Hi plutomaniac!
If ME Analyzer output “File does not contain Intel Engine Firmware”, does it mean that my BIOS has not ME components and I am lucky, or tool simple can not analyze my BIOS file?
For example, this ROM http://dlcdnet.asus.com/pub/ASUS/mb/LGA1…DELUXE-2209.zip
@ BlackIce:
The X58 chipset of your motherboard did not have any Engine firmware.
hi pluto, do you know what platform the "11.0.12.1003_COR_H_D0_UKPDM_PRD_RGN" firmware is for specifically?
Hello chinobino, no I do not. You meant to show the COR-H and not CON-H, right? If yes, I am looking for someone with a COR-H system who can test it and tell me.
Ha! You caught me out - was reading it as CON-H.
However, I am curious as to what COR-H is now…
Ah, in that case: The 11.0.12.1008 CON-H we currently have is PDM, verified by Pacman and others. Last non-PDM CON-H we have is 11.0.11.1005.
Do you mean what COR-H means? It stands for Corporate H, just like you use Consumer H (CON-H). If you meant that you wonder whether the COR-H/LP we have are PDM or NOPDM, I need testers to verify them and adjust the MEA db and filenames.
Engine Firmware Repository Database r58 :
Assigned PDM status to more ME 11.0 firmware
Added ME 11.0.10.1002_COR_LP_C0_NOPDM_PRD_RGN
Added SPS 04.00.03.095_PRD_REC
Added SPS 04.00.03.095_PRD_OPR
Engine Firmware Repository Database r59b :
Latest ME 11.0 COR H SKU to 11.0.15.1003
Added ME 11.0.15.1003_COR_H_XX_UKPDM_PRD_EXTR
Added SPS 03.01.03.036_PRD_REC
Added SPS 03.01.03.036_PRD_OPR
Added SPS 02.01.04.074_PRD_REC
Added SPS 02.01.04.074_PRD_OPR
Engine Firmware Repository Database r60 :
Added ME 11.0.12.1008_COR_H_D0_UKPDM_PRD_RGN
Added ME 11.0.11.1002_CON_H_D0_NOPDM_PRD_RGN
Added TXE 1.2.0.1144_1.375MB_MD_PRD_RGN
Removed TXE 1.2.0.1144_1.375MB_MD_PRD_EXTR
Added SPS 03.01.03.012_PRD_REC
Added SPS 03.01.03.012_PRD_OPR
-------[ ME Analyzer v1.5.7 ]-------
Database r60
File: me.bin
Firmware: Intel ME
Version: 11.0.15.1003
Release: Production
Type: Region, Extracted
SKU: Error, unknown ME 11.0 Consumer SKU! *
VCN: 16
PDM: Unknown
PV: Yes
Date: 06/06/2016
FIT Ver: 11.0.10.1002
FIT SKU: PCH-H Z170
Platform: SKL-SPT
Based on Kernel & FIT, the SKU could be:
Consumer H
The DB does not have any relevant entries.
* Please report this issue!
Note: This firmware was not found at the database, please report it!
Edit: remove arrach
@ SoniX:
Intel Management Engine: Drivers, Firmware & System Tools (151)
You just need to add manually the “MEA” db entry shown at that post to MEA.dat
Oops! Excuse me. ![]()
@plutomaniac i ran MEA.exe application nothing happened & MEA_Drop shown file: none
Read the instructions at the first post to understand how it works, you are obviously using it in a wrong way
yeah i read it, i’m able to drag “9.1.37.1002_5MB_PRD_RGN.bin” into MEA_Drop but the MEA.exe is not working.
It’s like I visit a doctor and say “I’m in pain” without adding anything else. Same thing here, more details are needed to pinpoint the issue, if there is one.
ME Analyzer v1.5.10 :
Added better early support for TXE 11.5 KBL firmware
Merged MEA_Drop with MEA into a single script/executable
Fixed issue that caused wrong ME2-ME4 Type detection
Fixed issue that caused wrong ME2 ICH B0 SKU detection
Parameter -multi now renames only files that need checking
Updated Intel Engine Firmware Repository Database to r61
@SoniX Don’t forget to change …\bios.bin to bios.bin at UBU batch script and GUI.
Engine Firmware Repository Database r61 :
Latest ME 11.5 CON LP SKU to 11.5.1.1006
Latest ME 11.0 CON H SKU to 11.0.15.1003
Latest ME 11.0 CON LP SKU to 11.0.15.1003
Added ME 11.5.1.1006_CON_LP_XX_UKPDM_PRD_EXTR
Added ME 11.5.0.1058_CON_LP_XX_UKPDM_PRD_EXTR
Added ME 11.0.15.1003_CON_H_D0_UKPDM_PRD_EXTR
Added ME 11.0.15.1003_CON_LP_C0_UKPDM_PRD_EXTR
Added ME 11.0.0.1198_CON_H_D0_NOPDM_PRD_EXTR
Added ME 11.0.0.1197_CON_H_D0_NOPDM_PRE_RGN
Added ME 11.0.0.1197_CON_LP_B1_NOPDM_PRE_RGN
Added ME 7.1.70.1198_5MB_ALL_PRD_EXTR
Added SPS 04.00.03.124_PRD_REC
Added SPS 04.00.03.124_PRD_OPR
Added SPS 03.00.03.025_PRD_REC
Added SPS 03.00.03.025_PRD_OPR
Ok. ![]()
v1.5.10
Not working option:
MEA.exe -info
For command line, everything except -ubu (UBU), -ubupre (UBU Pre-Menu), -extr (Extractor/UEFIStrip) and -msg (Extractor/UEFIStrip) requires parameter -skip to bypass the intro screen.
