Hello,
I have an Acer Nitro V 17 AI (ANV17-61) with an AMD Ryzen AI processor. My laptop drains the battery even when plugged in because the charger is limited to 135W but the PC consumes the same or more. I also tested with a 180W charger from another laptop and a compatible 280W/330W charger - nothing changes. The limit is clearly enforced by the firmware.
What I have already tried:
Disabled Secure Boot
Enabled testsigning (bcdedit /set testsigning on)
Tried H2OUVE - all functions are unsupported (IFR package initialization fails)
Tried RWEverything - driver fails to load
Booted RU.EFI and setup_var (GRUB mod) from USB
What I found using UEFITool + GRUB setup_var:
Using the modded GRUB with setup_var commands, I was able to read the AMD_PBS_SETUP variable. All power limit values are at 0% or 1%:
| Offset | Description | Current value |
| 0x55 | AC Maximum Performance Limit | 0x01 (1%) |
| 0x56 | AC Better Performance Limit | 0x00 (0%) |
| 0x57 | AC Better Battery Limit | 0x00 (0%) |
| 0x58 | DC Maximum Performance Limit | 0x00 (0%) |
However, writing returns: error: can't set variable using efi (error: 0x8000000000000008) which is EFI_WRITE_PROTECTED.
Technical analysis:
Using UEFITool on the BIOS image (BIOS_1_12_K.FD, Insyde H2O V1.12):
The AMD_PBS_SETUP variable is defined in AmdPbsSetupDxe with offsets 0x55-0x5A for AC/DC power limits (percentage 0-100)
The write protection comes from SmmPlatform module which registers AMD_PBS_SETUP for locking
The variable GUID is: a04a27f4-df00-4d42-b5-52-39-51-13-02-11-3d
The Setup variable is 700 bytes (0x2BC)
What I need: A patched version of the SmmPlatform SMM module (or any other fix) that removes the write protection on the AMD_PBS_SETUP variable, so I can set the power limits to 100% (0x64).
I can provide:
The full BIOS image: BIOS_1_12_K.FD
The extracted SmmPlatform module
Any other file needed
Thank you very much for your help!
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
