Need AHCI/SATA Drivers for GA-EP45T-USB for Windows XP Pro 64Bit
I am trying to install Windows XP Pro 64Bit on GA-EP43T-USB Rev 1.0. Since the install dose not Recognize my SEDA drive I’m assuming I need a driver for it.
i follow this guide and try to use this drivers ( not looking in to Integrate the drivers)
[Guide] Integration of Intels AHCI/RAID drivers into a WinXP/W2k3/W2k CD
just copy them to Floppy and provide it during the install with F6 but it is keep giving me BSOD.
i am using rufus to burn the ISO on the USB. i burn the CD but that also gave me BSOD.
Please Help me and Advise me on the next step…
Thank you so much in advance..
GA-EP43T-USB
Intel Core 2 Quad
8gb DDR3 1600
256 SSD
@dodoland
Questions:
  1. Which are the HardwareIDs of the on-board Intel SATA Controller? If you have already installed any Windows OS on the PC, you can get the information by running the Device Manager, expanding the section “IDE ATA/ATAPI Controllers”, doing a right-click onto the listed Intel SATA Controller and the choosing the options “Properties” > “Details” > “Property” > “HardwareIDs”.
  2. Which Error message did you get while getting the BSOD?
  3. Which specific Intel AHCI driver did you load (F6 option) at the beginning of the XP installation?
