CFL.zip (5.3 MB)
SKL-KBL.zip (5.1 MB)
Changelog:
- Updated Secure Boot (2023)
- Nuked all hidden BIOS menu settings (probably)
- Adjusted BIOS settings for Performance & ThrottleStop
- Adjusted BIOS settings for Windows 11 & Sound Blaster device support
(Tested on SB1040 all working fine, just don’t enable HVCI/Memory Integrity) - Enabled CMOS reset via holding the power button for 6 seconds
(System will restart twice, do not touch anything while in progress!) - Added CoffeeLake support (depending on the stepping, you may need to perform a pin mod)
- Added ReBar feature from ReBarUEFI v0.3 & NvStrapsReBar v0.3
- etc. (I already forgot what other things I’ve changed, it took me about 1–3 months to mod this buggy BIOS lol. there’s still a bug when switching to pure UEFI mode, the BIOS setup menu may break on some monitors. Make sure you are already on stable settings RAM tweaks, etc. before turning it on.)
