8MB ME region at an SPI image with only the first 1.5MB taken by the ME code and everything being unneeded padding. This is due to various reasons but the most usual is that, by design/default, any extra space of the SPI image is appended to the ME region. So, if a system uses a 16MB chip and the BIOS is 9MB for example, the ME will be padded at the end if its region to fill the rest, meaning approximately 7MB (minus the Flash Descriptor which is 4KB at the start).
I donât understand this sentence.
