Hello everyone,
I am trying to update/fix the BIOS on a Lenovo QiTian M4500 (Machine Type: 90BY, similar to ThinkCentre M-series). I have encountered a size mismatch issue when trying to use Intel FPT.
System Details:
- Model: Lenovo QiTian M4500-N000 (C)
- Current BIOS: O13KT23AUS (11/02/2016)
- Platform: Haswell / Intel H81/B85 chipset likely.
- Tool used: Intel FPT (Flash Programming Tool)
The Problem:
- I dumped the full SPI image using FPT, and the result is 8MB.
- FPT reports that the BIOS Region on the chip is 6MB.
- The official BIOS update file downloaded from Lenovo is only 4MB.
When I try to flash the official file using fpt -bios -f update.bin, it fails because of the size mismatch (File 4MB != Region 6MB).
Analysis:
I assume the 6MB BIOS Region consists of 2MB (likely NVRAM/Padding) + the 4MB Code volume, but I am not sure about the exact offset to construct a proper flashable file.
Request:
Could someone please look at my dump and the stock file, and help me reconstruct a valid 8MB full image (or a valid 6MB BIOS region file) that I can flash via FPT?
BIOS.zip (6.2 MB)
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title shortened
