asus laptop with mainboard b1400cepey dead after flash bios chip with ch341a anyone have idea?
Edit by Fernando: Thread title customized
Where is the original corrupted backup (NOT web flashed dumps), sn, model and mb id label?
even i reflash with origialbuckup it still dead
Sir…what was the initial issue with the system? 11 or 12th Gen?
Share it or not, your call, no share nothing to advance on it…
We know what board is sir… AGAIN, what was the initial issue with the system? Original firmware corruption? Then post it on not.
the customer tell that not read apop up message and shutdown the laptop after that the laptop power on without graphics
Most likely a bad bios update via WU, if so the firmware is corrupted due to interruption.
The Asus files are not read ones for direct programming, so that’s why the original corrupted dump reading is necessary, understood now?
before flashing the new firmware i was backup the original one…even i flash back the original the laptop still dead
Ok…
Well if its corrupted is obvious that flashing the same firmware, the system stays death anyway… Get a better translator, because you seem not to understood what i just wrote the previous post.
what i dont undrestand?
What you dont understand is simple sir… your flashing the original corrupted backup and complained about the system staying death anyway… “genius ideia”
Or you cant explain yourself correctly…
