[OFFER] ASUS Rampage V Extreme - modded BIOSes
Thanks for clarifying, I thought you meant you needed a non-windows-10 BIOS So that’s on me
I understand what you mean on the microcodes too, that refers to microcodes etc. But still don’t know what you mean about nonsense with the microcodes, you can put in or take out any ones you want, but you have to leave in the one for your CPU and any CPU you think you might want to use in the future
Glad @Sylar76 helped you with mod BIOS, thanks Sylar76!
Hello guys i find one bios for Asus rampage v10 edition 9001 bios official for Asus here:https://drive.google.com/file/d/1hTtIkRu…3JOZCPaRRK/view
can you mod bios for rampage V or no?thanks
@panosxidis - unsure what you are asking there?
Asus release for v10 9001 bios official!
any news for new Microcode?
Hello,
I have an ASUS Rampage V extreme, i’m looking for a moded BIOS for Xeon e5-2696 V3 QEY8 paired with GSKILL DDR4 F4-3400 (just in case i change for core i7)
I have tryed many BIOS and i have code 60 with one memory fitted, and 53 with no memory installed Oo.
Thanks
@Duty_Free https://drive.google.com/file/d/103nKIKb…VmA-qOX_wR/view take this one is last mod bios 3902 create by sylar76
Thanks,
now i have 55 instead of 60 post code and 53 with no memory Oo
Thanks for the bios, just in case i have tried many bioses and this happened when i flashed with bad one (before one of the bios i used no memory will result with a 55 post code and after no memory lead to 53)
If i use an external BIOS programmer perhaps this will changer i will come back with the results.
In addition my cpu was a broken one with 2 missed capacitor refitted on it by myself and controlled.
do you installed with bios flashback?
I use the Usb bios Flashback
3902 with new CPU Microcodes (and all orom/efi updated as well).
https://drive.google.com/open?id=1ndsLap…8fsXkypwaoVQQXw
Hi, I’m new and I greet everyone!
I wanted to know something about this bios mod. Does this bios fix the overclocking problems of the Broadwell-E series with Windows update KB4100347?
Thank you for the reply!
@Sylar76
Hello! Please tell me what I’m doing wrong. When I open the BIOS in UBU, there is no information about MEI Firmware.
Here is my.
Maybe some other items are not displayed.
@Dagal
In order to see the ME firmware image version, you have to use Uefi Tool.
@Sylar76
So I have everything right, and the UBU does not see
The ME firmware version and it will not be updated via UBU.
What other ORom does not see the UBU?
@Sylar76
Sylar76 can you mod/uptade bios called 1903 with lastest version cpu microcodes - everything like that latest versions and performance improvements for Asus Rampage V edition 10
since waiting it released but nothing found here. Ty for your help from now on
@Worgened
I will update this post when I’ll be able to find some time for do it (maybe tomorrow).
Edit. Here we go :
https://drive.google.com/open?id=1CBcxsD…Jnb2VpcgupLlrKR
ty mate so much:)
ASUS RAMPAGE V X99 NEW
3902 BIOS with Ethernet controller update and cpu microcodes
https://uploadfiles.io/qkf31
Please publish your modded bios under a different mirror. Google would be great.
