Microcode replacement
Hello, i wanted to try different microcode with z790 apex encore, i can remove all microcodes and insert only one i want and it works but when i try to replace only one from microcode switch i do that then fix fit table it shows it correctly but:
  1. i don’t know how can i edit setting name in setup since if i change from 0x10E to 0x11D in hxd ifr extractor stops working
  2. when i load this microcode i get 69 on post code every time, does anyone know how to fix that, do i need to edit setup data or setup?
