I installed Ubuntu server onto a NVME through a PCIe adapter, and it shows up selectable in the UEFI boot menu. But when I try boot from it, I just get stuck on a black screen. I’m not sure if I need to mod by BIOS to make it properly boot, since that seems to be required for PCs this old. Any help appreciated!
Edit by Fernando: Thread title customized
Check this out. You can use YouTube’s automatic subtitles, or just look at the steps.
Is there any way to do this without using Windows? I currently only have an older version of Ubuntu installed and would prefer not to have to install Windows just for this.
Maybe Intel FPT under DOS?
If the NVMe SSD is listed within the mainboard BIOS as bootable UEFI device, you neither have to modify the BIOS nor to install Windows.
Please check the installation medium.
Testing the drive and adapter on another PC, it booted normally. On the T3600, the drive doesn’t show up in the setup menu itself, but only in the F12 boot menu.
Which “setup menu” of which Operating System do you mean? Did you erase the old data from the NVMe SSD? How has the SSD been formatted?
To be able to boot off a certain device, a compatible boot sector has to be on it.
If you want to install any OS onto an HDD or SSD, you have to delete its existing data and to create a new boot sector.
Here’s a video I recorded of the issue. The Windows Boot Manager entry is old and I just forgot to remove it. If I connect the SSD to my personal computer, the Ubuntu boot option works fine.
Flashing this with flashrom fixed the issue. Thanks for the help!
