[OFFER] ASUS Rampage V Extreme - modded BIOSes
Hi mate, I’m using 2101 bios with 3A microcodes, plus all orom/efi modules updated as well. You don’t need to do a clean install. 3B and 3C microcodes affect any performance on these CPUs,
so I would flash the same (or any other) bios with 3A microcodes. That’s enough IMHO.
Sylar76 I didn’t explain that well. I am doing a clean install because it has been awhile since I have and after all the installs/uninstalls of software I do…not to mention all the windows updates…it gets pretty mucked up on my PC.
I didn’t understand your phrase of: "3B and 3C microcodes affect any performance on these CPUs" Are you saying that the 3B & 3C microcodes DON’T affect performance on the 5930k?
It has been said that 3C is meltdown/specte batch. There is only affect in that version.
Maybe also 3B? So you wanted to use 3A.
Exactly. 5930k will have performance drops as well as for a broadwell-e cpu with those microcodes (3B-3C or a similar for broadwell-E).
So it’s better to stay with 3A.
Has anyone actually benchmarked the performance hit? From what I gather, everyone is just rehashing theoreticals. Even if it does exist, it could be perhaps 1%, in which case, who cares?
anyone Mod last bios 3902?
Hi, my cpu 5960x Engineering Sample and i have bios 3504, but update to 3902 and not booting, which version of bios and microcodes is better to use with my cpu?. can update 3902 whith microcode for my cpu?
Thanks for everything
Since this is @Sylar76 thread I don’t want to jump in and start posting mods before he does, that wouldn’t be cool
@itmon I can update 3902 if Syler76 doesn’t want to update these anymore, but since he just replied on here I’m sure he’ll probably do the microcode updates for you.
Same to @panosxidis I’m sure Syler76 will post you both an updated BIOS shortly, if he doesn’t want to I’m sure he’ll let us know here and then if so I will help.
Here we go :
3902 Mod (latest cpu microcodes, intel orom/efi for sata and lan).
https://drive.google.com/open?id=1QzxNXF…TmFKpJ3fxKcE4aK
Which MicroCodes did you put in there? I have the 5930k
3D for 5930k.
Very thanks now boot my 5960x ES perfectly with 3902 mod
Microcode for broadwell-e? i have 6950X
406F1 (Broadwell-E) has 2E microcodes.
Anyway I’ve added latest cpu microcodes for meltdown/spectre, so anyone is fully protected.
who is faster for my cpu? 3801 OR LAST BIOS?
Sylar76 can you mod bios 3902 without spectre and meltdown???
Sylar76 can you mod bios 1902 for the Rampage V ED. 10 with the latest cpu microcodes, intel orom/efi for sata and lan
I waited for someone to update cpu microcodes. I updated them myself =)
RAMPAGE V EDITION 10 BIOS 1902
https://drive.google.com/open?id=1EqaoSw…jlE1q39qabGd0Ts
You could even ask for it. I could have modded it as well as the rampage V (non Edition 10) one.
Hi Sylar786
I did ask for a modded bios for the ED. 10 Rampage in post @#317 but no reply.
Thanks
