Hello everyone,
I’m hoping someone with experience in Acer/Insyde firmware can point me in the right direction.
I’m trying to repair an Acer Predator Triton 16 PT16-51-99GL that no longer POSTs, and before my SPI programmer arrives I’m trying to gather as much information as possible.
Laptop Information
Model: Acer Predator Triton 16 PT16-51-99GL
Motherboard: DA0ZQDMB8AE Rev. E
Main SPI flash: Winbond W25Q256JVEN (32MB)
Secondary SPI flash: Winbond W25Q80EW (1MB)
Symptoms
The laptop powers on but never completes POST.
Current symptoms:
Charging LED works normally.
Keyboard RGB lights up.
Fans spin normally.
Internal display stays black.
External HDMI display also stays black.
No Acer logo.
Caps Lock never responds, so it appears the system never begins POST.
The laptop was working normally before being stored for several months. When I powered it on again, these symptoms appeared immediately.
What I have already tried
Disconnected and reconnected the battery.
Performed a power drain.
Tested each RAM stick individually.
Tested both RAM slots.
Tested with an external monitor.
Inspected the motherboard for obvious burnt or damaged components and found nothing obvious.
Official Acer BIOS
I downloaded the official Acer BIOS v1.03 from Acer’s support website.
I tried extracting the BIOS using:
7-Zip
Windows Command Prompt
PowerShell
7-Zip reports that the EXE is not an archive.
Running the updater simply displays:
“This platform does not support IHISI interface.”
and exits immediately.
I also monitored the Windows temporary folders while launching the updater but couldn’t find any extracted BIOS files.
At the moment I only have Acer’s BIOS updater EXE and have not been able to obtain a raw BIOS image from it.
Programmer
I have already ordered a programmer and my first step will be to make multiple verified dumps of my original BIOS before writing anything.
I understand that my own dump is important because it contains machine-specific information, and I have no intention of flashing another BIOS without first understanding exactly what it contains.
My questions
Does anyone happen to have a verified original 32MB dump for this motherboard (DA0ZQDMB8AE Rev. E) or this exact laptop model?
Has anyone successfully extracted the raw BIOS image from Acer’s BIOS updater for this model without using commercial software?
Is Acer’s updater likely to contain:
a complete 32MB SPI image,
only the BIOS region,
or separate BIOS and EC firmware?
If my original dump is readable but partially corrupted, is it generally possible to rebuild it by combining my dump with Acer’s official BIOS package, or is a donor dump usually required for this platform?
I’m trying to understand the proper recovery path before my programmer arrives so I don’t make unnecessary mistakes.
Any advice, documentation, or experience with this specific motherboard would be greatly appreciated.
Thank you very much for your time.
Edit by Fernando: Thread moved into the “BIOS Requests” Category and title shortened
