I receive thousands of message and notifications every day but sometimes messages are overlapped and I can’t read all of them. I’m sorry.
Anyway I’m going to mod 1902 with all needed parts updated.
Sylar76 can you mod bios with last everything without Spectre and Meltdown?{Asus Rampage V} 3902 bios
@catch36
Here is the Rampage V Edition 10 modded bios as requested.
https://drive.google.com/open?id=1zaNzLF…rzOYNNmfgb7rM9O
You can try the one attached and use the InSpectre.exe as admin in order to disable both Spectre/Meltdown via registry and it will be the same.
I have this Program i disable both in inspectre.exe and thats it?or another step?thanks a lot
That’s it. Disable both of them if you want pure performance and reboot PC. Once rebooted you will notice the same pc speed as before spectre/meltdown fixes.
i think no same perfomance https://www.youtube.com/watch?v=LC1WuKdPVCQ see this video!!!
and ssds iops drops
As said before, if you use InSpectre.exe and click on "Disable Meltdown…" and "Disable Spectre" and do a reboot, your PC will have the same
behaviour of an "Unpatched" machine and you will not have any performance drops.
Anyone actually tried this? I am getting black screen and shutdowns with this BIOS. Any other works fine.
Works for me. I did mod it with UEFIPatch to unlock the MSR 0xE2 register for Hackintosh purposes though.
hi
i am new here
i have Asus rampage V extreme board and try to flash with bios latest here for this board and its say its wrong bios
what i can do?
i have Xeon V4 and bios without mod not support it
please help me
THanks!
You have to do it via BIOS flashback.
Or use this method, you have to do as shown and find your own variables for this board, can’t use the exact ones in the guide
[GUIDE] Grub Setup_Var Guide - Fix Intel FPT Error 368 - BIOS Lock Bit Set HSFS W/ Asus or Other Mod BIOS
thanks for answers!
if i want use Ami update bios tool, i need to rename this file to XXX.rom?
or need make diferent special file?
Gonzo thanks. but asus bios dont let me flash it say its wrong bios, its some how blocked
need to flash it with ami bios tool
just dont know how to use cap file with utility
maybe some can help me flash moded bios onto my motherboard please , how to do it?
i downloaded AMI update utility and its say again bios security code error
and not alow flash bios
I gave you the link to use BIOS flashback above.
I also showed you method to unlock BIOS locks, so you can use Intel FPT
