[Problem] Biostar B350GTX → B550 BIOS Crossflash
B350 → B550 Crossflash: Feasibility, Scope, and Limits
Test report — Biostar B350GTX (Brazilian variant of the B350GT3) running B550 board firmware, with a previously validated B350GTX→X470GTQ crossflash on the same hardware
Executive summary
This report documents a practical and binary-level investigation into the physical/electrical compatibility between the AMD B350/X370/X470/B450 chipset family (shared ASMedia die, already validated in a prior test) and B550 (next generation, same manufacturer), motivated by the absence of any public report of this specific crossflash combination in the modding community.
Core result: the crossflash works electrically. A Biostar B350GTX board (Brazilian variant of the B350GT3) POSTs, boots Windows stably, and keeps most peripherals functional while running the native firmware of three different B550 boards (B550MH, B550MHP, B550MH3.0) — a direct two-generation jump, skipping X470 as an intermediate step. This is practical evidence that the B350/X470 family and B550 share pin-for-pin compatibility (or something very close to it) on the FCH footprint — something that, as far as searches indicated, had not been publicly tested or documented before.
However, the crossflash provides no practical benefit: PCIe Gen4 remains locked (an AGESA limitation, not a board one), and 4 specific USB ports fail consistently across all three tested BIOS — most likely due to the B550 firmware lacking the hardware mapping (hub/GPIO) specific to the B350GTX PCB.
1. Motivation and initial hypothesis
X470 and B550 belong to the same ASMedia chipset line for AM4, with an identical electrical uplink (PCIe 3.0 x4 between CPU and chipset) and very close TDP (5–7W), unlike X570 (AMD/GlobalFoundries in-house design, PCIe 4.0 uplink, much higher TDP). This closeness motivated the hypothesis of BGA footprint reuse between X470 and B550 — never officially documented by AMD/ASMedia (no datasheet or ball map has ever been published).
A practical precedent already validated by the author, on the same physical hardware used in this report: the Biostar B350GTX board has, on its second SPI chip (BIOS2), a fully functional B350GTX → X470GTQ crossflash — which establishes that B350/X370/X470 (the “Promontory” family) are, with high probability, the same physical die, differentiated by SKU/fuses/firmware. This crossflash served as a stable working reference and as a safety net during the tests described here.
The open question was whether that same compatibility extends to B550 — a following generation, with a redesigned die (native PCIe 3.0 downlink vs. X470’s PCIe 2.0), but the same manufacturer and uplink. The test was performed on the first SPI chip (BIOS1) of the same B350GTX.
2. Preliminary binary analysis (before the physical test)
Files analyzed:
  • X47AS831.BST — official Biostar X470GTQ BIOS (vendor image, used here as a generic reference for the X470 family — independent of the physical board tested in Section 3/4)
  • B55AS831.BSS — official Biostar B550 BIOS (same “AS831” project naming as the X470 file, additional hint of a shared PCB)
  • DumpX470GTQ — real SPI dump of the B350GTX’s BIOS2 chip (the chip already carrying the previously established X470GTQ crossflash), named after the firmware it contains
SHA256 hashes (reference/integrity):
DumpX470GTQ    d2033ede03bee61bd6bfdfae6b3184eb3370f2f8efb402536f6ac173bc34e787
X47AS831.BST   f7b25db2f629cbe74c2d1423b0e4d9f301e10ee71a75c638504ef66e092676ea
B55AS831.BSS   95f43016235d8bed457fac832ad3591e87a16989475b3b955f0b59cd320978e2
2.1 General binary diff, X470 vs B550
  • 60.3% of the 16MB image is byte-for-byte identical between the two BIOS
  • 29 contiguous diverging regions, totaling 6.36MB
  • The final tail of the file (~2.2MB) is 100% identical
2.2 PSP directories (AGESA/PSP firmware)
$PSP directories located at identical offsets in both images: 0x110000, 0x260000, 0x3DF000, 0x60F000, 0x78F000.
  • At 0x3DF000, 0x60F000, and 0x78F000: directories are byte-identical, including checksum — fully reused firmware blobs.
  • At 0x110000 (24 entries) and 0x260000 (31 entries): identical entry type sequence, mostly identical sizes — only checksum and a few specific sizes change (component types 0x1, 0x2, 0xC, 0x28, 0x208, 0x212 — likely SMU/bootloader, expected to differ by version).
  • AGESA block (type 0x4): same size and same absolute address (0xFF087000) in both images.
2.3 Main Firmware Volume (DXE)
Located via the standard EFI_FIRMWARE_FILE_SYSTEM2 GUID (8C8CE578-8A3D-4F1C-9935-896185C32DD3):
Start offset Size
X470 0x94F000 3,870,720 bytes
B550 0x92F000 4,001,792 bytes
The size difference (128KB) matches exactly the offset shift between the two volumes — meaning most of the “raw diff” in this region is just a cascading misalignment caused by a single volume being 128KB larger on B550 (extra drivers), not a wholesale content rewrite.
2.4 Validation against real hardware
The real dump of the B350GTX’s BIOS2 (DumpX470GTQ) has all 5 PSP directories byte-identical to the official X47AS831.BST file, confirming that the X470GTQ crossflash active on that chip is running exactly that firmware version, with no corruption. The only differences (94.1% identical blocks) are expected runtime data: NVAR (variable store), memory-training cache, APOB blocks — nothing indicating corruption or an anomaly.
2.5 Indirect chipset-identification clue
CPU-Z, on a real B550MH board, reported Southbridge: AMD B350, Rev 51 (instead of B550). A documented parallel case (Dell Alienware R10, a B550 board) showed Southbridge: AMD X570, Rev 51 in the same type of tool. Since X570 is proven to be a different die (AMD/GF, not ASMedia), this coincidence suggests the “Rev 51” field is not a reliable SKU identifier — it more likely reflects a generic value (FCH stepping/revision) poorly mapped by outdated name lookup tables in these tools, rather than direct proof of die identity.
3. Physical test methodology
  • Donor/test board: Biostar B350GTX (Brazilian variant of the B350GT3), AMD Ryzen 5 5500 CPU, physical dual BIOS (two separate SPI chips + BIOS1/BIOS2 selector switch)
  • Flashing: AFUWinx64.exe (AMI) utility, from within Windows, with the command line:
    AFUWINx64.exe B55BS831-B550MH3.0.BSS /P /B /N /K /X
    The /X flag disables the Board ID/ROM ID check — it’s what allows flashing an image from a different board model, bypassing the validation that would normally block the process. /P programs the main BIOS, /B includes the boot block, /N and /K skip additional confirmation/compatibility-check steps in the utility.
  • Protocol: BIOS2 kept on the already-validated X470GTQ crossflash (safety net); B550 images flashed and tested sequentially on BIOS1; read-back and hash comparison before any boot attempt
  • BIOS tested on the BIOS1 chip (via the physical switch): B550MH, B550MHP, B550MH3.0 — three different firmware variants from the same product line
4. Results
4.1 Functional (across all three tested variants)
  • Full POST, no CMOS reset required
  • Stable Windows boot, no crashes
  • PS/2 keyboard (confirms the LPC/eSPI bridge is operational)
  • Audio
  • Network
  • SATA (implied by the OS booting)
  • Most USB ports
4.2 Non-functional (consistent across all three B550 BIOS)
  • PCIe Gen4: the Radeon Pro VII GPU (Vega 20, PCIe 4.0-capable, confirmed via GPU-Z) negotiates only Gen3, even under load. Likely cause: conditional AGESA gating out of caution for signal integrity on a previous-generation PCB not validated for Gen4 — this isn’t a simple firmware flag, and manually forcing it in Setup risks subtle instability (link retraining errors) rather than a clean failure.
  • 4 specific USB ports: 2x rear USB 3.1 + front-panel USB 2.0 + front-panel USB 3.1
    • With the generic Windows driver: Code 10 (“This device cannot start”)
    • After installing the AMD chipset driver: Code 43 (“Windows has stopped this device”)
    • Identical pattern across all 3 tested B550 BIOS → rules out a one-off bug in a specific firmware version
    • The elimination test (disabling Global C-State, AMD’s official workaround for a known Ryzen USB bug) was not validated before switching BIOS — it remains a not-fully-isolated variable, though the exact repeatability of the pattern across 3 distinct firmwares points more toward a structural cause than toward AMD’s generic C-state/PCIe bug (which tends to be more erratic across reboots).
4.3 Hypothesis for the USB port failures
  • DSDT/SSDT analysis (extracted via RWEverything, manually decoded): the XHC0/XHC1 controllers and the 20 port objects under RHUB (_UPC/_PLD) use generic AGESA template values — every port is described as USB3 Type-A, with no genuine FRONT/BACK marking. In other words, the ACPI device tree does not carry board-specific customization — that is not where the cause lives.
  • The most likely candidate is the APCB (AGESA PSP Customization Block) — a binary blob inside the PSP directory that carries board-specific parameters (USB Over-Current pin mapping, GPIO, etc.). 20–22 APCB blocks were located at matching offsets between the two images; unlike the PSP directories (nearly identical), every compared APCB block differs in size/checksum between X470 and B550 — consistent with this being the layer where the hardware mapping diverges.
  • Full decoding of the APCB contents was not completed in this test (would require tools such as PSPTool, apcbtool, or the amd-apcb crate, along with a reference Type ID table).
5. Conclusion and decision
Even assuming the 4 USB ports could be fixed via APCB editing or an SSDT overlay, the crossflash’s upside ceiling would be zero: PCIe Gen4 stays locked by AGESA’s decision regardless of which BIOS is used, and USB, at best, would only return to the parity the board already had with the X470GTQ crossflash (BIOS2). There is no practical advantage to keeping the B550 crossflash in use — decision made to discontinue the test and keep the board running on the already-validated X470GTQ crossflash (BIOS2).
6. Contribution to the community
As far as searches indicated at the time of this test, there was no public report of a documented B350/X470/B450 → B550 crossflash — neither a success nor a detailed failure. This test demonstrates:
  1. It is electrically viable — three different B550 firmwares POST and run stably on a B350 PCB (B350GTX/B350GT3), a two-generation chipset jump
  2. The failure is isolated and localizable — it is not a general board failure, it is specifically USB (likely hub/GPIO routing) and PCIe Gen4 (AGESA gating)
  3. The likely cause was traced to the correct layer (APCB, not ACPI/DSDT), opening a path for anyone who wants to continue the investigation with the right tools
Appendix A — Test environment
  • Board: Biostar B350GTX / B350GT3 (physical dual BIOS) — BIOS2 with the already-validated X470GTQ crossflash (precedent/safety net); BIOS1 used for the B550 tests in this report
  • CPU: AMD Ryzen 5 5500
  • Test GPU: AMD Radeon Pro VII (Vega 20, PCIe 4.0)
  • B550 firmwares tested: B550MH, B550MHP, B550MH3.0 (Biostar)
  • Tools: AFUWinx64.exe (AMI), RWEverything (ACPI extraction), GPU-Z, CPU-Z, HWiNFO
Appendix B — Recommended tools to continue the investigation
  • PSPTool— pip install psptool — parses/extracts the PSP directory and auto-identifies entry types
  • apcbtool— dedicated APCB block parser
  • amd-apcb— documented Rust library for APCB manipulation (Oxide Computer)
@flaviodelima
Welcome to the Win-Raid Forum!
Your contribution has been written with a mixture of portuguese and english language words, which is not easy to understand.
Since this is a “pure” English language Forum, please translate your text completely to English.
Thanks in advance and good luck for you regarding the feedback!
Sorry. The AI ​​failed to translate.
:grimacing:
Thank you very much for putting in the time and effort to document what you have done so far!
I almost went down the same path with another Biostar B350 board (B350ET2) about two years ago. Bios updates are very rare from them, but updates to fTPM are needed every now and then for online anti-cheat. If we can arrive at a good and general approach to crossflashing, those B350 and B450 boards can get updates for as long as the B550 boards gets them.
I think one very valuable thing to mention here is that from first gen Ryzen, AMD bios chips are (as far as I know) operating at 1.8V. So for instance the original CH341A (=5V only) is very likely to fry the BIOS chip. There is however an updated version that has selectable voltage.
