Hi
I am looking for assistance with a modded BIOS for my system. I am currently experiencing stability issues running Windows, and I believe this is my Win11 HomeEdition. Erros new files etc while i try mod this bios, tbh i give up, If anyone can help me.
Bios for Asus G20CI vr. All i need to unlock 8600K with OC setings.
Thank you.
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
Hi MeatWar, yes i know but when i use coffe lake tool nothiung happend. Dosnt work with my asus bios or i make some mistakes. All i have on the end is the same bios.
So, you want to put a CFLake cpu NOT unlocking OC/further options in bios…2 different things.
Doesn’t the OP of that thread had exactly the same symptom when he used a CFLake CPU, besides mcodes being present? What can you read next…
Don’t like to read??? Well…your loss then.
Hi so i unlock oc feature in AMIBCP but when i try use CFLake tool norhing change for me.
